Hi there,
i got a little Problem with the Google Home integration,
i got some WallPlugs in google Home / OpenHab - working
Some dimmers - also working
But i also got some RGB Lights, changin color works, but when i try to dim the colors, i got the following Log entry:
2018-12-03 16:12:53.400 [nt.ItemStatePredictedEvent] - RGB_AZ predicted to become 24
2018-12-03 16:12:53.432 [vent.ItemStateChangedEvent] - RGB_AZ changed from 0,0,72 to 0,0,24
2018-12-03 16:12:53.424 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.eclipse.smarthome.binding.mqtt.generic.internal.handler.GenericThingHandler@17af632': Didn't recognise the color value 24
java.lang.IllegalArgumentException: Didn't recognise the color value 24
at org.eclipse.smarthome.binding.mqtt.generic.internal.values.ColorValue.update(ColorValue.java:114) ~[?:?]
at org.eclipse.smarthome.binding.mqtt.generic.internal.generic.ChannelState.setValue(ChannelState.java:272) ~[?:?]
at org.eclipse.smarthome.binding.mqtt.generic.internal.handler.AbstractMQTTThingHandler.handleCommand(AbstractMQTTThingHandler.java:119) ~[?:?]
at sun.reflect.GeneratedMethodAccessor23.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [101:org.eclipse.smarthome.core:0.10.0.201811281422]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [101:org.eclipse.smarthome.core:0.10.0.201811281422]
at com.sun.proxy.$Proxy143.handleCommand(Unknown Source) [227:org.eclipse.smarthome.binding.mqtt.generic:0.10.0.201811281422]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [108:org.eclipse.smarthome.core.thing:0.10.0.201811281422]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [108:org.eclipse.smarthome.core.thing:0.10.0.201811281422]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [101:org.eclipse.smarthome.core:0.10.0.201811281422]
From the shown log I deduct @jeckyllhavok is using MQTT v2.
But in an ancient version (at least 2 weeks old!! )
You should know that MQTTv2 is a new feature for the not yet released OH 2.4
and the last fix commit is just 8 hours old (color channels were broken before that change)
and the last feature commit which added MQTT actions support for rules is just 2 hours old.
If you are using such a fast moving target, you need to stay up to date with your
OH version or use MQTT version 1 in the mean time instead.
thanks for the replies, yes David is right i use the MQTT v2 binding.
Yesterday i did an upgrade of Openhab and now i get the following Log entry:
The funny thing ist that Color and Saturation works, only brightness won’t
2018-12-13 11:42:29.509 [ome.event.ItemCommandEvent] - Item 'MQTT_RGB_Bad' received command 35
2018-12-13 11:42:29.516 [nt.ItemStatePredictedEvent] - MQTT_RGB_Bad predicted to become 35
2018-12-13 11:42:29.524 [vent.ItemStateChangedEvent] - MQTT_RGB_Bad changed from 145,0,53 to 145,0,35
2018-12-13 11:42:29.518 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.eclipse.smarthome.binding.mqtt.generic.internal.handler.GenericThingHandler@11f9b30': 35 is not a valid HSBType syntax
java.lang.IllegalArgumentException: 35 is not a valid HSBType syntax
at org.eclipse.smarthome.core.library.types.HSBType.<init>(HSBType.java:100) ~[102:org.eclipse.smarthome.core:0.10.0.201812121521]
at org.eclipse.smarthome.binding.mqtt.generic.internal.values.ColorValue.update(ColorValue.java:92) ~[?:?]
at org.eclipse.smarthome.binding.mqtt.generic.internal.generic.ChannelState.publishValue(ChannelState.java:302) ~[?:?]
at sun.reflect.GeneratedMethodAccessor25.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.201812121521]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [102:org.eclipse.smarthome.core:0.10.0.201812121521]
at com.sun.proxy.$Proxy156.handleCommand(Unknown Source) [240:org.eclipse.smarthome.binding.mqtt.generic:0.10.0.201812121521]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [109:org.eclipse.smarthome.core.thing:0.10.0.201812121521]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [109:org.eclipse.smarthome.core.thing:0.10.0.201812121521]
at sun.reflect.GeneratedMethodAccessor36.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.201812121521]
Hm, I have to admit that I have tested the color channel only with ON/OFF and a full color value, not with a brightness string value only. There is also no test case for this usage. @Kai this might require a hot fix with a test case.
@jeckyllhavok Just to be sure we are on the same side: You have a dimmer item linked to the MQTT color channel?
