I have two ecobee 3 thermostats, one for upstairs and one down. What do I need to change / add in order for me to be able to use both thermostats. I am a little new to openhab, love what I see so far but just need a nudge in the right direction.
If you have registered all thermostats under the same account at ecobee.com, all you need are the thermostat IDs as described in the wiki page to supply to the binding strings in your items file. The binding figures out what API calls to make based on your item bindings.
If instead your thermostats are registered under different accounts at ecobee.com, you need to set up two instances as described in the wiki. Let me know if this isn’t enough to go on.
Thanks… so in the ecobee.items file I just need to copy everything and change the ID’s? I thought I do this but things weren’t working right. I don’t need to do anything to any of the other files? What would distinguish one thermostat’s info from the other in the sitemap file?
I understand now – you were asking about what to name the items, like “hvacMode” and “hvacMode1” item names. You can name them anything, ideally keeping it to letters and numbers and the underscore _ character. In your case you could name items like MainDesiredTemp, BedroomDesiredTemp, MainActualTemperature, etc. It’s totally up to you, but the items are defined in files with names ending in “.items” and then those individual items are referenced by their names in your “.sitemap” files. Take a look at your “.items” file and make sure you have defined a “lastModified1” item correctly, as the possible explanation of why it’s not showing properly on the sitemap.
