Hello -
Can one of those that have succeeded in getting this to work please help? I am not having much luck. Here is what I did. By the way I am using OH 2.5 but not using the OH built in MQTT Broker
- Connected Automation Module to Concord 4 Panel
- Connected Automation Module to Raspberry Pi (same Pi that has Openhab running on it) using RS232 serial->USB cable
- Used eclipse to create a concord4pi.jar file (using everything in the concord4pi folder) from your code and uploaded to my openhab2-addons folder
- Installed mosquito broker on same Raspberry Pi
- Here is my Config for the broker and thingā¦
Bridge mqtt:broker:mosquittobroker [ host=ā192.xxx.xxx.xxxā, secure=false ]
Thing topic alarm āAlarm Stateā @ āInterlogixā {
Channels:
Type string : alarmstate [ stateTopic=āconcord4pi/areapartition/0100/armingLevel/textā]
Item:
String AlarmStateText āAlarm State Text [%s]ā {channel=āmqtt:topic:mosquittobroker:alarm:alarmstateā }
Issues encountered:
- I am getting an error on the Alarm Panel (I had only one item and now have two with the Automation Module. The error is 'System Bus Failure AM1. I guess this was because I powered up the alarm before connecting the Raspberry Pi. Now I cant get rid of the error
- Is my MQTT config and topic correct?
- Is it possible to upload the jar file? Atleast that way I can verify that I am using one that is working
Thanks!
