Getting daily error overview
You probably haven’t updated the widget yet. I added this part later than I posted the original widget.
Explanation for the two different approaches of Holger’s and mine solution:
Holger is opening the popup (containg the log details) by a command action and is submitting log details for the log entry you clicked on by a actionModalConfig: parameter. This works perfectly if you have the log list on a page and the log details in a popup widget.
The solution I posted is aimed at a different structure. This works for an oh-card or oh-cell where the log list is shown on an expanded card and the log details are shown on a popup widget. In this structure (popup on top of an expanded card) if you close the popup the expanded card will be closed, too and a refresh of the underlying page will happen. That’s why it is important to open the popup by popupOpen: =.open-popup-logdetails because only then you are able to close just the popup by popupClose: =.open-popup-logdetails
I’m having trouble seeing how this all fits into the page itself… Would you mind sharing the complete yaml of your page?
Thanks!
The complete yaml of my page will definitely be too complex :slight_smile:
At least I have removed to other cells. But the section for our logging solution is just one out of several functions the cell provides to me…
Here we go:
  hideNavbar: true
  hideSidebarIcon: false
  icon: f7:house
  label: Home
  layoutType: responsive
  order: "1"
  showFullscreenIcon: false
  sidebar: true
  style:
    --f7-block-padding-horizontal: 8px
    --f7-button-text-transform: none
    --f7-list-item-footer-font-size: 16px
    --f7-list-item-header-font-size: 18px
    --f7-list-item-title-font-size: 24px
    --f7-navbar-height: 0px
  stylesheet: |
    .block:first-child {
      margin-top: 6px;
      margin-bottom: 0px;
    .block-title {
      margin-bottom: 0px;
    .-expanded-card-block {
      position: absolute;
      top: 0px;
      left: 0px;
      overflow-x: hidden;
      margin: 0px;
      width: 100%;
      z-index: -1;
    .-expanded-card-title {
      font-size: 24px;
      font-weight: 500;
      color: black;
      text-align: center;
    .-expanded-card-actionbutton {
      display: flex;
      align-items: start;
      flex-direction: column;
      justify-content: center;
      --f7-button-hover-bg-color: rgba(150,150,150,0.5);
      --f7-button-bg-color: white;
      --f7-button-pressed-bg-color: rgba(150,150,150,1.0);
      --f7-button-text-transform: none;
      border-radius: var(--f7-card-expandable-border-radius);
      box-shadow: 0px 5px 10px rgba(0,0,0,0.15);
      color: black;
      font-size: 20px;
      font-weight: 300;
      height: 70px;
      margin-top: 20px;
      padding-left: 20px;
      white-space: normal;
      width: 250px;
    .-list {
      --f7-list-group-title-height: 38px;
      --f7-list-group-title-bg-color: rgb(242,242,247);
      --f7-list-group-title-font-size: 12px;
      --f7-list-group-title-text-color: gray;
      --f7-list-item-title-font-size: 16px !important;
      --f7-list-item-title-line-height: 18px;
      --f7-list-item-subtitle-font-size: 12px !important;
      --f7-list-item-subtitle-font-weight: 100 !important;
      --f7-list-item-subtitle-line-height: 12px;
      --f7-list-media-item-title-font-weight: 400 !important;
      --f7-list-inset-border-radius: 8px !important;
      --f7-toggle-active-color: rgb(58,200,96);
    .-list-title {
      font-size: 12px;
      color: gray;
      text-align: left;
      margin: 15px 0px 5px 17px;
    .-list-titleblock {
      padding: 0;
      display: flex;
      flex-direction: row;
      align-items: end;
      font-size: 12px;
      color: gray;
      text-align: left;
    .-list-item-title {
      font-size: 14px;
      margin-left: 7px;
      white-space: nowrap;
    .header-icon {
      font-size: 35px !important;
      width: 40px !important;
      height: 40px !important;
    .button-header {
      line-height: 40px !important;
      padding: 0px !important;
      font-weight: normal;
    .cell-expanded-header {
      margin: 20px !important;
      padding: 0px;
    .card-opening .cell-contents, .card-opened .cell-contents {
      background-color: rgb(242,242,247);
blocks:
  - component: oh-block
    config: {}
    slots:
      default:
        - component: oh-grid-cells
            cols:
              "719": 2
              default: 5
          slots:
            default:
              - component: oh-cell
                  color: black
                  expandable: true
                  header: System
                  icon: f7:gear_alt
                  on: true
                  stylesheet: |
                    .item-header {
                      --f7-list-item-header-text-color: white;
                      --f7-list-item-header-font-size: 14px;
                slots:
                  background:
                    - component: f7-block
                        class: card-opened-fade-out
                        style:
                          background-color: gray
                          color: white
                          display: flex
                          height: 120px
                          justify-content: flex-end
                          margin: 0
                          padding-right: 16px
                          padding-top: 64px
                      slots:
                        default:
                          - component: f7-chip
                              bgColor: red
                              style:
                                color: black
                              text: =@'vAlarmCount'
                              visible: =(@'vAlarmCount' != '0')
                              bgColor: yellow
                              style:
                                color: black
                                justify-content: end
                                margin-left: 2px
                                ustify-itmes: right
                              text: =@'gFaults'
                              visible: =(@'gFaults' != '0')
                              bgColor: green
                              style:
                                color: black
                                margin-left: 2px
                              text: =@'gInfo'
                              visible: =(@'gInfo' != '0')
                              bgColor: blue
                              style:
                                color: black
                                margin-left: 2px
                              text: =@'vLogCount'
                              visible: =(@'vLogCount' != '0')
                  default:
                    - component: widget:expanded-card-status
                      config: {}
Maybe you could try my adaptation ( Getting daily error overview - #36 by HolBaum5 ) of the page and the popup based on what Oliver2 did. The rules and entry in log4j2.xml are still needed, of course.
I did that, but removed one (or two, I assume?) layer(s):
  label: Display Errors
  sidebar: true
blocks:
    config: {}
    slots:
      default:
        - component: oh-grid-row
          config: {}
          slots:
            default:
              - component: oh-grid-col
                config: {}
                slots:
                  default:
                    - component: f7-list
                        bg-color: white
                        class: -list
                        inset: true
                        mediaList: true
                        noHairlinesBetween: false
                      slots:
                        default:
                          - component: oh-repeater
                              for: rLog
                              fragment: true
                              in: =JSON.parse(@@'vLog')
                              sourceType: array
                            slots:
                              default:
                                - component: oh-list-item
                                    action: popup
                                    actionModal: widget:Widget_Logdetails_Popup
                                    actionModalConfig:
                                      logDetails: =loop.rLog_source[loop.rLog_idx]
                                    badge: =loop.rLog.level
                                    badgeColor: =(loop.rLog.level == "WARN")?"yellow":"red"
                                    subtitle: =loop.rLog.timestamp + ", " + loop.rLog.threadName
                                    title: =loop.rLog.message
masonry: []
grid: []
canvas: []
