The following fails if the binding is added from the inbox after it was discovered from a static initialization block:
InputStream stream = Thread.currentThread().getContextClassLoader().getResourceAsStream("msg_definitions.xml");
If I shut down OH and start it again. It works as expected. Doing some investigation with the following code:
for (ClassLoader c = Thread.currentThread().getContextClassLoader(); c != null; c = c.getParent()) {
logger.info("{} {}", c.getClass().getName(), c.getResource("msg_definitions.xml"));
It returns the following when added from the inbox:
org.ops4j.pax.web.service.spi.util.ResourceDelegatingBundleClassLoader null
org.ops4j.pax.swissbox.core.BundleClassLoader null
And it returns the following when OH is stopped and restarted:
org.eclipse.osgi.internal.framework.ContextFinder bundleresource://235.fwk11729952/msg_definitions.xml
sun.misc.Launcher$AppClassLoader null
sun.misc.Launcher$ExtClassLoader null
I’ve tried multiple ways to get the class loader such as:
Object.class.getClassLoader().getResourceAsStream("msg_definitions.xml");
new Object().getClass().getClassLoader().getResourceAsStream("msg_definitions.xml");
And I got the same results.
