I have an image item that gets an image from MQTT. I can see the image in the model. I’m trying to get this image data or image file in a rule ECMAScript-2021 script.
var item = item || items.getItem('MQTTEventItem_Image')
console.log(`Image: ${item.state}.`)
// Image: raw type (image/jpeg): 10458 bytes.
It is aware of certain things (mime type, image size), but I can’t figure out how to get them. I’ve tried the getMimeType() and toFullString() as documented here but they result in method not found errors.
How can I get the file or the binary contents so I can script further behavior?
(By the way, btoa() and atob() seem to be unavailable in openhab-js. This will probably be my next problem.)
Reviewing the JS Scripting reference docs shows that Item.state returns a String. You want the Item.rawState to access the original Java State Object. JavaScript Scripting - Automation | openHAB
You may have to import and use the Java Classes to do this.
Can I send this binary data using HTTP.sendHttpPostRequest?
I’m trying to send the image data to Matrix/Synapse. I’m using the following command, and as long as the payload is an ASCII string, the upload itself works fine and the base64 string arrives at the server.
var headers = new Map()
headers.set('Content-Length', String(payload.length))
var result = HTTP.sendHttpPostRequest(apiUrl, mimeType, payload, headers, 3000)
console.log(result)
However, Synapse doesn’t recognize base64 encoded data. It wants binary data. How can I send binary data? I have tried the following:
Sending item.rawState.getBytes() as payload directly, both as is and escape()ed.
Getting the payload from the base64 string as below, sending it both directly and escape()ed:
var dataStr = item.rawState.toFullString().replace('data:image/jpeg;base64,', '')
var Base64 = Java.type('java.util.Base64')
var dec64 = Base64.getDecoder()
var payload = dec64.decode(dataStr)
I used a slightly different set of command line tools, but back when I was saving off images to file, I used executeCommandLine too to convert the Base64 to a binary png file.
