Get item previous state in a rule
I’d like to execute a rule based on the items state before it received the command
here is how i set my rule up
rule "Cinema scene Level selection"
        Item Scene_Cinema received command
        //logInfo("TEST ", "Cinema scene previous state WAS  " + Scene_Cinema.previousState)
        switch(receivedCommand) {
            case 0 : return false                             //no selection
            case 1 : {                                        //Level I
                        sendCommand(D2, DOWN)
            case 2 : {                                        //Level II
                        sendCommand(D0, DOWN)
            case 3 : {                                        //Level III
                        sendCommand(K1, DOWN)
            case 4 : {                                        //Level IV
                        sendCommand(K0, DOWN)
            case 5 :     if (Scene_Cinema.previousState == 1) {
                            sendCommand(D2, UP)
                            postUpdate(Scene_Cinema, 0)
                        else if (Scene_Cinema.previousState == 2) {
                            sendCommand(D0, UP)
                        else if (Scene_Cinema.previousState == 3) {
                            sendCommand(D0, UP)
                            sendCommand(K1, UP)
                        else if (Scene_Cinema.previousState == 4) {
                            sendCommand(D0, UP)
                            sendCommand(K0, UP)
                        else {
                            sendCommand(D0, UP)
                            sendCommand(K0, UP)
end`
What i’d like is to execute a rule in case 5 according to what the previous state of the item was, before the command was issued. However i can’t seem to get the .previousState working.
Can anyone suggest a solution?
Did you setup a persistence service for Scene_Cinema?
Is it the default persistence service? If not, you have to use Scene_Cinema.previousState(false,"mysql") e.g. when mysql is the persistence service. The boolean false instructs the persistence service not to omit identical states.
I’m using rrd4j persistence and it is set to
* : strategy = everyChange, restoreOnStartup
This should cover it right?
Should i change syntax to item.previousState.state
I also tried to add import org.openhab.core.persistence.* at the begining of the rules file
Yes, I should have seen this, .previousState includes the timestamp, so previousState.state would be the state. I’m not sure if it is necessary to cast the state to a DecimalType
if (Scene_Cinema.previousState.state as DecimalType == n)
because the number could be interpreted as a number but not a state.
Anotherquick question:
do i need to:
for the item.previousState.state to work?
l[quote=“Udo_Hartmann, post:4, topic:9368, full:true”]
[/quote]
Could you please give me an example on what you meen by this?
Also what should i import for this to work?
As the states 1, 2, 3 and 4 are digits, it’s possible that the state has to be casted to a numerical value. Simply set n to 1, 2, 3 or 4 in the example above. There should be no need for importing anything. Also, this should work as well:
case 5 : switch(Scene_Cinema.previousState.state as DecimalType) {
    case 1: {
                sendCommand(D2, UP)
    case  2: {
                sendCommand(D0, UP)
    case  3: {
                sendCommand(D0, UP)
                sendCommand(K1, UP)
    case  4: {
                sendCommand(D0, UP)
                sendCommand(K0, UP)
    default: {
                sendCommand(D0, UP)
                sendCommand(K0, UP)
thanks will try and report back :slight_smile:
Unfortunately it’s not working…
item.previousState.state doesn’t return the previous value …
Here is the code (unfortunately i can’t get it to convert to code):
// ###########Cinema
rule “Cinema scene Level selection”
logInfo("TEST ", "Cinema scene previous state WAS " + Scene_Cinema.previousState.state)
//sendCommand(D2, DOWN)
//postUpdate(Scene_Cinema_prev, 1)
logInfo("TEST ", “Cinema scene state now 1”)
//sendCommand(D0, DOWN)
//postUpdate(Scene_Cinema_prev, 2)
logInfo("TEST ", “Cinema scene state now 2”)
//sendCommand(K1, DOWN)
//postUpdate(Scene_Cinema_prev, 3)
logInfo("TEST ", “Cinema scene state now 3”)
//sendCommand(K0, DOWN)
//postUpdate(Scene_Cinema_prev, 4)
logInfo("TEST ", “Cinema scene state now 4”)
case 8 : { //STOP
//sendCommand(D0, STOP)
//sendCommand(K0, STOP)
//postUpdate(Scene_Cinema, Scene_Cinema_prev.state)
postUpdate(Scene_Cinema, Scene_Cinema.previousState.state)
case 9 : //raise shutters- exit Cinema mode
logInfo(“TEST OFF”, "Cinema scene state was "+Scene_Cinema.previousState.state)
switch(Scene_Cinema.previousState.state) {
//switch(Scene_Cinema_prev.state) {
case 1 : {
//sendCommand(D2, UP)
//postUpdate(Scene_Cinema_prev, 0)
//postUpdate(Scene_Cinema, 0)
logInfo("TEST OFF ", "1Cinema scene state "+Scene_Cinema.previousState.state)
case 2 : {
//sendCommand(D0, UP)
logInfo("TEST OFF ", "2Cinema scene state "+Scene_Cinema.previousState.state)
case 3 : {
//sendCommand(K1, UP)
logInfo("TEST OFF ", "3Cinema scene state "+Scene_Cinema.previousState.state)
case 4 : {
//sendCommand(K0, UP)
logInfo("TEST OFF ", "4Cinema scene state "+Scene_Cinema.previousState.state)
default : {
logInfo("TEST OFF ", "0Cinema scene state "+Scene_Cinema.previousState.state)
Here is the log output:
2016-04-04 18:53:55 - Scene_Cinema received command 1
2016-04-04 18:53:55.599 [INFO ] [org.openhab.model.script.TEST ] - Cinema scene previous state WAS  1
2016-04-04 18:53:55.605 [INFO ] [org.openhab.model.script.TEST ] - Cinema scene  state now 1
2016-04-04 18:53:55.625 [INFO ] [openhab.model.script.TEST OFF ] - 1Cinema scene  state 1
2016-04-04 18:53:58 - Scene_Cinema received command 2
2016-04-04 18:53:58.853 [INFO ] [org.openhab.model.script.TEST ] - Cinema scene previous state WAS  2
This should say that it was 1
2016-04-04 18:53:59.060 [INFO ] [org.openhab.model.script.TEST ] - Cinema scene  state now 2
2016-04-04 18:53:59.584 [INFO ] [openhab.model.script.TEST OFF ] - 2Cinema scene  state 2
2016-04-04 18:54:01 - Scene_Cinema received command 9
2016-04-04 18:54:01.414 [INFO ] [org.openhab.model.script.TEST ] - Cinema scene previous state WAS  9
This should say that previous state was 2 not 9
2016-04-04 18:54:01.436 [INFO ] [.openhab.model.script.TEST OFF] - Cinema scene  state was 9
2016-04-04 18:54:01.454 [INFO ] [openhab.model.script.TEST OFF ] - 0Cinema scene  state 9
To post code as code, just use 3 backticks (```) before and after the code (each in a separate line)
You could try to use Scene_Cinema.previousState(true).state to ensure that the previous state is another than the actual state (evil hack :slight_smile: ).
As logInfo writes Strings, you better should use Scene_Cinema.previousState.state.toString as part of the logging.
Still no joy … however now i got a new problem:
2016-04-05 18:53:30 - Scene_Cinema received command 1
2016-04-05 18:53:30.019 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Cinema scene Level selection': rrd4j does not allow querys without a begin date, unless order is descending and a single value is requested
2016-04-05 18:53:32 - Scene_Cinema received command 2
2016-04-05 18:53:32.520 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Cinema scene Level selection': rrd4j does not allow querys without a begin date, unless order is descending and a single value is requested
2016-04-05 18:53:38 - Scene_Cinema received command 9
2016-04-05 18:53:38.385 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Cinema scene Level selection': rrd4j does not allow querys without a begin date, unless order is descending and a single value is requested
Code i used was
        logInfo("TEST ", "Cinema scene previous state WAS  " + Scene_Cinema.previousState(true).state )
                logInfo("TEST ", "Cinema scene  state now 1")
                logInfo("TEST ", "Cinema scene  state now 2")
                logInfo("TEST ", "Cinema scene  state now 3")
                logInfo("TEST ", "Cinema scene  state now 4")
            case 8 : {                                        //STOP
                postUpdate(Scene_Cinema, Scene_Cinema.previousState(true).state)
            case 9 :                                         //dvigni rolete - exit Kino mode .previousState
                logInfo("TEST OFF", "Cinema scene  state was "+Scene_Cinema.previousState(true).state)
                switch(Scene_Cinema.previousState(true).state) {
                    case 1 : {
                        logInfo("TEST OFF ", "1Cinema scene  state "+Scene_Cinema.previousState(true).state)
                    case 2 : {
                        logInfo("TEST OFF ", "2Cinema scene  state "+Scene_Cinema.previousState(true).state)
                    case 3 : {
                        logInfo("TEST OFF ", "3Cinema scene  state "+Scene_Cinema.previousState(true).state)
                    case 4 : {
                        logInfo("TEST OFF ", "4Cinema scene  state "+Scene_Cinema.previousState(true).state)
                    default : {                 //use instead of else statement
                        logInfo("TEST OFF ", "0Cinema scene  state "+Scene_Cinema.previousState(true).state)
After reading about this error it seems that it is mostly a problem with rrd4j when you don’t use strategy every minute
so i added this line in rrd4j.persist file
Scene_Cinema : strategy = everyMinute
as opposed to
any ideas?
(also @Udo_Hartmann thank you very much for your effort so far)
Have you tried previousState (no XXX. in front) ? I believe it refers to the item that triggered rule execution which in your case is what you’re looking for. Works for me.
And possibly a silly question, but do you have rrd4j persistence activated (persistence:default=rrd4j) and configured in openhab.cfg ?
I would recommend using another persistence service e.g. db4o instead of rrd4j. This implies a growing persistence file, though, but just to rule errors out…
With Strategy everyMinute, previousState would deliver the state one minute ago.
If you could trigger your rule by a state change
Item SceneCinema changed
you would have the implicit variable previousState in the rule body available.
Thanks for suggestion but no joy …
Item Scene_Cinema changed with Scene_Cinema.previousState(true).state)
didn’t work…
I even tried with the historic.State(now.minusSeconds(1)).state), however i got some unreliable results so i took another approach at the problem and solved it …
i introduced another item Scene_Cinema_prev whose state i change to reflect the previous state:
            case 8 : {                                        //STOP
                    case 1 : {
                        sendCommand(D2, UP)
                    case 2 : {
                        sendCommand(D0, UP)
                    case 3 : {
                        sendCommand(D0, UP)
                        sendCommand(K1, UP)
                    case 4 : {
                        sendCommand(D0, UP)
                        sendCommand(K0, UP)
                        sendCommand(D0, UP)
                        sendCommand(K0, UP)
Can’ t leave this one alone … :slight_smile:
@thkrebs and @mstormi
Tried your suggestion with the previousState and it works … however now i have a new issue:
When i send command 8 to send a partial stop, i want to return the scene status to previous state, however that puts me in a loop because the rule looks for when Item changed instead of received command and it effectively trigers a rule even when i only update the status of the switch:
 case 8 : {                                        //STOP
                postUpdate(Scene_Cinema, previousState)
log file:
2016-04-10 22:09:33.205 [INFO ] [c.internal.ModelRepositoryImpl] - Refreshing model 'scene_events.rules'
"send command 2"
2016-04-10 22:09:42.598 [INFO ] [org.openhab.model.script.TEST ] - Cinema scene previous state WAS:  1
2016-04-10 22:09:43.056 [INFO ] [org.openhab.model.script.TEST ] - Cinema scene  state now 2
"send command 8"
2016-04-10 22:09:52.709 [INFO ] [org.openhab.model.script.TEST ] - Cinema scene previous state WAS:  2
"rule executes and completes with "postUpdate(Scene_Cinema, previousState)""
"rule is triggered by "postUpdate(Scene_Cinema, previousState)" and entire case 2 is executed "
2016-04-10 22:09:53.482 [INFO ] [org.openhab.model.script.TEST ] - Cinema scene previous state WAS:  8
2016-04-10 22:09:53.491 [INFO ] [org.openhab.model.script.TEST ] - Cinema scene  state now 2
but this is unwanted.
Any ideas?
The entire code:
        logInfo("TEST ", "Cinema scene previous state WAS:  " + previousState )
        switch(Scene_Cinema.state) {
            case 8 : {                                        //STOP
                //logInfo("TEST OFF", "Cinema scene  state was "+Scene_Cinema.previousState(true).state)
                switch(previousState) {
                    case 1 : {
                        logInfo("TEST OFF ", "1Cinema scene  state: "+ previousState)
                    case 2 : {
                        logInfo("TEST OFF ", "2Cinema scene  state: "+ previousState)
                    case 3 : {
                        logInfo("TEST OFF ", "3Cinema scene  state: "+ previousState)
                    case 4 : {
                        logInfo("TEST OFF ", "4Cinema scene  state: "+ previousState)
                        logInfo("TEST OFF ", "0Cinema scene  state: ")
You can add “from XXX” and/or “to YYY” after “changed”. Should help breaking the loop.
Does it also work with not from so that i could only exclude state 8?
Perhaps a simple if (previousState == 8) return false?
Not sure about ‘not’ in condition line (check the Wiki ‘rules’ pages), but yes, you can use previousState as a variable, so that should work, too.
Solved:
// ###########Cinema v2
                //logInfo("TEST ", "sendCommand(D2, DOWN)"
            case 8 : {                                        //STOP
            case 9 :                                         //exit Cinema mode
                    case 1 : {
                        sendCommand(D2, UP)
                    case 2 : {
                        sendCommand(D0, UP)
                    case 3 : {
                        sendCommand(D0, UP)
                        sendCommand(K1, UP)
                    case 4 : {
                        sendCommand(D0, UP)
                        sendCommand(K0, UP)
                        sendCommand(D0, UP)
                        sendCommand(K0, UP)
Thank you all!
