The last days and without changing anything i have the following error: In the rules that include a “say” command they re not working after trigger and i get a log error :
if i use VOICERSS tts service everything works as usual ,i get this only using GoogleTTS.Cleaning cashe at Google Cloud Text-to-Speech configuration maybe it will work but its hit an miss.
rule "test"
Item test received command
val String currentTime = String::format( "%1$tA, %1$tB %1$te, %1$tY ,and the time is %1$tl:%1$tM%1$tp", new java.util.Date )
gVolume.sendCommand(50)
say("Good morning,today is"+currentTime+",the temperature inside is"+HallwayThermostat_Temperature.state.format("%.1f").replace(".0",",")+"degrees"+",and the temperature ouside is"+LocalWeatherAndForecast_Current_OutdoorTemperature.state.format("%.1f").replace(".0",",")+"degrees, have a nice day")
this one for example ,some times works ,sometimes doesnt work.If i use another TTS engine it always works fine!
