I’m trying to get the Yeelight binding to work with Openhab and a Nginx reverse proxy in separate Docker containers. Is this possible as the Yeelight bulbs and the Docker containers reside in different subnets?
I’m not using the ‘network_mode: host’ as that will overrule (not sure about this) the reverse proxy. The reason for using the reverse proxy is because I’m using wborn’s embedded Grafana panel implementation (I removed the Grafana part from the compose and Nginx file for convenience)
The Yeelight things go offline after initializing and stay offline as shown in the event log:
2019-09-02 19:34:54.681 [.ItemChannelLinkAddedEvent] - Link 'light_bulb_10_sw-yeelight:wonder:light_bulb_10:color' has been added.
2019-09-02 19:43:01.609 [hingStatusInfoChangedEvent] - 'yeelight:wonder:light_bulb_10' changed from UNINITIALIZED to INITIALIZING
2019-09-02 19:43:01.637 [hingStatusInfoChangedEvent] - 'yeelight:wonder:light_bulb_10' changed from INITIALIZING to OFFLINE: Device is offline!
The documentation describes that UPnP is needed for discovery, so I exposed port 1900 in the Docker compose file.
NMAP shows that port 1900 is up:
Host is up.
PORT STATE SERVICE
1900/tcp filtered upnp
Docker-compose file:
version: '2'
services:
reverseproxy:
image: reverseproxy
ports:
- 5001:5001
restart: always
openhab:
depends_on:
- reverseproxy
image: "openhab/openhab:2.4.0"
restart: always
ports:
- "8080:8080"
- "8443:8443"
- "1900:1900" #UPNP
volumes:
- "/etc/localtime:/etc/localtime:ro"
- "/etc/timezone:/etc/timezone:ro"
- "/opt/openhab/addons:/openhab/addons"
- "/opt/openhab/conf:/openhab/conf"
- "/opt/openhab/userdata:/openhab/userdata"
environment:
OPENHAB_HTTP_PORT: "8080"
OPENHAB_HTTPS_PORT: "8443"
EXTRA_JAVA_OPTS: "-Duser.timezone=Europe/Berlin"
USER_ID: "999"
GROUP_ID: "999"
Nginx configuration:
worker_processes 1;
events { worker_connections 1024; }
http {
sendfile on;
upstream docker-openhab {
server openhab:8080;
server {
listen 5001;
server_name localhost;
location / {
proxy_pass http://docker-openhab;
proxy_buffering off;
proxy_set_header Host $http_host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
