FYI
Alexa was very fussy about the mappings, so could it be something as simple as Title case for example?
FYI
Hi
I had a thought from somewhere in the depths of my dusty mind.
Does Google Assistant use Numbers instead of Names for its modes?
Iâm sure somewhere in the past Iâve had Google change a thermostat mode.
When Iâm back in my office tomorrow, Iâll dig around in my archive and see what I can find from olds tests.
Iâm sure itâs something like the mapping shown here
It uses both. But I think string is recommended.
This is my thermostat settings:
Group g_Stortbad_TSTAT "Stort Bad Termostat" [ "Thermostat" ]
Number stort_bad_Temperature "Stort Bad Temperatur [%.1f °C]" <cu_heating> (g_Stortbad_TSTAT,Temperatur,gTvaer,gSugeTemp) [ "CurrentTemperature" ] { channel="ihc:controller:elko:stortbad_temperatur_fb" }
Number stort_bad_Tempsetpunkt "Stort Bad Temperature setpunkt [%.1f °C]" <temperature> (g_Stortbad_TSTAT) [ "homekit:TargetTemperature" ] { channel="ihc:controller:elko:stortbad_temperaturSet_fb", autoupdate="false" }
Number stort_bad_fugt "Stort Bad Fugtighed [%.0f %%]" <Humidity> (g_Stortbad_TSTAT,Fugtighed,gHumidityBathRoom) [ "CurrentHumidity" ] { channel="ihc:controller:elko:stortbad_fugtighed" }
String stort_bad_Mode "Stort Bad Mode [%s]" (g_Stortbad_TSTAT) [ "homekit:TargetHeatingCoolingMode" ]
Switch telestat1_stort_bad "Stort Bad Telestat [%s]" <cu_switch> (g_Stortbad_TSTAT,gTelestat) { channel="ihc:controller:elko:stortbad_telestat" }
Then I use a rule, based on the telestat state, which send either heat or cool to GA.
rule "heatingmode stortbad"
Item telestat1_stort_bad changed
if (telestat1_stort_bad.state.toString == "ON" ) {
stort_bad_Mode.postUpdate("heat") }
else {
stort_bad_Mode.postUpdate("cool") }
When âheatâ is send to GA the thermostat in the Google Home app will turn red. And when sending âcoolâ, the thermostat turn to blue.
Btw⌠Stay healthy, Stuart!
Thanks Kim
I had it working with Tagging, what weâre trying to achieve is the and type of mode setting using the new metadata technique.
As for staying healthy, Iâll try
Good luck to you all, if youâre really lucky, your children will draw on the wallpaper and force you to redecorate
Should be the same with metadata
Well, I would like to see my children draw on the wall paper. My daughter is 17 and my son 21 years old
I am having problems getting Google Assistant to report back the current / ambient temperature. Instead, it is always telling me the set target temperature of the thermostat.
Question: âOkay google, what it the temperature in the living room?â
Answer: âThe temperature of the living room thermostat is set to âŚÂ°C.â
What am I doing wrong?
The item configuration is the following:
Group WZ_Thermostat "Wohnzimmer Thermostat" <heating> (WZ) { ga="Thermostat" }
String WZ_Thermostat_Mode "Wohnzimmer Thermostat Mode" (WZ_Thermostat) {ga="thermostatMode"}
Number WZ_Thermostat_Temp "Wohnzimmer Temperatur [%.1f %unit%]" <temperature> (WZ_Thermostat) { channel="homematic:HM-TC-IT-WM-W-EU:xxx:2#ACTUAL_TEMPERATURE", ga="thermostatTemperatureAmbient" }
Number WZ_Thermostat_Target "Zieltemperatur [%.1f %unit%]" <temperature> (WZ_Thermostat) { channel="homematic:HM-TC-IT-WM-W-EU:xxx:2#SET_TEMPERATURE", ga="thermostatTemperatureSetpoint" }
Number WZ_Thermostat_Humid "Feuchtigkeit" (WZ_Thermostat) { channel="homematic:HM-TC-IT-WM-W-EU:xxx:2#ACTUAL_HUMIDITY", ga="thermostatHumidityAmbient" }```
NothingâŚ
I and others have noticed this as well. And there dont seem to be any obvious reason for this.
I have 12 thermostats setup. They are all exact the same, and the setup is exact the same. Yet Google respond by telling the setpoint rather than the temperature on two of them. It simply makes no sense.
I think its an Google issue. But I dont see how and why⌠Its always the same two thermostats which Google respond with setpoint.
I have just built an Arduino Nano connected to my Hot Tub via Mosquitto to open HAB. Today I attempted to get GA working with it. I configured it as thermostat both temperature and setpoint are being reported to OH correctly and I see exactly this problem, the setting is reported and not the temperature.
Has anyone found a workaround for this âfeatureâ yet?
NEW INFO:
By playing around with the mode and the set point I have managed to get this working correctly. I seems that when the modes are set to the Alias, it does not work, if I set the mode String to the default it will then work. I suspect the mode was incorrectly set initially causing the problem???
I have also noticed another issue, the maximum temperature on the thermostat on the Phone App is 32C the hot tub max is 40C, Is there a way to extend the operating range of the thermostat?
If thats correct, @michikrug may be able to fix it.
However, it doesnt explain why only two out of my 12 exact equal themostats behave like this. They´re set up exactly the same, and yet two of the report the setpoint when ask for temperature.
I was using the alias when first initialised, as soon as changed I went to the google defined ones it worked. I may try and get it to fail again tomorrow. At no point did I shutdown and restart anything, it just started working. Part of the process was to set up a second thermostat on the same device as just a temperature sensor. That reported temperature okay. When I added the mode (but not the setpoint) to the new group, it failed reporting a setpoint of zero (I assume because it was not defined). The mode alias was âStandardâ for âheatâ, as it now failed I suspected the mode was affecting the return.
Then I went back to the original definition and manually set the mode to âheatâ and it worked, no other changes were made to the definitions.
I can now confirm the action, when setting the mode to the alias âStandardâ google fails to report temperature. As soon as I manually change the mode to the default âheatâ, google reports temperature correctly. No other changes were made during this test, perhaps I am not understanding the alias in the item config correctly, but this is a repeatable state.
So direct control of the mode
[10:35:40] openhabian@openhab:~$ mosquitto_pub -h xxx -u xxx -P xxx -t "balboa_hottub/mode" -m "heat"
[10:36:50] openhabian@openhab:~$ mosquitto_pub -h xxx -u xxx -P xxx -t "balboa_hottub/mode" -m "Standard"
[11:25:42] openhabian@openhab:~$ mosquitto_pub -h xxx -u xxx -P xxx -t "balboa_hottub/mode" -m "heat"
Gives Working - Not Working - Working
Hope this helps someone
But my thermostats is only set up for âheatâ and âcoolâ.
Capitalisation?
I have created a separate mode now and use just âheatâ and âcoolâ. The operation is now robust, in terms of getting the temp back from google and the HA phone app, goes Red and Blue accordingly. Still need to know how to extend the HA thermostat temperature range though!!!
These are my items:
Group g_sove_TSTAT "SovevĂŚrelse Termostat" [ "Thermostat" ]
Number sove_Temperature "SovevÌrelse Temperatur [%.1f °C]" <cu_heating> (g_sove_TSTAT,Temperatur,gTvaer) [ "CurrentTemperature" ] { channel="ihc:controller:elko:sove_temperatur_fb" }
Number sove_Tempsetpunkt "SovevÌrelse Temperature setpunkt [%.1f °C]" <temperature> (g_sove_TSTAT) [ "homekit:TargetTemperature" ] { channel="ihc:controller:elko:sove_temperaturSet_fb", autoupdate="false" }
String sove_Mode "SovevĂŚrelse Mode [%s]" (g_sove_TSTAT) [ "homekit:TargetHeatingCoolingMode" ]
Switch telestat2_sove "SovevĂŚrelse Telestat [%s]" <cu_switch> (g_sove_TSTAT,gTelestat) { channel="ihc:controller:elko:sove_telestat" }
Group g_stue_TSTAT "Stue Termostat" [ "Thermostat" ]
Number stue_Temperature "Stue Temperatur [%.1f °C]" <cu_heating> (g_stue_TSTAT,Temperatur,gTvaer) [ "CurrentTemperature" ] { channel="ihc:controller:elko:stuen_temperatur_fb" }
Number stue_Tempsetpunkt "Stue Temperature setpunkt [%.1f °C]" <temperature> (g_stue_TSTAT) [ "TargetTemperature" ] { channel="ihc:controller:elko:stuen_temperaturSet_fb", autoupdate="false" }
String stue_Mode "Stue Mode [%s]" (g_stue_TSTAT) [ "homekit:TargetHeatingCoolingMode" ]
Switch telestat3_stue "Stue Telestat [%s]" <cu_switch> (g_stue_TSTAT,gTelestat) { channel="ihc:controller:elko:stuen_telestat" }
Group g_koekken_TSTAT "Køkken Termostat" [ "Thermostat" ]
Number koekken_Temperature "Køkken Temperatur [%.1f °C]" <cu_heating> (g_koekken_TSTAT,Temperatur,gTvaer,gSugeTemp) [ "CurrentTemperature" ] { channel="ihc:controller:elko:koekken_temperatur_fb" }
Number koekken_Tempsetpunkt "Køkken Temperature setpunkt [%.1f °C]" <temperature> (g_koekken_TSTAT) [ "homekit:TargetTemperature" ] { channel="ihc:controller:elko:koekken_temperaturSet_fb", autoupdate="false" }
String koekken_Mode "Køkken Mode [%s]" (g_koekken_TSTAT) [ "homekit:TargetHeatingCoolingMode" ]
Switch telestat4a_koekken "Køkken Telestat [%s]" <cu_switch> (g_koekken_TSTAT,gTelestat) { channel="ihc:controller:elko:koekken_telestat" }
Group g_spisestue_TSTAT "Spiseplads Termostat" [ "Thermostat" ]
Number spisestue_Temperature "Spiseplads Temperatur [%.1f °C]" <cu_heating> (g_spisestue_TSTAT,Temperatur,gTvaer) [ "CurrentTemperature" ] { channel="ihc:controller:elko:spise_temperatur_fb" }
Number spisestue_Tempsetpunkt "Spiseplads Temperature setpunkt [%.1f °C]" <temperature> (g_spisestue_TSTAT) [ "homekit:TargetTemperature" ] { channel="ihc:controller:elko:spise_temperaturSet_fb", autoupdate="false" }
String spisestue_Mode "Spiseplads Mode [%s]" (g_spisestue_TSTAT) [ "homekit:TargetHeatingCoolingMode" ]
Switch telestat4b_koekken "Spiseplads Telestat [%s]" <cu_switch> (g_spisestue_TSTAT,gTelestat) { channel="ihc:controller:elko:spise_telestat" }
Group g_kontor_TSTAT "Kontor" [ "Thermostat" ]
Number kontor_Temperature "Kontor [%.1f °C]" <cu_heating> (g_kontor_TSTAT,Temperatur,gTvaer,gSugeTemp) [ "CurrentTemperature" ] { channel="ihc:controller:elko:kontor_temperatur_fb" }
Number kontor_Tempsetpunkt "Kontor setpunkt [%.1f °C]" <temperature> (g_kontor_TSTAT) [ "homekit:TargetTemperature" ] { channel="ihc:controller:elko:kontor_temperaturSet_fb", autoupdate="false" }
String kontor_Mode "Kontor Mode [%s]" (g_kontor_TSTAT) [ "homekit:TargetHeatingCoolingMode" ]
Switch telestat5_kontor "Kontor Telestat [%s]" <cu_switch> (g_kontor_TSTAT,gTelestat) { channel="ihc:controller:elko:kontor_telestat" }
Group g_bryggers_TSTAT "Bryggers Termostat" [ "Thermostat" ]
Number bryggers_Temperature "Bryggers Temperatur [%.1f °C]" <cu_heating> (g_bryggers_TSTAT,Temperatur,gTvaer,gSugeTemp) [ "CurrentTemperature" ] { channel="ihc:controller:elko:bryggers_temperatur_fb" }
Number bryggers_Tempsetpunkt "Bryggers Temperature setpunkt [%.1f °C]" <temperature> (g_bryggers_TSTAT) [ "homekit:TargetTemperature" ] { channel="ihc:controller:elko:bryggers_temperaturSet_fb", autoupdate="false" }
String bryggers_Mode "Bryggers Mode [%s]" (g_bryggers_TSTAT) [ "homekit:TargetHeatingCoolingMode" ]
Switch telestat9_bryggers "Bryggers Telestat [%s]" <cu_switch> (g_bryggers_TSTAT,gTelestat) { channel="ihc:controller:elko:bryggers_telestat9" }
Switch telestat10_entre "Bryggers Telestat Entre [%s]" <cu_switch> (gTelestat) { channel="ihc:controller:elko:bryggers_telestat10" }
Group g_lille_bad_TSTAT "Lille Bad Termostat" [ "Thermostat" ]
Number lille_bad_Temperature "Lille Bad Temperatur [%.1f °C]" <cu_heating> (g_lille_bad_TSTAT,Temperatur,gTvaer,gSugeTemp) [ "CurrentTemperature" ] { channel="ihc:controller:elko:lillebad_temperatur_fb" }
Number lille_bad_Tempsetpunkt "Lille Bad Temperature setpunkt [%.1f °C]" <temperature> (g_lille_bad_TSTAT) [ "homekit:TargetTemperature" ] { channel="ihc:controller:elko:lillebad_temperaturSet_fb", autoupdate="false" }
Number lille_bad_fugt "Lille Bad Fugtighed [%.0f %%]" <Humidity> (g_lille_bad_TSTAT,Fugtighed,gHumidityBathRoom) [ "CurrentHumidity" ] { channel="ihc:controller:elko:lillebad_fugtighed" }
String lille_bad_Mode "Lille Bad Mode [%s]" (g_lille_bad_TSTAT) [ "homekit:TargetHeatingCoolingMode" ]
Switch telestat11_lil_bad "Lille Bad Telestat [%s]" <cu_switch> (g_lille_bad_TSTAT,gTelestat) { channel="ihc:controller:elko:lillebad_telestat" }
Group g_casper_TSTAT "Caspers Termostat" [ "Thermostat" ]
Number casper_Temperature "Caspers vÌr Temperatur [%.1f °C]" <cu_heating> (g_casper_TSTAT,Temperatur,gTvaer) [ "CurrentTemperature" ] { channel="ihc:controller:elko:casper_temperatur_fb" }
Number casper_Tempsetpunkt "Caspers vÌr Temperature setpunkt [%.1f °C]" <temperature> (g_casper_TSTAT) [ "homekit:TargetTemperature" ] { channel="ihc:controller:elko:casper_temperaturSet_fb", autoupdate="false" }
String casper_Mode "Caspers vĂŚr Mode [%s]" (g_casper_TSTAT) [ "homekit:TargetHeatingCoolingMode" ]
Switch telestat12_gaest "Caspers vĂŚr Telestat [%s]" <cu_switch> (g_casper_TSTAT,gTelestat) { channel="ihc:controller:elko:casper_telestat" }
Group g_amanda_TSTAT "Amandas Termostat" [ "Thermostat" ]
Number amanda_Temperature "Amandas vÌr Temperatur [%.1f °C]" <cu_heating> (g_amanda_TSTAT,Temperatur,gTvaer) [ "CurrentTemperature" ] { channel="ihc:controller:elko:amanda_temperatur_fb" }
Number amanda_Tempsetpunkt "Amandas vÌr Temperature setpunkt [%.1f °C]" <temperature> (g_amanda_TSTAT) [ "homekit:TargetTemperature" ] { channel="ihc:controller:elko:amanda_temperaturSet_fb", autoupdate="false" }
String amanda_Mode "Amandas vĂŚr Mode [%s]" (g_amanda_TSTAT) [ "homekit:TargetHeatingCoolingMode" ]
Switch telestat8_amanda "Amandas vĂŚr Telestat [%s]" <cu_switch> (g_amanda_TSTAT,gTelestat) { channel="ihc:controller:elko:amanda_telestat" }
Group g_marc_TSTAT "Marc Termostat" [ "Thermostat" ]
Number marc_Temperature "Marcs vÌrelse Temperatur [%.1f °C]" <cu_heating> (g_marc_TSTAT,Temperatur,gTvaer) [ "CurrentTemperature" ] { channel="ihc:controller:elko:marc_temperatur_fb" }
Number marc_Tempsetpunkt "Marcs vÌrelse Temperature setpunkt [%.1f °C]" <temperature> (g_marc_TSTAT) [ "homekit:TargetTemperature" ] { channel="ihc:controller:elko:marc_temperaturSet_fb", autoupdate="false" }
String marc_Mode "Marcs vĂŚrelse Mode [%s]" (g_marc_TSTAT) [ "homekit:TargetHeatingCoolingMode" ]
Switch telestat7_marc "Marcs vĂŚrelse Telestat [%s]" <cu_switch> (g_marc_TSTAT,gTelestat) { channel="ihc:controller:elko:marc_telestat" }
Group g_aktivitet_TSTAT "Aktivitet Termostat" [ "Thermostat" ]
Number aktivitet_Temperature "Aktivitetsrum Temperatur [%.1f °C]" <cu_heating> (g_aktivitet_TSTAT,Temperatur,gTvaer,gSugeTemp) [ "CurrentTemperature" ] { channel="ihc:controller:elko:aktivitet_temperatur_fb" }
Number aktivitet_Tempsetpunkt "Aktivitetsrum Temperature setpunkt [%.1f °C]" <temperature> (g_aktivitet_TSTAT) [ "homekit:TargetTemperature" ] { channel="ihc:controller:elko:aktivitet_temperaturSet_fb", autoupdate="false" }
String aktivitet_Mode "Aktivitetsrum vĂŚr Mode [%s]" (g_aktivitet_TSTAT) [ "homekit:TargetHeatingCoolingMode" ]
Switch telestat6_aktivitet "Aktivitetsrum Telestat [%s]" <cu_switch> (g_aktivitet_TSTAT,gTelestat) { channel="ihc:controller:elko:aktivitet_telestat" }
As you can see, they´re exact equal.
The mode is set from a rule, when the telestart switch to ON, mode is set for âheatâ and when telestat is OFF, mode is set for âcoolâ.
This is the rule for the first themostat:
else {
It´s a simple as it gets
Hey please, this is my items :
Group SST âTermostato Casaâ { ga=âThermostatâ [ useFahrenheit=false ] }
Number termostatosoggiorno_temperatura âTemperatura Soggiorno [%.1f °C]â (SST) {channel=âsouliss:t52:71:8-5:valueâ, ga=âthermostatTemperatureAmbientâ }
Number termostatosoggiorno_umidita âUmiditĂ Soggiorno [%.1f %%]â (SST) {channel=âsouliss:t53:71:8-7:valueâ, ga=âthermostatHumidityAmbientâ }
Number termostatosoggiorno_setpoint âRegola Set Point [%.1f °c]â (SST) {autoupdate=âfalseâ, channel=âsouliss:t31:71:8-0:setpointâ, ga=âthermostatTemperatureSetpointâ }
Switch termostatosoggiorno_setasmeasured âSet temp. attualeâ (SST) {channel=âsouliss:t31:71:8-0:setAsMeasuredâ}
String termostatosoggiorno_modo âModoâ (SST) {autoupdate=âfalseâ, channel=âsouliss:t31:71:8-0:modeâ, ga=âthermostatModeâ}
Switch termostatosoggiorno_power âTermostatoâ (SST) {channel=âsouliss:t31:71:8-0:systemâ}
When i ask for temperature GA respond me with setpoint. When i ask for humidity GA respond me correctly⌠Tried to ask temperatura soggiorno, temperatura di casa, etc.etc.
What can i try to have ambient temperature as answer ?
thanks
Hi @dariocdj, if you find the answer tell me to! If I ask for the temperature, first the assistant replies with the set point and then with the temperature
@dariocdj yeap, Iâve the same problema with modbus tcp thermostat⌠I think maybe can be missing modes?
