I stopped using Google a while back and wasn’t sure if that could be a possible issue as there are some devices that can have only one connection. Thanks for the post, I will try to keep this info about google handy for later.
ok, will go for re-setup of myopenhab inside google home app. keep you posted
it’s getting weirder. so I removed the openhab connection inside google home and tried to add it again. I select openhab as vendor and the myopenhab webpage appears. I log in with my crendentials and then I allow the permissions that google is asking for. Myopenhab website says “Application Google is requesting access to your account for the following scope: Access to myopenHAB specific API for Google”. Once I click on ALLOW I’m back in the google home app and see “connecting openHAB” (German: wird mit openHAB Konto verknuepft) and then nothing has changed. openhab has not been added as a connection. I tried it now 5 times.
next update, sorry for spamming: I cleaned cache again and tried again in google home, now it worked.
PS: need a hint. I have some items that aren’t correctly initialized when restarting openhab. it does always require that I open and write the .items file (some using http binding, others mqtt). is this is known thing?
PPS: thanks for all who tried to help. unfortunately I have no clue what the issue was
Ahh so simple…
Not to my knowledge…
What exactly do you mean with open and write the items file? If it´s because the item doesnt initialise, then use the mapdb and a rule to initialise on system start for the items involved.
I also always have to touch (open / save) my item files after restarting openHAB to have them properly created. This sucks.
I have now enabled mapdb persistence, this solved my problem with the items not being initialized
As I mentioned in earlier post. Sometimes you need to do it more than once and I have no idea why but when OH starts acting weird this has always seemed to fix it.
I must have missed it. Will do it multiple times in the future
