Hello!
I have several items with the tag [ “CurrentTemperature”]. These are mysensors.org temperature sensors.
When i said “OK Google, whats the temperature in the living room?” (German “OK Google, wie hoch ist die Temperatur im Wohnzimmer?”), Google answered “The current temperature in the living room is 22 degrees” (German “Die aktuelle Temperatur im Wohnzimmer beträgt 22 Grad”).
I didnt change anything, but maybe Google assistant was updated.
When i now ask the question the answer of Google is “the living room thermostat is set to heating” (German “Das Thermostat Wohnzimmer ist auf Heizen gestellt”).
Is this a OH or google assistant issue?
Anybody esle having this problem?
Any solution?
Thanks for your help
