- Platform information:
- Hardware: CPUArchitecture/RAM/storage
- OS: what OS is used and which version
- Java Runtime Environment: which java platform is used and what version
- openHAB version:
- Issue of the topic: please be detailed explaining your issue
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
I am running openhabian
And doing configuration of global cache ITach IR
But the I face the following issue
2020-10-16 18:50:36.746 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: org.eclipse.jetty.io.EofException
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) ~[bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [bundleFile:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [bundleFile:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [bundleFile:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [bundleFile:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [bundleFile:?]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [bundleFile:?]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [bundleFile:?]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [bundleFile:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_265]
Caused by: org.eclipse.jetty.io.EofException
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:283) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:422) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:277) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:381) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:812) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:223) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:549) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:852) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:929) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:250) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:226) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:551) ~[bundleFile:9.4.20.v20190813]
at java.io.OutputStream.write(OutputStream.java:75) ~[?:1.8.0_265]
at org.glassfish.jersey.servlet.internal.ResponseWriter$NonCloseableOutputStreamWrapper.write(ResponseWriter.java:320) ~[?:?]
at org.glassfish.jersey.message.internal.CommittingOutputStream.write(CommittingOutputStream.java:218) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$UnCloseableOutputStream.write(WriterInterceptorExecutor.java:294) ~[bundleFile:?]
at org.eclipse.smarthome.io.rest.core.internal.GsonProvider.writeTo(GsonProvider.java:71) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.invokeWriteTo(WriterInterceptorExecutor.java:265) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.aroundWriteTo(WriterInterceptorExecutor.java:250) ~[bundleFile:?]
at org.glassfish.jersey.server.internal.JsonWithPaddingInterceptor.aroundWriteTo(JsonWithPaddingInterceptor.java:106) ~[?:?]
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:86) ~[?:?]
... 53 more
Caused by: java.io.IOException: Broken pipe
at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:1.8.0_265]
at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:1.8.0_265]
at sun.nio.ch.IOUtil.write(IOUtil.java:148) ~[?:1.8.0_265]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:501) ~[?:1.8.0_265]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:263) ~[bundleFile:9.4.20.v20190813]
... 53 more
2020-10-16 18:50:39.320 [ERROR] [.GlobalCacheHandler$CommandProcessor] - Comm error for thing itachIR:6dfd3a64 at 192.168.1.167: Connection reset
2020-10-16 18:50:39.326 [hingStatusInfoChangedEvent] - ‘globalcache:itachIR:6dfd3a64’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): ERROR: Connection reset
2020-10-16 18:51:39.330 [INFO ] [GlobalCacheHandler$ConnectionManager] - Got a connection to command port for thing itachIR:6dfd3a64 at 192.168.1.167
2020-10-16 18:51:39.337 [hingStatusInfoChangedEvent] - ‘globalcache:itachIR:6dfd3a64’ changed from OFFLINE (COMMUNICATION_ERROR): ERROR: Connection reset to ONLINE
2020-10-16 18:52:39.341 [ERROR] [.GlobalCacheHandler$CommandProcessor] - Comm error for thing itachIR:6dfd3a64 at 192.168.1.167: Connection reset
2020-10-16 18:52:39.346 [hingStatusInfoChangedEvent] - ‘globalcache:itachIR:6dfd3a64’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): ERROR: Connection reset
