Signal is reading just fine. LED is reading fine. Only having issues with LED.
Here is the channel for LED.
Here is the LED Item.
When i toggle the swithch in paperui control here is a tail -f | grep ESP_Easy_LED on /var/log/openhab2/events.log
andrew@OpenHab-Home:/var/log/openhab2$ tail -f events.log | grep ESP_Easy_LED
2020-08-23 17:14:46.961 [ome.event.ItemCommandEvent] - Received event of type ‘ItemCommandEvent’ under the topic ‘smarthome/items/ESP_Easy_LED/command’ with payload: ‘{“type”:“OnOff”,“value”:“ON”}’
2020-08-23 17:14:46.962 [ome.event.ItemCommandEvent] - Item ‘ESP_Easy_LED’ received command ON
2020-08-23 17:14:46.963 [nt.ItemStatePredictedEvent] - Received event of type ‘ItemStatePredictedEvent’ under the topic ‘smarthome/items/ESP_Easy_LED/statepredicted’ with payload: ‘{“predictedType”:“OnOff”,“predictedValue”:“ON”,“isConfirmation”:false}’
2020-08-23 17:14:46.964 [nt.ItemStatePredictedEvent] - ESP_Easy_LED predicted to become ON
2020-08-23 17:14:46.988 [vent.ItemStateChangedEvent] - Received event of type ‘ItemStateChangedEvent’ under the topic ‘smarthome/items/ESP_Easy_LED/statechanged’ with payload: ‘{“type”:“OnOff”,“value”:“ON”,“oldType”:“OnOff”,“oldValue”:“OFF”}’
2020-08-23 17:14:46.990 [vent.ItemStateChangedEvent] - ESP_Easy_LED changed from OFF to ON
And here is the output logs when toggling the device in paper ui running a tail -f | grep ESP_Easy_LED on openhab.log
@OpenHab-Home:/var/log/openhab2$ tail -f openhab.log | grep ESP_Easy_LED
2020-08-23 17:09:57.486 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - REQUEST for //192.168.1.3:8080/rest/items/ESP_Easy_LED on HttpChannelOverHttp@24171eb0{r=1,c=false,c=false/false,a=IDLE,uri=//192.168.1.3:8080/rest/items/ESP_Easy_LED,age=0}
POST //192.168.1.3:8080/rest/items/ESP_Easy_LED HTTP/1.1
2020-08-23 17:09:57.487 [DEBUG] [.eclipse.jetty.server.HttpConnection] - HttpConnection@1ff8d3b4::SocketChannelEndPoint@17a6e4b7{/192.168.1.100:49357<->/192.168.1.3:8080,OPEN,fill=-,flush=-,to=31/30000}{io=0/0,kio=0,kro=1}->HttpConnection@1ff8d3b4[p=HttpParser{s=CONTENT,0 of 3},g=HttpGenerator@3fdb0fa0{s=START}]=>HttpChannelOverHttp@24171eb0{r=1,c=false,c=false/false,a=IDLE,uri=//192.168.1.3:8080/rest/items/ESP_Easy_LED,age=1} parsed true HttpParser{s=CONTENT,0 of 3}
2020-08-23 17:09:57.488 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@24171eb0{r=1,c=false,c=false/false,a=IDLE,uri=//192.168.1.3:8080/rest/items/ESP_Easy_LED,age=2} handle //192.168.1.3:8080/rest/items/ESP_Easy_LED
2020-08-23 17:09:57.489 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@24171eb0{r=1,c=false,c=false/false,a=DISPATCHED,uri=//192.168.1.3:8080/rest/items/ESP_Easy_LED,age=3} action DISPATCH
2020-08-23 17:09:57.490 [DEBUG] [org.eclipse.jetty.server.Server ] - REQUEST POST /rest/items/ESP_Easy_LED on HttpChannelOverHttp@24171eb0{r=1,c=false,c=false/false,a=DISPATCHED,uri=//192.168.1.3:8080/rest/items/ESP_Easy_LED,age=4}
2020-08-23 17:09:57.491 [DEBUG] [ax.web.service.spi.model.ServerModel] - Matching [/rest/items/ESP_Easy_LED]…
2020-08-23 17:09:57.492 [DEBUG] [ax.web.service.spi.model.ServerModel] - Path [/rest/items/ESP_Easy_LED] matched to {pattern=/rest/.,model=ServletModel{id=org.ops4j.pax.web.service.spi.model.ServletModel-5,name=org.ops4j.pax.web.service.spi.model.ServletModel-5,urlPatterns=[/rest/],alias=/rest,servlet=com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge@1c849e0a,initParams={},context=ContextModel{id=org.ops4j.pax.web.service.spi.model.ContextModel-4,name=,httpContext=DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [19], contextID=default],contextParams={},virtualHosts={},connectors={}}}}
2020-08-23 17:09:57.492 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/items/ESP_Easy_LED @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [19], contextID=default]}
2020-08-23 17:09:57.494 [DEBUG] [.jetty.server.handler.ContextHandler] - context=||/rest/items/ESP_Easy_LED @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [19], contextID=default]}
2020-08-23 17:09:57.496 [DEBUG] [eclipse.jetty.servlet.ServletHandler] - servlet |/rest|/items/ESP_Easy_LED → org.ops4j.pax.web.service.spi.model.ServletModel-5@378be0fd==com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge,jsp=null,order=-1,inst=true,async=true
2020-08-23 17:09:57.497 [DEBUG] [ce.jetty.internal.HttpServiceContext] - Handling request for [/rest/items/ESP_Easy_LED] using http context [DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [19], contextID=default]]
2020-08-23 17:09:57.502 [DEBUG] [.eclipse.jetty.server.HttpConnection] - HttpConnection@1ff8d3b4::SocketChannelEndPoint@17a6e4b7{/192.168.1.100:49357<->/192.168.1.3:8080,OPEN,fill=-,flush=-,to=46/30000}{io=0/0,kio=0,kro=1}->HttpConnection@1ff8d3b4[p=HttpParser{s=CONTENT,0 of 3},g=HttpGenerator@3fdb0fa0{s=START}]=>HttpChannelOverHttp@24171eb0{r=1,c=false,c=false/false,a=DISPATCHED,uri=//192.168.1.3:8080/rest/items/ESP_Easy_LED,age=16} parse HeapByteBuffer@d674790[p=565,l=568,c=8192,r=3]={POST /rest/items/…db:adblk_no\r\n\r\n<<>>TF06PVBSMXV3A|159…d":true,“verify} {}
2020-08-23 17:09:57.505 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@24171eb0{r=1,c=false,c=false/false,a=DISPATCHED,uri=//192.168.1.3:8080/rest/items/ESP_Easy_LED,age=19} onContent Content@7070e2c9{HeapByteBufferR@750138aa[p=565,l=568,c=8192,r=3]={POST /rest/items/…db:adblk_no\r\n\r\n<<>>TF06PVBSMXV3A|159…d”:true,"verify}}
2020-08-23 17:09:57.511 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@24171eb0{r=1,c=false,c=false/false,a=DISPATCHED,uri=//192.168.1.3:8080/rest/items/ESP_Easy_LED,age=25} onContentComplete
2020-08-23 17:09:57.513 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@24171eb0{r=1,c=false,c=false/false,a=DISPATCHED,uri=//192.168.1.3:8080/rest/items/ESP_Easy_LED,age=27} onRequestComplete
2020-08-23 17:09:57.517 [DEBUG] [.eclipse.jetty.server.HttpConnection] - HttpConnection@1ff8d3b4::SocketChannelEndPoint@17a6e4b7{/192.168.1.100:49357<->/192.168.1.3:8080,OPEN,fill=-,flush=-,to=61/30000}{io=0/0,kio=0,kro=1}->HttpConnection@1ff8d3b4[p=HttpParser{s=END,3 of 3},g=HttpGenerator@3fdb0fa0{s=START}]=>HttpChannelOverHttp@24171eb0{r=1,c=false,c=false/false,a=DISPATCHED,uri=//192.168.1.3:8080/rest/items/ESP_Easy_LED,age=31} parsed false HttpParser{s=END,3 of 3}
2020-08-23 17:09:57.520 [DEBUG] [.eclipse.jetty.server.HttpConnection] - releaseRequestBuffer HttpConnection@1ff8d3b4::SocketChannelEndPoint@17a6e4b7{/192.168.1.100:49357<->/192.168.1.3:8080,OPEN,fill=-,flush=-,to=65/30000}{io=0/0,kio=0,kro=1}->HttpConnection@1ff8d3b4[p=HttpParser{s=END,3 of 3},g=HttpGenerator@3fdb0fa0{s=START}]=>HttpChannelOverHttp@24171eb0{r=1,c=false,c=false/false,a=DISPATCHED,uri=//192.168.1.3:8080/rest/items/ESP_Easy_LED,age=34}
2020-08-23 17:09:57.524 [DEBUG] [rest.core.internal.item.ItemResource] - Received HTTP POST request at ‘items/ESP_Easy_LED’ with value ‘OFF’.
2020-08-23 17:09:57.527 [TRACE] [internal.events.ThreadedEventHandler] - inspect event: org.osgi.service.event.Event [topic=smarthome] {topic=smarthome/items/ESP_Easy_LED/command, type=ItemCommandEvent, payload={“type”:“OnOff”,“value”:“OFF”}, timestamp=1598220597526}
2020-08-23 17:09:57.531 [TRACE] [ore.thing.internal.AutoUpdateManager] - Optimistically updating item ‘ESP_Easy_LED’
2020-08-23 17:09:57.534 [DEBUG] [org.eclipse.jetty.server.Server ] - handled=true async=false committed=false on HttpChannelOverHttp@24171eb0{r=1,c=false,c=false/false,a=DISPATCHED,uri=//192.168.1.3:8080/rest/items/ESP_Easy_LED,age=47}
2020-08-23 17:09:57.535 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@24171eb0{r=1,c=false,c=false/false,a=COMPLETING,uri=//192.168.1.3:8080/rest/items/ESP_Easy_LED,age=49} action COMPLETE
2020-08-23 17:09:57.536 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - COMMIT for /rest/items/ESP_Easy_LED on HttpChannelOverHttp@24171eb0{r=1,c=true,c=false/false,a=COMPLETING,uri=//192.168.1.3:8080/rest/items/ESP_Easy_LED,age=50}
2020-08-23 17:09:57.541 [TRACE] [internal.events.ThreadedEventHandler] - inspect event: org.osgi.service.event.Event [topic=smarthome] {topic=smarthome/items/ESP_Easy_LED/statepredicted, type=ItemStatePredictedEvent, payload={“predictedType”:“OnOff”,“predictedValue”:“OFF”,“isConfirmation”:false}, timestamp=1598220597534}
2020-08-23 17:09:57.545 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - flushed 97 SocketChannelEndPoint@17a6e4b7{/192.168.1.100:49357<->/192.168.1.3:8080,OPEN,fill=-,flush=W,to=89/30000}{io=0/0,kio=0,kro=1}->HttpConnection@1ff8d3b4[p=HttpParser{s=END,3 of 3},g=HttpGenerator@3fdb0fa0{s=COMPLETING}]=>HttpChannelOverHttp@24171eb0{r=1,c=true,c=false/false,a=COMPLETING,uri=//192.168.1.3:8080/rest/items/ESP_Easy_LED,age=59}
2020-08-23 17:09:57.546 [TRACE] [internal.events.ThreadedEventHandler] - inspect event: org.osgi.service.event.Event [topic=smarthome] {topic=smarthome/items/ESP_Easy_LED/state, source=org.eclipse.smarthome.core.autoupdate.optimistic, type=ItemStateEvent, payload={“type”:“OnOff”,“value”:“OFF”}, timestamp=1598220597534}
2020-08-23 17:09:57.549 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - COMPLETE for /rest/items/ESP_Easy_LED written=0
2020-08-23 17:09:57.568 [TRACE] [internal.events.ThreadedEventHandler] - inspect event: org.osgi.service.event.Event [topic=smarthome] {topic=smarthome/items/ESP_Easy_LED/statechanged, type=ItemStateChangedEvent, payload={“type”:“OnOff”,“value”:“OFF”,“oldType”:“OnOff”,“oldValue”:“ON”}, timestamp=1598220597566}
2020-08-23 17:09:57.571 [DEBUG] [nternal.profiles.ProfileCallbackImpl] - Delegating command ‘OFF’ for item ‘ESP_Easy_LED’ to handler for channel ‘mqtt:topic:d1f8785b:LED’
2020-08-23 17:09:57.628 [DEBUG] [nternal.profiles.ProfileCallbackImpl] - Delegating update ‘OFF’ for item ‘ESP_Easy_LED’ to handler for channel ‘mqtt:topic:d1f8785b:LED’
Does this help and if not what specifically can i share that will help?
