Google assitant camera stream - home app
Trying to see a camera stream in google home app. I see black screen only and ffmpeg is not starting.
my assumptions were : stream must be compatible with google based on this GitHub - gihad/streamer: Converting Streams into HLS for playback on Chromecast devices using FFMPEG + NGINX
my config:
ip camera binding with pure rstp stream:
FFmepg command:
ffmpeg -i rtsp:/…:____@192.168.5.222:554/Streaming/Channels/101 -acodec aac -vcodec copy -hls_list_size 2 -hls_init_time 1 -hls_time 1 -hls_flags delete_segments
i can play this stream in VLC, but the home app is not starting the ffmpeg
  • id: hlsUrl channel mapped to an item string ga=camera
UID: ipcamera:generic:449425871d
label: RTSP/HTTP IP Camera
thingTypeUID: ipcamera:generic
configuration:
  mjpegOptions: -q:v 5 -r 2 -vf scale=640:-2 -update 1
  ipAddress: 192.168.5.222
  updateImageWhen: "0"
  gifPreroll: 0
  ffmpegLocation: /usr/bin/ffmpeg
  ipWhitelist: DISABLE
  mp4OutOptions: -c:v copy -c:a copy
  pollTime: 1000
  password: $$$$$$$
  port: 80
  snapshotUrl: http://192.168.5.222/ISAPI/Streaming/channels/2/picture
  snapshotOptions: -an -vsync vfr -q:v 2 -update 1
  username: xxxxxx
  ffmpegInput: rtsp://192.168.5.222:554/Streaming/Channels/102
  hlsOutOptions: -strict -2 -f lavfi -i aevalsrc=0 -acodec aac -vcodec copy
    -hls_flags delete_segments -hls_time 1 -hls_list_size 2  -hls_init_time 1
  gifOutOptions: -r 2 -filter_complex
    scale=-2:360:flags=lanczos,setpts=0.5*PTS,split[o1][o2];[o1]palettegen[p];[o2]fifo[o3];[o3][p]paletteuse
channels:
  - id: startStream
    channelTypeUID: ipcamera:startStream
    label: Start HLS Stream
    description: Lower the delay to start casting the camera by creating the files
      non stop in case they are needed.
    configuration: {}
  - id: pollImage
    channelTypeUID: ipcamera:pollImage
    label: Poll Image
    description: This can be used to trigger snapshot updates when an external PIR,
      button or other form of sensor turns this channel ON.
    configuration: {}
  - id: image
    channelTypeUID: ipcamera:image
    label: Image
    description: Low frame rate image from your camera. Recommend this is NOT used
      unless you have large pollTime.
    configuration: {}
  - id: recordingGif
    channelTypeUID: ipcamera:recordingGif
    label: GIF Recording
    description: Indicates how long the recording will occur for and when the file
      is created, the channel will change to 0 by itself.
    configuration: {}
  - id: gifHistory
    channelTypeUID: ipcamera:gifHistory
    label: GIF History
    description: A history of the last GIFs created in a CSV formatted string.
    configuration: {}
  - id: gifHistoryLength
    channelTypeUID: ipcamera:gifHistoryLength
    label: GIF History Length
    description: How many GIFs are stored in the history.
    configuration: {}
  - id: recordingMp4
    channelTypeUID: ipcamera:recordingMp4
    label: MP4 Recording
    configuration: {}
  - id: mp4History
    channelTypeUID: ipcamera:mp4History
    label: MP4 History
    description: A history of the last mp4 recordings created in a CSV formatted string.
    configuration: {}
  - id: mp4HistoryLength
    channelTypeUID: ipcamera:mp4HistoryLength
    label: MP4 History Length
    description: How many mp4 recordings are stored in the history.
    configuration: {}
  - id: lastMotionType
    channelTypeUID: ipcamera:lastMotionType
    label: Last Motion Type
    description: A string that contains the type of motion alarm that was last triggered.
    configuration: {}
  - id: ffmpegMotionControl
    channelTypeUID: ipcamera:ffmpegMotionControl
    label: Control FFmpeg Motion Alarm
    description: Enable/Disable the motion alarm and control the sensitivity.
    configuration: {}
  - id: ffmpegMotionAlarm
    channelTypeUID: ipcamera:ffmpegMotionAlarm
    label: FFmpeg Motion Alarm
    description: FFmpeg has detected motion.
    configuration: {}
  - id: externalMotion
    channelTypeUID: ipcamera:externalMotion
    label: External Motion
    description: Use any external sensor like a ZWave PIR sensor to flag that the
      camera has motion in its field of view.
    configuration: {}
  - id: thresholdAudioAlarm
    channelTypeUID: ipcamera:thresholdAudioAlarm
    label: Audio Alarm Threshold
    description: By moving this control you should be able to change how sensitive
      the audio alarm is to soft or loud noises.
    configuration: {}
  - id: audioAlarm
    channelTypeUID: ipcamera:audioAlarm
    label: Audio Alarm
    description: Audio has triggered an Alarm.
    configuration: {}
  - id: mjpegUrl
    channelTypeUID: ipcamera:mjpegUrl
    label: MJPEG URL
    description: A link you can use in openHAB/HABpanel to fetch a MJPEG video feed
      from the camera.
    configuration: {}
  - id: rtspUrl
    channelTypeUID: ipcamera:rtspUrl
    label: RTSP URL
    description: A link that the camera uses for RTSP.
    configuration: {}
  - id: imageUrl
    channelTypeUID: ipcamera:imageUrl
    label: Image URL
    description: A link you can use to fetch a static image from the camera.
    configuration: {}
  - id: hlsUrl
    channelTypeUID: ipcamera:hlsUrl
    label: HLS URL
    description: A link you can use in openHAB to cast video feeds.
    configuration: {}
