I just realized while creating this post that the model number is slightly off from what shown on the z-wave device database. ( 58433 vs 58436)
I am running the latest snapshot of OpenHAB 4.2 and have paired a GE Enbrighten Z-Wave Plus Smart Switch (58436). Obviously it’s not recognized, but the one listed in the database appears to be of the same kind (difference is that mine is a toggle and not a paddle).
https://opensmarthouse.org/zwavedatabase/1589
Is it easy to add this into the database manually?
<node>
<homeId>0xcb4d0aaa</homeId>
<nodeId>9</nodeId>
<version>4</version>
<manufacturer>0x63</manufacturer>
<deviceId>0x3330</deviceId>
<deviceType>0x4952</deviceType>
<listening>true</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>500</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<commandClass>COMMAND_CLASS_APPLICATION_STATUS</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
<commandClass>COMMAND_CLASS_INDICATOR</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_BINARY</commandClass>
<commandClass>COMMAND_CLASS_SCENE_ACTIVATION</commandClass>
<commandClass>COMMAND_CLASS_SCENE_ACTUATOR_CONF</commandClass>
<commandClass>COMMAND_CLASS_TRANSPORT_SERVICE</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
<commandClass>COMMAND_CLASS_SECURITY_2</commandClass>
<commandClass>COMMAND_CLASS_SUPERVISION</commandClass>
<commandClass>COMMAND_CLASS_CENTRAL_SCENE</commandClass>
<commandClass>COMMAND_CLASS_FIRMWARE_UPDATE_MD</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map">
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<maxNodes>0</maxNodes>
<name>Lifeline</name>
<profile1>0x0</profile1>
<profile2>0x1</profile2>
<commands>
</commands>
<associations>
<associationMember>
<node>1</node>
</associationMember>
</associations>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<name>Single Press</name>
<profile1>0x20</profile1>
<commands>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
</commands>
<associations/>
</associationGroup>
</entry>
<entry>
<int>3</int>
<associationGroup>
<index>3</index>
<name>Double Press</name>
<profile2>0x2</profile2>
<commands>
</commands>
<associations/>
</associationGroup>
</entry>
</associationGroups>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SWITCH_BINARY</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_NOT_USED</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<COMMAND__CLASS__BASIC>
<versionSupported>2</versionSupported>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<COMMAND__CLASS__APPLICATION__STATUS>
</COMMAND__CLASS__APPLICATION__STATUS>
</entry>
<entry>
<COMMAND__CLASS__SWITCH__BINARY>
</COMMAND__CLASS__SWITCH__BINARY>
</entry>
<entry>
<COMMAND__CLASS__SCENE__ACTIVATION>
</COMMAND__CLASS__SCENE__ACTIVATION>
</entry>
<entry>
<COMMAND__CLASS__SCENE__ACTUATOR__CONF>
</COMMAND__CLASS__SCENE__ACTUATOR__CONF>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION__GRP__INFO>
<versionSupported>3</versionSupported>
<autoSubscribeGroups>
<int>1</int>
</autoSubscribeGroups>
</COMMAND__CLASS__ASSOCIATION__GRP__INFO>
</entry>
<entry>
<COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</entry>
<entry>
<COMMAND__CLASS__CENTRAL__SCENE>
<version>3</version>
<sceneCount>2</sceneCount>
</COMMAND__CLASS__CENTRAL__SCENE>
</entry>
<entry>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<zwPlusVersion>2</zwPlusVersion>
<zwPlusRole>ROLE_TYPE_SLAVE_ALWAYS_ON</zwPlusRole>
<zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<versionSupported>4</versionSupported>
<configParameters/>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>99</deviceManufacturer>
<deviceType>18770</deviceType>
<deviceId>13104</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<COMMAND__CLASS__FIRMWARE__UPDATE__MD>
<versionSupported>5</versionSupported>
</COMMAND__CLASS__FIRMWARE__UPDATE__MD>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
<version>2</version>
<maxGroups>3</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>7.15</protocolVersion>
<applicationVersion>1.22</applicationVersion>
<hardwareVersion>1</hardwareVersion>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<COMMAND__CLASS__INDICATOR>
<supportedIndicatorsInitialised>true</supportedIndicatorsInitialised>
<supportedIndicators>
<ZWaveIndicator>
<type>NODE_IDENTIFY</type>
</ZWaveIndicator>
</supportedIndicators>
</COMMAND__CLASS__INDICATOR>
</entry>
<entry>
<COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors/>
<lastReceived>2024-03-29 15:53:38.912 UTC</lastReceived>
</node>
