Good Weather widget with external URL for BasicUI webview?
Hey that’s a cool idea
You can use darksky widgets if you want you just need to create your own static webpage.
ok
In the HTML folder in openhab create a file
weather.html
<html>
<script type='text/javascript' src='https://darksky.net/widget/default/42.360082,-71.05888/us12/en.js?height=500&title=Full Forecast&textColor=333333&bgColor=FFFFFF&skyColor=333&fontFamily=Default&units=us&htColor=333333&ltColor=C7C7C7&displaySum=yes&displayHeader=yes'></script>
</html>
You can use your own script you configure on dark sky
Then in your sitemap
Webview url="http://openhabianpi:8080/static/weather.html"
I use openhabian on pi but you can put your ip in.
I use OpenWeatherMap binding for my weather info.
