General error during canonicalization: NoClassDefFoundError: …ScriptedCustom_ModuleHandlerFactory
I want to write a Groovy script, which utilizes @TypedChecked and @CompileStatic as much as possible. My aim is to convert the groovy file to an almost identical class file, which utilizes no dynamic logic at runtime and executes just as fast as a .class file:
import org.openhab.core.automation.*
import org.openhab.core.automation.util.TriggerBuilder
import org.openhab.core.automation.module.script.rulesupport.shared.simple.SimpleRule
import org.openhab.core.config.core.Configuration
import org.slf4j.LoggerFactory
scriptExtension.importPreset("RuleSupport")
@groovy.transform.TypeChecked
@groovy.transform.CompileStatic
class m {
   org.slf4j.Logger log = LoggerFactory.getLogger("org.openhab.core.model.script.rele1")
   m(org.openhab.core.automation.module.script.rulesupport.shared.ScriptedAutomationManager automationManager) {
     SimpleRule s1 = new SimpleRule() {
       String name = "B2"
       @Override
       Object execute(Action module, Map<String, ?> inputs) {
	   log.info("ABC")
       List<Trigger> triggers = [
         TriggerBuilder.create().withId("trig2a").withTypeUID("core.ItemStateChangeTrigger")
         .withConfiguration(new Configuration([itemName: "inv1_Inverter_mode"])).build()
     automationManager.addRule(s1)  // Problematic Line
new m(automationManager)
Why does the Problematic Line above produce:
2024-09-01 17:52:12.115 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script ‘/etc/openhab/automation/jsr223/m3.groovy’: org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed:
General error during canonicalization: java.lang.NoClassDefFoundError: org.openhab.core.automation.module.script.rulesupport.internal.ScriptedCustomModuleHandlerFactory
java.lang.RuntimeException: java.lang.NoClassDefFoundError: org.openhab.core.automation.module.script.rulesupport.internal.ScriptedCusto
at org.codehaus.groovy.control.CompilationUnit$IPrimaryClassNodeOperation.doPhaseOperation(CompilationUnit.java:972)
at org.codehaus.groovy.control.CompilationUnit.processPhaseOperations(CompilationUnit.java:692)
at org.codehaus.groovy.control.CompilationUnit.compile(CompilationUnit.java:666)
at groovy.lang.GroovyClassLoader.doParseClass(GroovyClassLoader.java:373)
at groovy.lang.GroovyClassLoader.lambda$parseClass$2(GroovyClassLoader.java:316)
at org.codehaus.groovy.runtime.memoize.StampedCommonCache.compute(StampedCommonCache.java:163)
at org.codehaus.groovy.runtime.memoize.StampedCommonCache.getAndPut(StampedCommonCache.java:154)
at groovy.lang.GroovyClassLoader.parseClass(GroovyClassLoader.java:314)
at groovy.lang.GroovyClassLoader.parseClass(GroovyClassLoader.java:298)
at groovy.lang.GroovyClassLoader.parseClass(GroovyClassLoader.java:258)
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.getScriptClass(GroovyScriptEngineImpl.java:350)
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:159)
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:137)
at java.scripting/javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:247)
at org.openhab.core.automation.module.script.internal.ScriptEngineManagerImpl.loadScript(ScriptEngineManagerImpl.java:165)
at org.openhab.core.automation.module.script.rulesupport.loader.AbstractScriptFileWatcher.createAndLoad(AbstractScriptFileWatcher.java:336)
at org.openhab.core.automation.module.script.rulesupport.loader.AbstractScriptFileWatcher.lambda$13(AbstractScriptFileWatcher.java:310)
at java.base/java.util.concurrent.CompletableFuture$AsyncRun.run(CompletableFuture.java:1804)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
at java.base/java.lang.Thread.run(Thread.java:840)
Caused by: java.lang.NoClassDefFoundError: org.openhab.core.automation.module.script.rulesupport.internal.ScriptedCustomModuleHandlerFactory
at org.codehaus.groovy.ast.decompiled.AsmReferenceResolver.resolveClass(AsmReferenceResolver.java:46)
at org.codehaus.groovy.ast.decompiled.AsmReferenceResolver.resolveNonArrayType(AsmReferenceResolver.java:79)
at org.codehaus.groovy.ast.decompiled.AsmReferenceResolver.resolveType(AsmReferenceResolver.java:70)
at org.codehaus.groovy.ast.decompiled.MemberSignatureParser.resolve(MemberSignatureParser.java:172)
at org.codehaus.groovy.ast.decompiled.MemberSignatureParser.createMethodNode(MemberSignatureParser.java:64)
at org.codehaus.groovy.ast.decompiled.DecompiledClassNode.lambda$createConstructor$2(DecompiledClassNode.java:277)
at org.codehaus.groovy.ast.decompiled.DecompiledClassNode.createConstructor(DecompiledClassNode.java:283)
at org.codehaus.groovy.ast.decompiled.DecompiledClassNode.lazyInitMembers(DecompiledClassNode.java:238)
at org.codehaus.groovy.ast.decompiled.DecompiledClassNode.getDeclaredMethods(DecompiledClassNode.java:212)
at org.codehaus.groovy.ast.ClassNode.getDeclaredMethods(ClassNode.java:882)
at org.codehaus.groovy.ast.ClassNode.getMethods(ClassNode.java:897)
at org.codehaus.groovy.transform.stc.StaticTypeCheckingVisitor.findMethodsWithGenerated(StaticTypeCheckingVisitor.java:4785)
at org.codehaus.groovy.transform.stc.StaticTypeCheckingVisitor.findMethod(StaticTypeCheckingVisitor.java:4884)
at org.codehaus.groovy.transform.stc.StaticTypeCheckingVisitor.visitMethodCallExpression(StaticTypeCheckingVisitor.java:3455)
at org.codehaus.groovy.transform.sc.StaticCompilationVisitor.visitMethodCallExpression(StaticCompilationVisitor.java:422)
at org.codehaus.groovy.ast.expr.MethodCallExpression.visit(MethodCallExpression.java:77)
at org.codehaus.groovy.ast.CodeVisitorSupport.visitExpressionStatement(CodeVisitorSupport.java:117)
at org.codehaus.groovy.ast.ClassCodeVisitorSupport.visitExpressionStatement(ClassCodeVisitorSupport.java:204)
at org.codehaus.groovy.transform.stc.StaticTypeCheckingVisitor.visitExpressionStatement(StaticTypeCheckingVisitor.java:2160)
at org.codehaus.groovy.ast.stmt.ExpressionStatement.visit(ExpressionStatement.java:41)
at org.codehaus.groovy.ast.CodeVisitorSupport.visitBlockStatement(CodeVisitorSupport.java:86)
at org.codehaus.groovy.ast.ClassCodeVisitorSupport.visitBlockStatement(ClassCodeVisitorSupport.java:168)
at org.codehaus.groovy.transform.stc.StaticTypeCheckingVisitor.visitBlockStatement(StaticTypeCheckingVisitor.java:3956)
at org.codehaus.groovy.ast.stmt.BlockStatement.visit(BlockStatement.java:72)
at org.codehaus.groovy.ast.ClassCodeVisitorSupport.visitClassCodeContainer(ClassCodeVisitorSupport.java:142)
at org.codehaus.groovy.ast.ClassCodeVisitorSupport.visitConstructorOrMethod(ClassCodeVisitorSupport.java:115)
at org.codehaus.groovy.transform.stc.StaticTypeCheckingVisitor.visitConstructorOrMethod(StaticTypeCheckingVisitor.java:2595)
at org.codehaus.groovy.ast.ClassCodeVisitorSupport.visitConstructor(ClassCodeVisitorSupport.java:105)
at org.codehaus.groovy.transform.stc.StaticTypeCheckingVisitor.visitConstructor(StaticTypeCheckingVisitor.java:2544)
at org.codehaus.groovy.transform.sc.StaticCompilationVisitor.visitConstructorOrMethod(StaticCompilationVisitor.java:222)
at org.codehaus.groovy.transform.sc.StaticCompilationVisitor.visitConstructor(StaticCompilationVisitor.java:247)
at org.codehaus.groovy.ast.ClassNode.visitContents(ClassNode.java:1121)
at org.codehaus.groovy.ast.ClassCodeVisitorSupport.visitClass(ClassCodeVisitorSupport.java:52)
at org.codehaus.groovy.transform.stc.StaticTypeCheckingVisitor.visitClass(StaticTypeCheckingVisitor.java:446)
at org.codehaus.groovy.transform.sc.StaticCompilationVisitor.visitClass(StaticCompilationVisitor.java:198)
at org.codehaus.groovy.transform.sc.StaticCompileTransformation.visit(StaticCompileTransformation.java:68)
at org.codehaus.groovy.transform.ASTTransformationVisitor.visitClass(ASTTransformationVisitor.java:155)
at org.codehaus.groovy.transform.ASTTransformationVisitor.lambda$addPhaseOperations$2(ASTTransformationVisitor.java:237)
at org.codehaus.groovy.control.CompilationUnit$IPrimaryClassNodeOperation.doPhaseOperation(CompilationUnit.java:938)
… 23 more
1 error
