I am trying to get the CalDAV binding to work on my OH1 system and have quite a few questions. I believe I have all of the files necessary installed in the addons folder.
- org.openhab.io.caldav-1.8.2.jar
- org.openhab.persistence.caldav-1.8.2.jar
- org.openhab.binding.caldav-1.8.2.jar
My openhab.cfg file set up as follows. I have the refresh time set to be short for testing purposes.
################################### CalDAV IO Binding ###################################
# Used to connect to Cal DAV. All parameters are required.
# Path to the calendar
# caldavio:<calendarId>:url=
caldavio:ohab:url=https://www.google.com/calendar/dav/me@mydomain.com/events
# Username for the calendar
# caldavio:<calendarId>:username=
caldavio:ohab:username=username
# Password for the calendar
# caldavio:<calendarId>:password=
caldavio:ohab:password=password
# Reload interval unit is minutes.
# Defines how often the calendar should be reloaded from server.
# Default is 60 minutes
# caldavio:<calendarId>:reloadInterval=
caldavio:ohab:reloadInterval=5
# This defines which events are relevant for execution. Unit is in minutes.
# Default is 1 Day (1440 minutes)
# caldavio:<calendarId>:preloadTime=
caldavio:ohab:preloadTime=5
# A caldav Server is just a webdav Server which list files. Some servers does not use the valid timestamp for modifications.
# If your calendar does not provide correct timestamps you have to set this false.
# Default is true
# caldavio:<calendarId>:lastModifiedFileTimeStampValid=
# SSL verification can be disabled, if you don't want to import the server certificate
# into the java keystore. This is just needed for self-signed certificates, where the
# certificate path cannot be verified. Default is false. Do not set to true if no SSL is used.
# caldavio:<calendarId>:disableCertificateVerification=
# Timezone for events which does not have a timeZone information.
# Normally this is not required
# caldavio:timeZone=
caldavio:timeZone=America/Chicago
################################ CalDAV Command Binding ###################################
# see CalDAV IO Binding
# Used to execute commands if events starts or ends with an easy notation in the event description.
# commaseperated (e. g. openhab, anothercalendar)
# caldavCommand:readCalendars=<ids from caldav-io>
caldavCommand:readCalendars=ohab
############################# CalDAV Personal Binding ################################
# Used to toggle switch items for presence. Switched to ON if an event in the calendar occurs.
# And back to OFF if the event ends.
# Can also be used to show upcoming or active events
# Which calendars should be used to detect presence (comma separated)
# caldavPersonal:usedCalendars=<ids from caldav-io>
caldavPersonal:usedCalendars=ohab
# If the location of the event is one of this identifiers, the presence will not be changed.
# Can be used for events which are at home or are just reminders. (comma separated, optional)
# caldavPersonal:homeIdentifiers=
The CalDAV items files has the following:
String oHABcalendarN1 "Name [%s]" <calendar> {caldavPersonal="calendar:ohab type:ACTIVE eventNr:1 value:NAME"}
String oHABcalendarP1 "Place [%s]" <calendar> {caldavPersonal="calendar:ohab type:ACTIVE eventNr:1 value:PLACE"}
DateTime oHABcalendarS1 "Start [%1$tT, %1$td.%1$td.%1$tY]" <calendar> {caldavPersonal="calendar:ohab type:ACTIVE eventNr:1 value:START"}
DateTime oHABcalendarE1 "End [%1$tT, %1$td.%1$td.%1$tY]" <calendar> {caldavPersonal="calendar:ohab type:UPCOMING eventNr:1 value:END"}
And the event in my calendar has the following:
Event Name : testevent
Start Time : any
End Time : any
Description : BEGIN:sKitchenLightStatus:ON
END:sKitchenLightStatus:OFF
I based the files off of the binding page in the wiki. Do I need the CalDAV items file if the calendar entry is referencing items I have in my MiOS items file?
I have the logging turned on to TRACE for CalDAV and here is the most recent output. I had just stopped the service added an event for 30 minutes in the future that should have been picked up.
2016-05-17 21:39:59 DEBUG o.o.i.c.i.CalDavActivator[:34]- CalDav Calendar IO has been started.
2016-05-17 21:39:59 DEBUG o.o.b.c.i.CalDavActivator[:34]- CalDav-Presence binding has been started.
2016-05-17 21:39:59 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:82]- handling config: calendar:ohab type:ACTIVE eventNr:1 value:NAME
2016-05-17 21:39:59 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:93]- handling config part: calendar:ohab
2016-05-17 21:39:59 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:93]- handling config part: type:ACTIVE
2016-05-17 21:39:59 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:93]- handling config part: eventNr:1
2016-05-17 21:39:59 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:93]- handling config part: value:NAME
2016-05-17 21:39:59 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:117]- found values: calendar=[ohab], type=ACTIVE, eventNr=1, value=NAME
2016-05-17 21:39:59 DEBUG o.o.b.c.i.CalDavBindingProviderImpl[:156]- adding item: oHABcalendarN1
2016-05-17 21:39:59 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:82]- handling config: calendar:ohab type:ACTIVE eventNr:1 value:PLACE
2016-05-17 21:39:59 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:93]- handling config part: value:PLACE
2016-05-17 21:39:59 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:117]- found values: calendar=[ohab], type=ACTIVE, eventNr=1, value=PLACE
2016-05-17 21:40:00 DEBUG o.o.b.c.i.CalDavBindingProviderImpl[:156]- adding item: oHABcalendarP1
2016-05-17 21:40:00 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:82]- handling config: calendar:ohab type:ACTIVE eventNr:1 value:START
2016-05-17 21:40:00 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:93]- handling config part: calendar:ohab
2016-05-17 21:40:00 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:93]- handling config part: type:ACTIVE
2016-05-17 21:40:00 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:93]- handling config part: eventNr:1
2016-05-17 21:40:00 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:93]- handling config part: value:START
2016-05-17 21:40:00 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:117]- found values: calendar=[ohab], type=ACTIVE, eventNr=1, value=START
2016-05-17 21:40:00 DEBUG o.o.b.c.i.CalDavBindingProviderImpl[:156]- adding item: oHABcalendarS1
2016-05-17 21:40:00 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:82]- handling config: calendar:ohab type:UPCOMING eventNr:1 value:END
2016-05-17 21:40:00 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:93]- handling config part: type:UPCOMING
2016-05-17 21:40:00 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:93]- handling config part: value:END
2016-05-17 21:40:00 TRACE o.o.b.c.i.CalDavBindingProviderImpl[:117]- found values: calendar=[ohab], type=UPCOMING, eventNr=1, value=END
2016-05-17 21:40:00 DEBUG o.o.b.c.i.CalDavBindingProviderImpl[:156]- adding item: oHABcalendarE1
2016-05-17 21:40:00 DEBUG o.o.b.c.internal.CalDavBinding[:66]- setting CalDavLoader: true
2016-05-17 21:40:00 DEBUG o.o.b.c.internal.CalDavBinding[:77]- CalDavBinding (personal) activated
2016-05-17 21:40:00 DEBUG o.o.b.c.i.CalDavActivator[:34]- CalDav-Command binding has been started.
Any help guidance would be greatly appreciated.
