Google TTS exception
Hello guys,
It is the first time trying to test google TTS with openhab but I cannot make it work
Openhab 2.4.0 (stable)
Platform: raspberry pi3
org.openhab.voice.googletts version 2.4.0
I followed the documentation and when I put the json contents on the paperui I get the following exception in openhab.log
2019-03-17 12:32:42.947 [DEBUG] [.googletts.internal.GoogleTTSService] - Updating configuration
2019-03-17 12:32:43.488 [ERROR] [org.openhab.voice.googletts ] - bundle org.openhab.voice.googletts:2.4.0 (261)[org.openhab.voice.googletts.internal.GoogleTTSService(345)] : The updateConfig method has thrown an exception
at org.openhab.voice.googletts.internal.GoogleCloudAPI.listVoices(GoogleCloudAPI.java:246) ~[?:?]
at org.openhab.voice.googletts.internal.GoogleCloudAPI.initVoices(GoogleCloudAPI.java:218) ~[?:?]
at org.openhab.voice.googletts.internal.GoogleCloudAPI.setConfig(GoogleCloudAPI.java:142) ~[?:?]
at org.openhab.voice.googletts.internal.GoogleTTSService.updateConfig(GoogleTTSService.java:211) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) ~[39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) ~[39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeModifiedMethod(SingleComponentManager.java:810) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.modify(SingleComponentManager.java:765) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:683) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:647) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.configurationUpdated(ConfigurableComponentHolder.java:435) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.configurationEvent(RegionConfigurationSupport.java:288) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport$1.configurationEvent(RegionConfigurationSupport.java:91) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.sendEvent(ConfigurationManager.java:1667) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.run(ConfigurationManager.java:1635) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.UpdateThread$1.run(UpdateThread.java:126) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.UpdateThread$1.run(UpdateThread.java:123) [9:org.apache.felix.configadmin:1.9.4]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:122) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105) [9:org.apache.felix.configadmin:1.9.4]
Anybody has any idea why I get this exception ?
Regards,
Hi Christos,
Have a look here:
Thanks Christoph. I have already seen that post but I was not sure it is the same issue so I created a new one. In any case I will monitor that thread as well.
In case it helps I run openhab in docker. Maybe this is related ?
Regards
I do not think so. The NPE was thrown because the voice extension was not able to retrieve the voices from the API which could be caused by - it is just a guess - a misconfiguration.
