(German) school holidays for Ephemeris
I was missing a possibility to import German School holidays into Ephemeris.
The calendars are provided by schulferien.org.
But I wanted to have it imported automatically to check for
  • when is the next school holiday
  • is today a school holiday
  • what is the name of the next holiday
I could not find any other tool to import the calendars from schulferien.org so I wrote this little script.
usage: ephemeris.py [-h] [-v] [-i INPATH] [-o OUTFILE]
read school holidays from https://www.schulferien.org/deutschland/ical/
optional arguments:
  -h, --help            show this help message and exit
  -v, --verbose         activate logging
  -i INPATH, --inPath INPATH
                        set path where the ics files are
  -o OUTFILE, --outFile OUTFILE
                        set the out file
Test it, and if you have any comments - feel free.
If you see any other (school) calendars for other contries. Please post the link if they do not work.
Hi Michael,
thank you very much for the script! :slight_smile:
I was able to use it on the school holidays 2021 and 2022 for Baden-Württemberg, Germany.
What I needed to change in the script was the utf8 encoding, maybe the format of the ics files changed from last March?
I put these three lines into the script, after the line ā€œimport osā€:
import sys
reload(sys)
sys.setdefaultencoding('utf8')
No idea if that is the way you do it (I am not a programmer), found this on Google. :wink: But it works now.
Maybe you want to update your repo on Github.
Regards,
Martin
Hello Martin,
thanks a lot. Indeed for BW the content is different than for LowerSaxony - what I am using. That happens when people add special German characters (ü) into files :-).
I updated your change in my repo.
