Need to add [%s] to item for string. I use item files but I think you can do this via PaperUI or REST?
Closest example I have at the moment. You would use the [%s] in your item where [%.1f °F] is in example.
Number LivingRoom_Light_Temp "Temperature [%.1f °F]" <temp> { channel="mqtt:topic:pibroker:sonoff11:temperature" }
EDIT: In PaperUI > Configuration > Things > select your things then click the pencil icon to edit the channel. Next click show more at bottom left and you will see options to add the %s in appropriate spot.
Are you on OH version 2.4? If so and you made a change to the mqtt files then a restart of OH is needed sudo systemctl restart openhab2 This should get your broker back online and note that each time a mqtt file change is made a restart will be needed.
This bug has been fixed in later versions.
You have duplicate stateTopics so if this causes an issue change the String part “stat” to “tele”.
Type switch : Bathroom_Boiler_Relay [ stateTopic="stat/tasmota-switch/POWER"
Type String : Bathroom_Boiler_Status [ stateTopic="stat/tasmota-switch/POWER" ]
like this:
Type String : Bathroom_Boiler_Status [ stateTopic="tele/tasmota-switch/POWER" ]
2019-11-24 17:32:32.311 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2019-11-24 17:32:32.367 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2019-11-24 17:32:32.380 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Stopped Home Builder
2019-11-24 17:32:32.422 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2019-11-24 17:32:51.095 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2019-11-24 17:32:51.191 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2019-11-24 17:33:01.633 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.items'
2019-11-24 17:33:10.379 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.rules'
2019-11-24 17:33:10.799 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-11-24 17:33:11.557 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.sitemap'
2019-11-24 17:33:12.077 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'default.things' has errors, therefore ignoring it: [6,14]: mismatched input 'String' expecting RULE_ID
2019-11-24 17:33:12.232 [.ItemChannelLinkAddedEvent] - Link 'Bathroom_Tasmota_Relay-mqtt:topic:Bathroom_Boiler_Control:Bathroom_Boiler_Relay' has been added.
2019-11-24 17:33:12.240 [.ItemChannelLinkAddedEvent] - Link 'Bathroom_Tasmota_Status-mqtt:topic:Bathroom_Boiler_Control:Bathroom_Relay_Status' has been added.
2019-11-24 17:33:12.264 [.ItemChannelLinkAddedEvent] - Link 'network_servicedevice_0e1b06e8_latency-network:servicedevice:0e1b06e8:latency' has been added.
2019-11-24 17:33:12.269 [.ItemChannelLinkAddedEvent] - Link 'network_servicedevice_0e1b06e8_online-network:servicedevice:0e1b06e8:online' has been added.
2019-11-24 17:33:12.275 [.ItemChannelLinkAddedEvent] - Link 'mqtt_topic_Bathroom_Boiler_Control_Bathroom_Boiler_Relay-mqtt:topic:Bathroom_Boiler_Control:Bathroom_Boiler_Relay' has been added.
2019-11-24 17:33:12.286 [.ItemChannelLinkAddedEvent] - Link 'Sonoff_SonoffRelayCommand-mqtt:topic:34a42238:Sonoff_Relay_Command' has been added.
2019-11-24 17:33:12.291 [.ItemChannelLinkAddedEvent] - Link 'network_servicedevice_0e1b06e8_lastseen-network:servicedevice:0e1b06e8:lastseen' has been added.
2019-11-24 17:33:12.654 [hingStatusInfoChangedEvent] - 'network:servicedevice:0e1b06e8' changed from UNINITIALIZED to INITIALIZING
2019-11-24 17:33:12.737 [hingStatusInfoChangedEvent] - 'network:servicedevice:0e1b06e8' changed from INITIALIZING to ONLINE
2019-11-24 17:33:13.805 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.178.39:8080
2019-11-24 17:33:13.809 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.178.39:8443
2019-11-24 17:33:14.408 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2019-11-24 17:33:14.570 [vent.ItemStateChangedEvent] - network_servicedevice_0e1b06e8_lastseen changed from NULL to UNDEF
2019-11-24 17:33:15.622 [vent.ItemStateChangedEvent] - Livingroom_Woodfire_Relay changed from NULL to OFF
2019-11-24 17:33:15.915 [vent.ItemStateChangedEvent] - network_servicedevice_0e1b06e8_online changed from NULL to OFF
2019-11-24 17:33:15.934 [vent.ItemStateChangedEvent] - network_servicedevice_0e1b06e8_latency changed from NULL to -1.0
2019-11-24 17:33:15.941 [vent.ItemStateChangedEvent] - network_servicedevice_0e1b06e8_latency changed from -1.0 to UNDEF
2019-11-24 17:33:16.752 [ERROR] [ipse.smarthome.io.mqttembeddedbroker] - bundle org.eclipse.smarthome.io.mqttembeddedbroker:0.10.0.oh240 (211)[org.eclipse.smarthome.io.mqttembeddedbroker.internal.EmbeddedBrokerServiceImpl(223)] : The activate method has thrown an exception
java.net.BindException: Address already in use
at sun.nio.ch.Net.bind0(Native Method) ~[?:?]
at sun.nio.ch.Net.bind(Net.java:433) ~[?:?]
at sun.nio.ch.Net.bind(Net.java:425) ~[?:?]
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223) ~[?:?]
at io.netty.channel.socket.nio.NioServerSocketChannel.doBind(NioServerSocketChannel.java:128) ~[?:?]
at io.netty.channel.AbstractChannel$AbstractUnsafe.bind(AbstractChannel.java:558) ~[?:?]
at io.netty.channel.DefaultChannelPipeline$HeadContext.bind(DefaultChannelPipeline.java:1283) ~[?:?]
at io.netty.channel.AbstractChannelHandlerContext.invokeBind(AbstractChannelHandlerContext.java:501) ~[?:?]
at io.netty.channel.AbstractChannelHandlerContext.bind(AbstractChannelHandlerContext.java:486) ~[?:?]
at io.netty.channel.DefaultChannelPipeline.bind(DefaultChannelPipeline.java:989) ~[?:?]
at io.netty.channel.AbstractChannel.bind(AbstractChannel.java:254) ~[?:?]
at io.netty.bootstrap.AbstractBootstrap$2.run(AbstractBootstrap.java:364) ~[?:?]
at io.netty.util.concurrent.AbstractEventExecutor.safeExecute(AbstractEventExecutor.java:163) ~[?:?]
at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:404) ~[?:?]
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:463) ~[?:?]
at io.netty.util.concurrent.SingleThreadEventExecutor$5.run(SingleThreadEventExecutor.java:886) ~[?:?]
at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) ~[?:?]
at java.lang.Thread.run(Thread.java:748) ~[?:?]
2019-11-24 17:33:16.853 [WARN ] [ipse.smarthome.io.mqttembeddedbroker] - FrameworkEvent WARNING - org.eclipse.smarthome.io.mqttembeddedbroker
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) ~[?:?]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:891) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:877) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:944) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:727) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:661) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:427) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) ~[?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2019-11-24 17:33:16.870 [ERROR] [ipse.smarthome.io.mqttembeddedbroker] - bundle org.eclipse.smarthome.io.mqttembeddedbroker:0.10.0.oh240 (211)[org.eclipse.smarthome.io.mqttembeddedbroker.internal.EmbeddedBrokerServiceImpl(223)] : The activate method has thrown an exception
