Newbie here love the openHAB app and getting along quite well after I got my Zwave controller going.
I have the above thermostat and have the Things and Items setup and visible but cannot change any settings. Basically want to set the cooling/heat temps and turn it on and off. If there is a good tutorial on this please post a link…looked around but don’t see how to bring it all together.
Two issues:
What do I need to change to display a data entry field and send the set temps? Guessing this is something in the Items setting… In the sitemap I used “Default item=HVAC_HeatSetPoint label=“Heat Set Temp””.
For the on/off switch I’m getting the below openhab.log message. Not sure what that value needs to be and how to change it. Guessing it needs a “0” sent back.
2018-02-01 07:54:47.778 [WARN ] [rest.core.internal.item.ItemResource] - Received
HTTP POST request at 'items/HVAC_Mode' with an invalid status value 'OFF'.
