Hello Guys,
im a OpenHab2 noob and i have a big Problem. Also when i open PaperUI and enter there the Player with Mute, Volume, Play it works fine and i can use all over PaperUI and HabDroid(PaperUI/Home). But when i want to make my own sitemap with categories i must use a other way rigth? In Both ways PaperUI and the Sitemap Mute and Volume works but Play and Power dont work!
I Download Designer open it and make squeeze.items and write there
Switch KitchenPlay “Play” { squeeze=“kitchen:play” }
Switch KitchenMute “Mute” { squeeze=“kitchen:mute” }
Dimmer KitchenVolume “Volumen” { squeeze=“kitchen:volume” }
in the squeeze.sitemap i write
Switch item=KitchenPlay mappings=[ON=“Play”, OFF=“Stop”]
Switch item=Kitchen Mute
Slider item=KitchenVolume
in the openhab.cfg (there i copy from github original) i write the Server and the Player
squeeze:Kitchen.id=de:ad:be:ef:12:34
i think that i have a genarel Problem with the addon but i dont know where i find the right datas in the link
https://github.com/openhab/openhab1-addons/wiki/Squeezebox-Binding stay that i Need org.openhab.io.squeezeserver and org.openhab.binding.squeezebox i install over PaperUI the binding but dont find the io what i do wronge?
Please help me. Thanks
