Thank you for the information, I really appreciate it I have created a database account and opened a ticket to get permission to update. I found “ZW3011” in the database:
Jasco Products ZW3011/14322/46565 In-Wall Smart Toggle Dimmer All Wall Switch
The Manufacturer ID and DeviceType match my device and the picture looks the same, however the content does not appear to be a very good match to my xml file.
I am not sure at this point weather I need to upload the xml file to the database or just add the extra references to the existing device. I find the xml files confusing and I don’t want to break anything. Can someone please point me in the right direction.
But the database has a different type ID. Yours has 3132 but the database has 3237.
Manufacturer ID 0063
Name ZW3011/14322/46565
Device Description In-Wall Smart Toggle Dimmer
Category Wall Switch
References (Type:Id) 4944:3237
My suggestion is to create a new device in the database since it is different. You may be able to copy much of the information from the other device to your new device.
I don’t know if it is possible to have the same device in the database with 2 different device ID’s. If your device matched perfectly, then maybe that would work, but I defer to the experts on that.
I’ve fixed the error with the thingid, but it does seem we have two devices with the same name. Are these really different?
If it’s basically the same, then we should just update the existing device rather than create a new entry. You need to compare the manuals to see if they have the same associations and config parameters - to me the device looks the same outside of this (ie the classes look pretty much the same).
@chris Thank you for fixing the thingid. As you suggested I compared the manuals and they appear to be the same to me so I updated the entry for “ZW3011/14322/46565” with my xml file for “14296”.
The updated entry is now waiting for approval. My new entry which is no longer needed is still there as well, is there any way to remove it. ?
Thanks for all the work you do for the community. I really appreciate it.
