I need some more help.
How can I get information about the parent equipment of a triggering item in a javascript/blockly rule?
Most of my items are organised hierarchically in the openhab model.
So for example i have:
house
room1
contact equipment1
actually triggering state item
room2
contact equipment2
state item
Both items are aggregated into another group, e. g. “gContactSensors”
Now the rule is being triggered by group “gContactSensors” member item changed state.
In my rule I now need information in which room the triggering item is located.
How do I achieve this using information from the model?
Can I use this syntax for expressions on ui pages too? - No I tried it, it didn’t work.
Or how can I achieve it on ui pages?
For example, I have a list of battery items which are displayed on an ui page. Now I want to show the location and the equipment the items belong to on the same page, how would I do this?
I’m sure you can’t use the same syntax in UI. On MainUI Page the syntax si different.
But I don’t know how exactly this could be done in UI.
I have done similar case with batteries in UI without semantic model, just using List card and adding manually the Label list items with custom title for each battery item.
