Go-e binding errors after upgrade to OH 5.1
I just upgraded my OH from 32-bit 4.39 to 64-bit 5.1.0. Almost everything worked seamlessly, but the go-e addon throws a lot of errors which I’m not able to understand:
2025-12-26 20:56:59.427 [WARN ] [ternal.handler.GoEChargerBaseHandler] - Error fetching GoE data: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 1 column 1 path $
See https://github.com/google/gson/blob/main/Troubleshooting.md#unexpected-json-structure
com.google.gson.JsonSyntaxException: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 1 column 1 path $
        at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:523) ~[?:?]
        at com.google.gson.Gson.fromJson(Gson.java:1359) ~[?:?]
        at com.google.gson.Gson.fromJson(Gson.java:1260) ~[?:?]
        at com.google.gson.Gson.fromJson(Gson.java:1170) ~[?:?]
        at com.google.gson.Gson.fromJson(Gson.java:1107) ~[?:?]
        at org.openhab.binding.goecharger.internal.handler.GoEChargerHandler.getGoEData(GoEChargerHandler.java:383) ~[?:?]
        at org.openhab.binding.goecharger.internal.handler.GoEChargerBaseHandler.refresh(GoEChargerBaseHandler.java:129) ~[?:?]
        at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) ~[?:?]
        at java.util.concurrent.FutureTask.runAndReset(Unknown Source) ~[?:?]
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source) ~[?:?]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) ~[?:?]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) ~[?:?]
        at java.lang.Thread.run(Unknown Source) [?:?]
Caused by: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 1 column 1 path $
        at com.google.gson.stream.JsonReader.unexpectedTokenError(JsonReader.java:1831) ~[?:?]
        at com.google.gson.stream.JsonReader.beginObject(JsonReader.java:509) ~[?:?]
        at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:512) ~[?:?]
        ... 12 more
2
Actually I have 2 “11KW Homefix” wallboxes installed. Both are running without problems, both with their latest firmware and with OH 4.3 everything was ok.
Thanks for any hints,
Soeren
any update/fix? i have a similar problem.
