HAve a tight space so wnat to monitor the temperature of the orange pi zero board
Have installed exec binding throught the paper UI
Added the following to items
Number System_Temperature_CPU "Temperature CPU [%.1f C]" <temperature> (System_Temperature_Chart) { exec="<[cat /sys/class/thermal/thermal_zone0/temp:10000:REGEX((.*?))]"
And get nothing. This is the output from shell
66
maybe a permissions issue, so what’s the output of
ls -l /sys/class/thermal/thermal_zone0/temp
and
groups openhab
Might be. Thanks. Changed to 777 but that didn’t fix it
-r--r--r-- 1 root root
and
openhab : openhab tty dialout
hmm… Maybe you have to use the complete path for cat (i.e. /bin/cat
instead of cat
Nope. Nothing works. HAd to uninstall exec binding 2 and install the legacy version and everything started to work
Number System_Temperature_CPU "Temperature CPU [%.1f C]" <temperature> (System_Temperature_Chart) { exec="<[/bin/cat /sys/class/thermal/thermal_zone0/temp:10000:REGEX((.*?))]" }
Running manually all fine
# /bin/cat /sys/class/thermal/thermal_zone0/temp
61
