I got a couple of Generic Z-Wave Siren Alarms that physically look like the Zipato AB02Z_PSE02 (without the branding) but OH imported it as an NAS-AB01Z. Regardless it does work fine but it seems to be missing the following config paramaters (for control of the LED light) that both the AB01Z and the AB02Z look like they support (according to the info I found at https://products.z-wavealliance.org/Search/Index?regionId=-1&searchText=AB0 )
<ConfigurationParameterExport>
<Name>Alarm Led Enable</Name>
<Description>This parameter defines the default led enable status when siren is on for ALARM SOUND MODE.
If parameter is set to ‘0’, led will be disable.
If parameter is set t0 ‘1’, led will be enable. When siren is on, the led will blink.</Description>
<ParameterNumber>8</ParameterNumber>
<Size>1</Size>
<DefaultValue>1</DefaultValue>
<pType>0</pType>
<flagReadOnly>false</flagReadOnly>
<flagReInclude>false</flagReInclude>
<flagAdvanced>false</flagAdvanced>
<v3plus>false</v3plus>
<minValue>0</minValue>
<maxValue>0</maxValue>
<ConfigurationParameterValues>
<ConfigurationParameterValueExport>
<From>0</From>
<To>1</To>
<Description>Alarm mode switching</Description>
</ConfigurationParameterValueExport>
</ConfigurationParameterValues>
</ConfigurationParameterExport>
<Name>Door Bell Led Enable</Name>
<Description>This parameter defines the default led enable status when siren is on for DOOR BELL SOUND MODE.
<ParameterNumber>9</ParameterNumber>
<Size>1</Size>
<DefaultValue>0</DefaultValue>
<pType>0</pType>
<From>0</From>
<To>1</To>
<Description>Door Bell Led Enable</Description>
</ConfigurationParameters>
