Hello World,
I have some kind of problem with two bindinds on my openhab system. A couple month ago I started with this project and after some hours I was binding openhab to my Gardena smart account. It works straight ahead perfect. Parallel to this I was binding my Rademacher Smart Home system to openhab. I focused on that topic and neglected the gardena things for a while. After a couple of weeks I had set up all of my Rademacher stuff so that it worked all proper. I refocused on Gardena. The binding was not working anymore. The thing-entry in MainUI showed me error in connection. So I checked my logs. To be honest I am not a professional programmer so I got really quickly stucked with the given message. I searched the community and did what most guys did there and deleted the api and made it all again. No positive result.
I thought okay, lets focus on something else to get more comfy with all that stuff. I implemented HUE and Spotify and did some work on the layout. All worked out fine. Last week I wanted to connect openhab to Alexa. Again I got a failure message about ECDH Handshake. Now I am wondering what is wrong on my system. Below I will paste a brief list of my log and I would very appreciate it if someone out there could just give me an hint what is wrong on my system.
Another information: On the husqvuarna develpment site they give you the api key, the api secret and a test linkt to copy into your terminal. I did the testlink and that works but the binding in openhab not. Maybe there is a setting that is wrong in my openhab. I am desperate…
best regards,
Skywalker without stars in the night
Log:
2023-06-02 22:03:56.439 [WARN ] [org.eclipse.jetty.server.HttpChannel] - handleException /amazonechocontrol/d80a847812/ap/signin/132-5198524-2964711 javax.net.ssl.SSLException: Could not generate ECDH keypair
2023-06-02 22:04:28.887 [WARN ] [ity.CommunityMarketplaceAddonService] - Unable to retrieve marketplace add-ons: Cannot verify CertificateVerify signature
2023-06-02 22:05:52.507 [WARN ] [ternal.handler.GardenaAccountHandler] - javax.net.ssl.SSLHandshakeException: Could not generate ECDH keypair
2023-06-02 22:03:51.287 [WARN ] [ternal.handler.GardenaAccountHandler] - javax.net.ssl.SSLHandshakeException: Could not generate ECDH keypair
2023-06-02 22:03:56.431 [WARN ] [mazonechocontrol.internal.Connection] - Request to url ‘https://api.amazon.com/auth/register’ fails with unknown error
at sun.security.ssl.Alert.createSSLException(Alert.java:133) ~[?:?]
at sun.security.ssl.TransportContext.fatal(TransportContext.java:353) ~[?:?]
at sun.security.ssl.TransportContext.fatal(TransportContext.java:296) ~[?:?]
at sun.security.ssl.TransportContext.fatal(TransportContext.java:291) ~[?:?]
at sun.security.ssl.SSLSocketImpl.handleException(SSLSocketImpl.java:1690) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:471) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:427) ~[?:?]
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:572) ~[?:?]
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:201) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream0(HttpURLConnection.java:1367) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(HttpURLConnection.java:1342) ~[?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(HttpsURLConnectionImpl.java:246) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:640) ~[bundleFile:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:561) ~[bundleFile:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.registerConnectionAsApp(Connection.java:752) ~[bundleFile:?]
at org.openhab.binding.amazonechocontrol.internal.AccountServlet.handleProxyRequest(AccountServlet.java:641) ~[bundleFile:?]
at org.openhab.binding.amazonechocontrol.internal.AccountServlet.doVerb(AccountServlet.java:231) ~[bundleFile:?]
at org.openhab.binding.amazonechocontrol.internal.AccountServlet.doPost(AccountServlet.java:126) ~[bundleFile:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) ~[bundleFile:3.1.0]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) ~[bundleFile:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:550) ~[bundleFile:9.4.46.v20220331]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:74) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440) ~[bundleFile:9.4.46.v20220331]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[bundleFile:9.4.46.v20220331]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:90) ~[bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.46.v20220331]
Caused by: java.lang.RuntimeException: Could not generate ECDH keypair
at sun.security.ssl.ECDHKeyExchange$ECDHEPossession.(ECDHKeyExchange.java:124) ~[?:?]
at sun.security.ssl.NamedGroup$ECDHEScheme.createPossession(NamedGroup.java:575) ~[?:?]
at sun.security.ssl.NamedGroup$NamedGroupSpec.createPossession(NamedGroup.java:511) ~[?:?]
at sun.security.ssl.NamedGroup.createPossession(NamedGroup.java:419) ~[?:?]
at sun.security.ssl.ECDHClientKeyExchange$ECDHEClientKeyExchangeProducer.produce(ECDHClientKeyExchange.java:399) ~[?:?]
at sun.security.ssl.ClientKeyExchange$ClientKeyExchangeProducer.produce(ClientKeyExchange.java:65) ~[?:?]
at sun.security.ssl.SSLHandshake.produce(SSLHandshake.java:436) ~[?:?]
at sun.security.ssl.ServerHelloDone$ServerHelloDoneConsumer.consume(ServerHelloDone.java:182) ~[?:?]
at sun.security.ssl.SSLHandshake.consume(SSLHandshake.java:392) ~[?:?]
at sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:443) ~[?:?]
at sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:421) ~[?:?]
at sun.security.ssl.TransportContext.dispatch(TransportContext.java:183) ~[?:?]
at sun.security.ssl.SSLTransport.decode(SSLTransport.java:172) ~[?:?]
at sun.security.ssl.SSLSocketImpl.decode(SSLSocketImpl.java:1507) ~[?:?]
at sun.security.ssl.SSLSocketImpl.readHandshakeRecord(SSLSocketImpl.java:1417) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:456) ~[?:?]
… 49 more
Caused by: java.security.InvalidAlgorithmParameterException: Unsupported curve: secp256r1 [NIST P-256, X9.62 prime256v1] (1.2.840.10045.3.1.7)
at sun.security.ec.ECKeyPairGenerator.ensureCurveIsSupported(ECKeyPairGenerator.java:137) ~[jdk.crypto.ec:?]
at sun.security.ec.ECKeyPairGenerator.initialize(ECKeyPairGenerator.java:114) ~[jdk.crypto.ec:?]
at java.security.KeyPairGenerator$Delegate.initialize(KeyPairGenerator.java:699) ~[?:?]
at sun.security.ssl.ECDHKeyExchange$ECDHEPossession.(ECDHKeyExchange.java:119) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:2023-06-02 22:07:55.013 [WARN ] [ternal.handler.GardenaAccountHandler] - javax.net.ssl.SSLHandshakeException: Could not generate ECDH keypair
