Using Openhab latest Snapshot, but had seen this Problem since Month.
Some Items like Sunrise from Astro Binding, LastSeen from network binding allways causes errors an no SQL-Table for the persistence values can be found.
I analysed the tables and the Logs.
Every Item using the type DateTime causes the following error, only table-name is different:
2019-11-10 00:00:31.023 [ERROR] [org.knowm.yank.Yank ] - Error in SQL query!!!
java.sql.SQLException: Table 'openhab2.sun_set_time_0579' doesn't exist Query: INSERT INTO sun_set_time_0579 (TIME, VALUE) VALUES( NOW(3), ? ) ON DUPLICATE KEY UPDATE VALUE= ? Parameters: [2019-11-10 16:46:00.0, 2019-11-10 16:46:00.0]
at org.apache.commons.dbutils.AbstractQueryRunner.rethrow(AbstractQueryRunner.java:392) ~[250:org.openhab.persistence.jdbc:1.14.0.201911091730]
at org.apache.commons.dbutils.QueryRunner.update(QueryRunner.java:491) ~[250:org.openhab.persistence.jdbc:1.14.0.201911091730]
at org.apache.commons.dbutils.QueryRunner.update(QueryRunner.java:457) ~[250:org.openhab.persistence.jdbc:1.14.0.201911091730]
at org.knowm.yank.Yank.execute(Yank.java:194) [250:org.openhab.persistence.jdbc:1.14.0.201911091730]
at org.knowm.yank.Yank.execute(Yank.java:177) [250:org.openhab.persistence.jdbc:1.14.0.201911091730]
at org.openhab.persistence.jdbc.db.JdbcBaseDAO.doStoreItemValue(JdbcBaseDAO.java:337) [250:org.openhab.persistence.jdbc:1.14.0.201911091730]
at org.openhab.persistence.jdbc.internal.JdbcMapper.storeItemValue(JdbcMapper.java:145) [250:org.openhab.persistence.jdbc:1.14.0.201911091730]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.store(JdbcPersistenceService.java:137) [250:org.openhab.persistence.jdbc:1.14.0.201911091730]
at org.openhab.core.persistence.internal.PersistenceServiceDelegate.store(PersistenceServiceDelegate.java:59) [241:org.openhab.core.compat1x:2.5.0.201911090307]
at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.handleStateEvent(PersistenceManagerImpl.java:137) [182:org.openhab.core.persistence:2.5.0.201911090304]
at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.stateChanged(PersistenceManagerImpl.java:437) [182:org.openhab.core.persistence:2.5.0.201911090304]
at org.eclipse.smarthome.core.items.GenericItem$1.run(GenericItem.java:261) [134:org.openhab.core:2.5.0.201911090301]
Very special: If i create a table with this via phpMyAdmin with fields time and value, both type timestamp the errors go away and persistence ist doing as expected.
Why automatic creation of persistence tables doesnt work if there is a DateTime Value?
Have same problem when using mysql database via jdbc with latest version of openhab. All items which are configured as DateTime items are affected. In earlier days I had MariaDB in place and not these problems but other ones why I switched to mysql
mysql --version show these output at my openhab server:
mysql Ver 8.0.19-0ubuntu0.19.10.3 for Linux on aarch64 ((Ubuntu))
mysqld --version show these output at my database server:
mysqld Ver 5.7.29-0ubuntu0.18.04.1 for Linux on aarch64 ((Ubuntu))
thanks for the detailed SQL query try to help solving the problem, I keep in my mind for other topics,
I havenāt received an email that this topic was updated.
My solution: a big bang insteadā¦I setup both systems from the scratch:
-using raspbian buster instead of ubuntu to get rid of starting problems with mariadb
-using again mariadb instead of mysql
This problem is now solved, but seems to be that mariadb has now problems with items of type āLocationā
I have no idea were to fix it:-(
Regarding limitations of String items inside of DB with nonworking default varchar of 65000, I configured it manually to 2048 and solved this problem. I tried to extend varchar from 30 to 128ā¦No luck. Maybe shorter values at LON and LAT like 50.0 and 10.0 instead of 50.12345678 and 10.12345678 will help⦠We will see. I read somewhere else that usually a db expects LAT and LON with max 6 digits after the ā.ā
Has anyone else had any experience with this, or come up with a solution? I have the exact same problem after upgrading from OpenHAB2.5 to 3.1.0.M5. I started with a clean mysql database and for the most part my persistence is working, except for DateTime items, and some string items that look like times or dates. (I have some String items that have a value like ā2d 03:45:32ā, and these also raise this sql error).
