After a restart of my RPI, the service is working and everything is ok! Nice! Very happy.
hi all , i want to migrate from nest account to Google.is there a guide to setup my thermostat with openhab3.1 binding?
Are the new camera gen.2 (battery) also supported in this binding? Canāt seem to get it integrated in oh3
Update:
I now have the new gen.2 added as a thing, but it doesnāt update the channels for image or live stream urls. The only channels that receive data is the timestamp channels. Is it another trait for these new cameras, thatās not supported by this binding?
Thanks for providing this fine binding, which I have configured in OH3.1 using SDM with pub/sub and it is working.
However, I have a problem with the state of my thermostat. If I turn the device to reduce the temperature in the room, then both current_mode and hvac_status channels seem to change to off. And if I increase both will become HEAT / heating.
This means I cannot identity if the thermostat has actually been turned to OFF in the main menu on the thermostat.
I had expected that current_mode would not change in case the thermostat call for heating or stops heating. My expectation is that current_mode would actually reflect the main menu selection on the termostat.
Hey, not sure how to update the nest binding docs on the openhab main docs. I discovered a small hole in the docs for the pubsub portion of the setup guide.
As per the google nest docs(Subscribe to Events Ā |Ā Device Access Ā |Ā Google Developers) in order to create the subscription ID, you need to run the following command in the gcode terminal:
gcloud pubsub subscriptions create {subscription-id} --topic=projects/sdm-prod/topics/enterprise-{ nest project-id}
Created subscription [projects/{gcp-project-name}/subscriptions/{subscription-id}].
This creates and links the subscription in google to the nest project properly so the sub/pub config works.
Anyone got this working with the newer Nest cams?
This isnāt necessary if you first enable pub/sub in GDC. Google Cloud Platform . Afterwards, when saving the thing, the subscription ID is created.
really???i have to spent 3 hours and 5$ just to connect my thermostat to my Openhab???Google is trolling me for sure !!!
Looking at the same thing now. Any responses?
i finally migrate from nest to google account ā¦got SDM account up and running ,showing āUsing periodic refresh and Pub/Subā under online status.I added my thermostat and linked my thermostat item nicely and everything works ok.Just one thing.When i command my thermostat from openhab the change is instant.When i change something from thermostat or nest app the change shows at my openhab with a 2-3 mins delay.Is that right?Is anyone else has the same issue?
I will see if thats the same for me.
I have to solve a different problem until then though:
[WARN ] [binding.nest.internal.sdm.api.SDMAPI] - SDM API error: Rate limited for the GetDevice API for the user.
Seems like for some reason my openhab is polling the pub/sub too many times, I usually get several of those messages in a row.
What triggers a channel update? I already went through my rules, but I donāt think thatās the culpritā¦
Anybody else with those issues?
Infinall have the binding up and running with OH3.2 (somehow it was not working in the older releases for me). I have a nest hello doorcam and Iām wondering: what did you guys do functionality? Are the any rules you can share? Iām thinking about react on doorbell ring, image storage, face recognition, stream processing (btw how to access/store rtsp streams?). Would be great to do some reuse instead of inventing everything from scratchā¦ thanks! M
Iāve just updated to OH3.2, installed the Nest binding, set up my SDM account with periodic refresh and Pub/Sub. Itās discovered my Nest Doorbell but none of the items are being updated (all are Null).
The GCP console isnāt showing any API traffic or subscriptions.
Based on a previous comment Iāve restarting OH and itās still not working. Any ideas to track down the issue?
Thanks!
Having a similar issue. I setup the registered SDM API ($5), set up Nest Binding but I am not discovering my Nest Thermostats.
question: is there a channel to show the AWAY/HOME info?i cant find it?
I have the same issue with the Google Nest Doorbell (Battery) on OH3.2. In my log I see an issue with the permission.
2022-02-05 21:23:07.834 [WARN ] [binding.nest.internal.sdm.api.SDMAPI] - SDM API error: Permission denied to sdm.devices.commands.CameraEventImage.GenerateImage.
I checked that I have given Google the necessary permission to the Doorbell.
Strange enough I get the correct timestamp of the chime as an event.
Anybody can help?
Just a follow up to this. Today working from home my doorbell rule triggered, which was quite a surprise.
I havenāt changed anything but it seems like it just started working for me.
@wborn I just wanted to check if this is on your radar? I received an email notification from google saying āthe OAuth client will be blocked on Oct 3, 2022ā
Continuing the discussion from Google Nest Device Access Console now available:
Hello everyone!
Trying to configure for the first timeā¦ everything seems fine until i get here: i need the token, i select all flags for my camera (named SoggiornoCam). What do i miss???
Thanks!
Any update on this thread?
Since updating to OH 3.4.0 M2, I can no longer authenticate successfully.
