Following this thread in the google group
https://groups.google.com/forum/#!topic/openhab/yCd7eTb6jjg
I am trying to use the binding built by @Nicholas_Waterton that is posted in that thread
my configs:
gc100ir:mediaroom.host=192.168.60.225
String TV_POWER_MODE_ON { gc100ir="[#mediaroom|2|1|0000,0071,0000,0032,0080,003f,0010,0010,0010,0030,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0030,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0030,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0030,0010,0030,0010,0030,0010,0030,0010,0030,0010,0030,0010,0010,0010,0010,0010,0030,0010,0030,0010,0030,0010,0030,0010,0030,0010,0030,0010,0010,0010,0030,0010,0a98]" }
Switch item=TV_POWER_MODE_ON label=“Power ON” mappings=[POWERON=“POWER ON”]
It doesn’t work when I hit the button, here is some of the relevant log output
2015-11-16 02:04:29.100 [ERROR] [o.o.b.g.i.GC100IRActiveBinding] - Connection failed with #mediaroom
2015-11-16 02:04:29.115 [INFO ] [.o.b.g.lib.GC100IRControlPoint] - Connected Successfully to /192.168.60.225:4998
2015-11-16 02:04:29.116 [INFO ] [.service.AbstractActiveService] - GC100IR Refresh Service has been started
2015-11-16 02:06:45.201 [INFO ] [runtime.busevents ] - TV_POWER_MODE_ON received command POWERON
2015-11-16 02:06:45.302 [WARN ] [.b.g.internal.GC100IRConnector] - Failed to execute command over GC100: 192.168.60.225 with Module: 2 of Connector: 1 to Item: TV_POWER_MODE_ON
2015-11-16 02:09:51.456 [INFO ] [runtime.busevents ] - TV_POWER_MODE_ON received command POWERON
2015-11-16 02:09:51.456 [WARN ] [o.o.b.g.i.GC100IRActiveBinding] - Received command (POWERON) for item TV_POWER_MODE_ON but the connection to the GC100 instance mediaroom is down, ignoring
