I can’t reproduce it on demand, but every few days the “items” global scope disappears. I can still access items and all their properties through ir.getItems()
, though.
So, for example, after days of running just fine:
mode_metadata = get_key_value(item_name, "area_triggers_and_actions", items.mode)
…results in:
2020-10-20 07:00:59.659 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 'f5f36e86-db67-407b-837b-ca45af66fa2e': Fail to execute action: 1
2020-10-20 07:01:18.791 [INFO ] [ort.shared.ScriptedAutomationManager] - removeAll added handlers
2020-10-20 07:01:18.933 [INFO ] [me.core.service.AbstractWatchService] - Loading script 'python/personal/area_mt_logic.py'
2020-10-20 07:01:23.336 [ERROR] [jsr223.jython ] - Traceback (most recent call last):
File "/etc/openhab2/automation/lib/python/core/log.py", line 51, in wrapper
return fn(*args, **kwargs)
File "<script>", line 68, in light_action
NameError: global name 'mode' is not defined
If I replace items.mode
with ir.getItem('mode').state
and simply reload the rule, everything works fine again.
Life is great if I just replace all my items.
references, but I’d still like to understand the problem. I’m not sure how to further troubleshoot the issue, however.
Some environment information:
- Openhabian, OH 2.5.9-1
- openjdk version “1.8.0_265”
- OpenJDK Runtime Environment (Zulu 8.48.3.246-CA-linux_aarch32hf) (build 1.8.0_265-b11)
- OpenJDK Client VM (Zulu 8.48.3.246-CA-linux_aarch32hf) (build 25.265-b11, mixed mode)
- jython-standalone-2.7.0.jar
