Google Assistant metadata values not working!
Linux
Openhab 2.5.9
I now use [“Lighting”] to expose my light to Google Assistant
According to Google Assistant | openHAB I can use { ga=“Light” }
When I use { ga=“Light” } I get error in my item file
Item:
Working:
Switch E1Lstaande2_Switch          "Staande lamp 2"           <switch>        (gHuiskamer,gLampen,ALLE,gLampenHuiskamer,gALLOFF)["Lighting"] {channel="zwave:device:c3d4c8dc:node4:switch_binary"}
Not working:
Switch E1Lstaande2_Switch "Staande lamp 2" <switch>     (gHuiskamer,gLampen,ALLE,gLampenHuiskamer,gALLOFF){ ga="Light" }  {channel="zwave:device:c3d4c8dc:node4:switch_binary"}
Openhab.log
2020-10-03 20:19:11.955 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'lights.items' has errors, therefore ignoring it: [6,145]: missing EOF at '{'
Is the Google Assistant functionality in Openhab a module / binding /action or part of the core ?
Is it possible that I have an old version of the Google Assistant functionality and can I update it???
The metadata goes with the channel.
{channel="zwave:device:c3d4c8dc:node4:switch_binary",  ga="Light"}
Thank you Russ,
This is working
