Absolute beginner: I am trying to get a minimal configuration of OpenHAB 1.8.3 talking to an HAI Omnilink system. I can run OpenHab and I have one item (a dimmer switch) defined in the .items file but how can I test it? Is there a CLI command? I tried using the generateitems feature of the omnilink binding but it fails with:
2016-11-27 21:50:26.142 [INFO ] [o.b.o.internal.OmniLinkBinding] - System: SystemStatus ( timeDateValid = true year = 16 month = 11 day = 27 dayOfWeek = 7 hour = 21 minute = 49 second = 27 daylightSavings = false sunriseHour = 6 sunriseMinute = 54 sunsetHour = 16 sunsetMinute = 33 batteryReading = 230 alarms = {} )
2016-11-27 21:50:26.386 [ERROR] [o.b.o.internal.OmniLinkBinding] - Could not connect to system
at org.openhab.binding.omnilink.internal.ui.OmnilinkItemGenerator.generateUnits(OmnilinkItemGenerator.java:250) ~[na:na]
at org.openhab.binding.omnilink.internal.ui.OmnilinkItemGenerator.generateItemsAndGroups(OmnilinkItemGenerator.java:159) ~[na:na]
at org.openhab.binding.omnilink.internal.OmniLinkBinding$OmniConnectionThread.run(OmniLinkBinding.java:412) ~[na:na]
2016-11-27 21:50:26.388 [ERROR] [o.b.o.internal.OmniLinkBinding] - OmniConnectionThread was disconnected, will try again
