Generic Presence Detection
I’m trying to use DSC Alarm sensor with this fantastic rule. But presence never goes off. What’s wrong?
items
Switch Present
Group:Switch:AND(OFF,ON) gPresent
Switch Present_Timer { expire="15s,command=OFF" }
Switch PresentDSC (gPresent)
rule
rule "System started"
    System started
    Present.sendCommand(OFF) // assume no one is home on startup
rule "gPresent updated, at least one sensor changed state"
    Item gPresent received update
    logInfo("presence.rules","gPresent aggiornato")
    // someone came home
    if(gPresent.state == ON && Present.state != ON) {
        Present_Timer.postUpdate(OFF) // cancel the timer if necessary
        Present.sendCommand(ON)
    // no one is home
    else if(gPresent.state == OFF && Present.state != OFF){
        Present_Timer.sendCommand(ON) // start the timer
rule "Present_Timer expired"
    Item Present_Timer received command OFF
rule "DSC"
    Item DSCAlarmMotion changed from OPEN to CLOSED
    PresentDSC.sendCommand(ON)
debug
rule "debug"
    Item Present received update
    sendTelegram("home", "Presence - " + Present.state.toString)
Does PresentDSC change state?
Yes
2018-10-25 23:02:17.523 [ome.event.ItemCommandEvent] - Item 'Present' received command OFF
2018-10-25 23:02:17.525 [vent.ItemStateChangedEvent] - Present changed from ON to OFF
2018-10-25 23:02:28.625 [ome.event.ItemCommandEvent] - Item 'PresentDSC' received command ON
2018-10-25 23:02:28.632 [ome.event.ItemCommandEvent] - Item 'Present' received command ON
2018-10-25 23:02:28.638 [vent.ItemStateChangedEvent] - Present changed from OFF to ON
2018-10-25 23:03:24.084 [ome.event.ItemCommandEvent] - Item 'PresentDSC' received command ON
(See time)
Does it generates the error every time the winner runs?
Do the Item names exactly match the way they are defined in PaperUI or your .items files? Case matters. I’m kind of at a loss what we it could be.
No errors into the log
Something wrong with expire binding. Present_Timer never expires. Reinstalled expire bindings, rebooted OH:
2018-10-26 11:26:29.533 [ome.event.ItemCommandEvent] - Item 'Present' received command OFF
2018-10-26 11:26:29.535 [vent.ItemStateChangedEvent] - Present changed from NULL to OFF
2018-10-26 11:26:51.936 [ome.event.ItemCommandEvent] - Item 'PresentDSC' received command ON
2018-10-26 11:26:51.939 [vent.ItemStateChangedEvent] - PresentDSC changed from NULL to ON
2018-10-26 11:26:51.940 [GroupItemStateChangedEvent] - gPresent changed from NULL to ON through PresentDSC
2018-10-26 11:26:51.944 [ome.event.ItemCommandEvent] - Item 'Present' received command ON
2018-10-26 11:26:51.945 [vent.ItemStateChangedEvent] - Present_Timer changed from NULL to OFF
2018-10-26 11:26:51.946 [vent.ItemStateChangedEvent] - Present changed from OFF to ON
This is the rule. See comment (“are you sure?”)
    System started
                                     // OFF? Are you sure?
                                     // With ON it works
    // no one is home
Yes I’m sure.
With expire="15s,command=OFF" the timer gets started when they Item changes state to ON. Is 15 seconds pass with the Item not receiving any other updates the binding will send the OFF command to the Item. When you postUodate(OFF), the binding sees that the Item is already in the OFF state now so it cancels the timer and no OFF command will be sent.
So the Timer expired rule only gets triggered when the Expire binding commands the item to OFF.
I’ve been running with this coffee for years so the concept is sound.
Rich, you can’t help yourself, can you… :smile:
I was in a meeting typing on my phone. For some reason Google really thinks I mean coffee when I type code. Sigh. Guess I need more code this morning.
:wink:
I though you came up with another idiomatic pearl!
@rlkoshak @lamero Mmm, I took a look a your code and I think your
Present_Timer
get’s never canceled, because
Present.state
is still on when someone comes home before timeout, so you will never reach
Possible solution would be to leave out
or if you don’t want that
gets triggered twice, you can add an additional else if
    else if(gPresent.state == ON && Present.state ==ON){ // someone came home but timer is running
and remove
in the first if.
Didn’t tested it, so maybe I’m wrong?
Greets Udo
I’m confused
ITEMS
Switch Present
Switch Present_Timer                              { expire="10s,command=OFF" }
RULE
    System started
    logInfo("present","gPresent.state " + gPresent.state.toString)
    logInfo("present","Present.state " + Present.state.toString)
        logInfo("present","present 1 if")
    // no one is home
        logInfo("present","present 2 if")
LOG
System start
2018-10-31 15:39:23.086 [ome.event.ItemCommandEvent] - Item 'Present' received command OFF
2018-10-31 15:39:23.088 [vent.ItemStateChangedEvent] - Present changed from ON to OFF
Alarm sensor triggered
2018-10-31 15:41:02.687 [ome.event.ItemCommandEvent] - Item 'PresentDSC' received command ON
2018-10-31 15:41:02.689 [INFO ] [lipse.smarthome.model.script.present] - gPresent.state ON
2018-10-31 15:41:02.690 [INFO ] [lipse.smarthome.model.script.present] - Present.state OFF
2018-10-31 15:41:02.690 [INFO ] [lipse.smarthome.model.script.present] - present 1 if
2018-10-31 15:41:02.691 [ome.event.ItemCommandEvent] - Item 'Present' received command ON
2018-10-31 15:41:02.692 [vent.ItemStateChangedEvent] - Present changed from OFF to ON
Alarm sensor triggered after 2 minutes
2018-10-31 15:43:09.434 [ome.event.ItemCommandEvent] - Item 'PresentDSC' received command ON
2018-10-31 15:43:09.435 [INFO ] [lipse.smarthome.model.script.present] - gPresent.state ON
2018-10-31 15:43:09.436 [INFO ] [lipse.smarthome.model.script.present] - Present.state ON
Alarm sensor triggered after 7 minutes
2018-10-31 15:48:22.300 [ome.event.ItemCommandEvent] - Item 'PresentDSC' received command ON
2018-10-31 15:48:22.303 [INFO ] [lipse.smarthome.model.script.present] - gPresent.state ON
2018-10-31 15:48:22.303 [INFO ] [lipse.smarthome.model.script.present] - Present.state ON
Full log
How alarm sensors updates their state
ITEMS
Group:Contact:OR(OPEN, CLOSED) DSCAlarmMotion <motionDetector>
Contact ZONE1_STATUS "Sensor (Zone 1)" (DSCAlarmZones, DSCAlarmMotion) { channel="dscalarm:zone:be74eaa7:zone1:zone_status" }
RULES
rule "DSC"
Present_Timer never starts, never expires
There may be a timing issue here because I’ve been running with this code (or at least code based on it) for years without problem.
The way it is supposed to work is gPresent represents the state of the actual sensors and Present is a proxy for the sensors so we can use the timer to smooth out the flapping.
In my working code at home I’m using changed as the trigger, not received update, so maybe that is part of the issue.
I’m also using a count of the ON sensors instead of just gPresent.state == ON. It looks like I’ve made a number of changes since posting this.
Ah yes, I must have fixed this somewhere along the way and forgot to come back here.
    Item gPresent changed
    logDebug("present", "gPresent changed to " + gPresent.state)
    // A presence sensor is ON, set Present to ON if it is OFF and cancel the Timer if it exists
    if(gPresent.state == ON && (Present.state != ON || Present_Timer.state == ON)) {
        logDebug("present", "Someone came home")
        if(Present_Timer.state != OFF) Present_Timer.postUpdate(OFF) // cancel the timer
        if(Present.state != ON) Present.sendCommand(ON)
    // All presence sensors are OFF, create a Timer, if one doesn't already exist, to turn Present to OFF if
    // Present isn't already OFF
    else if(gPresent.state == OFF && Present.state !-= OFF && Present_Timer.state != ON) {
        logDebug("present", "Everyone is away, setting timer")
        Present_Timer.sendCommand(ON) // set timer to turn off Present
I transcribed this and had to change the names to match the Items above. But I think this might address the issues. Let me know one way or the other and I’ll update the OP.
In your case it is important to realize that this Rule assumes that there will be one or more sensors that is constantly ON when you are home (e.g. Network binding, iCloud binding, FIND, reelyActive detection of phone or BT beacon). I don’t think it works well with motion timers.
But if I’m reading what you are trying to do incorrectly, try the changes I made above and see if ti helps.
No timing issue, it is just wrong, I tested it and I’m sure. In your example on the top you will never reach the line that cancels the timer.
Can you edit your first post? Because it will miss leading other people.
rule "Group present updated, at least one sensor changed state"
    if(gPresent.state == ON && Present.state != ON) { // someone came home
    } else if(gPresent.state == ON && Present.state == ON) { // someone came home but timer is running
    } else if(gPresent.state == OFF && Present.state != OFF){ // last person left home
Thanks for reading my full reply to your original post.
Sorry, if that last post sounds a bit rude, wasn’t meant that way.
Ok, but it not worked with the original post and it never has, maybe when you changed it for your use.
I already got it, thanks for explaining.
That’s another problem of retriggering, but not the reason for the problem we are talking about.
It’s very “unreadable” therefor for beginnersnot easy to understand, because of the or and the two if statements in the if statement. But could be working this way. Maybe we find together a more readable version of your OP, thats besides was a good idea.
Just the “-” minus is to much.
Oh yes, sorry I skipped this one, but as I said, seems to me to unreadable.
Thanks for your work and your help for the community. :slight_smile:
Have a nice evening!
Greets Udo
Not that it was rude. Just that you ignored the bulk of what I wrote in response. I said that the code was wrong and supplied a version of what I’ve been successfully running with and said I would update the OP. But you only responded to the first line of the post. It was a little annoying.
Typo.
Ahhh, then this was the problem, because for me it was annoying that you sound like you didn’t made an error :wink:
gPresence_Sensors or Presence_Sensors? :roll_eyes:
Typo. I’ve corrected it above. The name should match what is defined in the .items file, no “g”.
