I know this is getting on a year old but Iām trying to make it work, So far Iāve failed but I canāt see what Iām doing wrong. Iām using GPSTracker which makes things significantly simpler and based on watching events.log the History Item is being populated correctly. Hereās what Iāve doneā¦
NOTE: Iām not using the gecoding API so I didnāt reproduce that Rule.
Preconditions
- GPSTracker installed and configured correctly.
- OwnTracks installed on phones and reporting to OH.
- Things created for each of the reporting phones and the Channels linked to Items.
Get Google Maps API Key
Navigate to https://developers.google.com/maps/documentation/embed/start and select āGet an API keyā on the left and follow the instructions. I already have a billing account. I chose the Maps JS API. Copy the key, we will need it later.
@sintei, it would be helpful if you posted exactly what you needed to change to get the Embedded API URL to work. I tried and failed.
Items
I created a few new Items.
Location vHome "Home Location"
String vMaps_API "Google Maps API Key"
Group:String LocationHistories
Group:Location Locations
// Rich
Location vRich_Location "Rich's Current Lat/Lon [%s]"
<motion> (gChart, Locations)
{ channel="gpstracker:tracker:RK:lastLocation" }
Number vRich_Phone_Battery "Rich's Phone Battery [%d %%]"
<battery>
{ channel="gpstracker:tracker:RK:batteryLevel" }
DateTime vRich_Last_GPS "Rich's Last Location Report [%1$tm/%1$td %1$tH:%1$tM]"
<time>
{ channel="gpstracker:tracker:RK:lastReport" }
Number:Length vRich_GPS_Accuracy "Rich's Location Accuracy [%d ft]"
<motion>
{ channel="gpstracker:tracker:RK:gpsAccuracy" }
String vRich_Region "Rich's Location [%s]"
<motion>
Number:Length vRich_Distance "Rich's Distance from Home [%.1f mi]"
<motion>
{ channel="gpstracker:tracker:RK:distanceSystem" }
String vRich_Location_History
(LocationHistories)
// Jenn
Location vJenn_Location "Jenn's Current Lat/Lon [%s]"
{ channel="gpstracker:tracker:JC:lastLocation" }
Number vJenn_Phone_Battery "Jenn's Phone Battery [%d %%]"
<battery>
{ channel="gpstracker:tracker:JC:batteryLevel" }
DateTime vJenn_Last_GPS "Jenn's Last Location Report [%1$tm/%1$td %1$tH:%1$tM]"
<time>
{ channel="gpstracker:tracker:JC:lastReport" }
Number:Length vJenn_GPS_Accuracy "Jenn's Location Accuracy [%d ft]"
<motion>
{ channel="gpstracker:tracker:JC:gpsAccuracy" }
String vJenn_Region "Jenn's Location [%s]"
<motion>
Number:Length vJenn_Distance "Jenn's Distance from Home [%.1f mi]"
<motion>
{ channel="gpstracker:tracker:JC:distanceSystem" }
String vJenn_Location_History
(LocationHistories)
Rules
I use Python but these are simple enough they should be understood by all. Because the GPSTracker handles parsing the messages from OwnTracks and Iām not doing geocoding yet so all I need to do is update the history Items.
@rule("Clear Histories",
description="Clears location histories",
tags=["location"])
@when("Time cron 0 0 0 ? * * *")
def clear_hist(event):
for loc in ir.getItems("LocationHistories").members:
events.postUpdate(loc.name, "")
@rule("Location Changed",
description="Updates location history",
tags=["location"])
@when("Member of Locations changed")
def loc_changed(event):
hist_item = "{}_History".format(event.itemName)
events.postUpdate(hist_item, "{}{};".format(items[hist_item], event.itemState))
Watching events.log, my History Item is updating as expected:
<lat>,<lon>;<lat>,<lon>;
No spaces. NOTE that I had to initialize the History Item to āā. I need to update the code to handle that case, but I mention it here. Without initializing the Item it ends up starting with NULL
Webview
Downloaded and change the name and unzip map.zip.txt from Google Map. Unzip this folder to $OH_CONF/html. Made the following edits:
index.html
Change the lang attribute at the top to āenā.
Change the error message āPositionsdaten sind nicht geladen.ā to āPosition data is not loaded.ā
Inserted my API Key where indicated at the bottom of the file and change the end of the URL to initMap
instead of initialize
. The example URL on Googleās site uses initMap
. It doesnāt work either way sadly.
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<!-- Force latest IE rendering engine & Chrome Frame -->
<meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1">
<meta name="description" content="Displays the current user locations and the location history data in Google-Maps.">
<meta name="author" content="Patrik Gfeller">
<meta name="viewport" content="width=device-width, initial-scale=1.0, shrink-to-fit=no">
<title>Positionsinformationen</title>
<link href="./css/style.css" type="text/css" rel="stylesheet">
<script src="./lib/openHAB.js"></script>
<script src="./lib/map20.js"></script>
</head>
<body>
<main>
<div id="map" class="map">
<span id="errorMessage" class="errorMessage">Position data is not loaded.</span>
</div>
</main>
<!-- Google-Maps API must be loaded after DOM is initialized completely. -->
<script
src="https://maps.googleapis.com/maps/api/js?key=<MY API KEY>&callback=initMap"
async defer></script>
</body>
</html>
lib/map21.js
Populated openHABLocations with my Items.
I check that the Items are populated properly but whenever I load the page I get the āPosition data is not loaded.ā error. Iāve double checked for typos everywhere I can think of to no avail. Everything
var openHABLocations = {
"Home": {
locationItem: "vHome",
locationIcon: "./img/home.png",
locationType: locationTypes.home,
animation: null,
historyItem: undefined,
historyIcon: undefined,
zIndex: 10
"Rich": {
locationItem: "vRich_Location",
locationIcon: "./img/patrik.png",
locationType: locationTypes.user,
animation: google.maps.Animation.DROP,
historyItem: "vRich_Location_History",
historyIcon: "./img/historyPatrik.png",
zIndex: 9
"Jenn": {
locationItem: "vJenn_Location",
locationIcon: "./img/karin.png",
historyItem: "vJenn_Location_History",
historyIcon: "./img/historyKarin.png",
zIndex: 8
Any assistance or information telling me this no longer works would be appreciated.
