Google Voice Percent Symbol (%)
a very very easy but tricky question:
as mention in the tutorial Openhab With your voice
It is possible to say: Dim livingroom light at 20 percent
Indeed it works BUT google voice send
Dim livingroom light at 20%
% and percent are different
and consequently the role do not works!!!
How can I manage the percent symbol issue GASP???
Any idea?
if(command.contains("percent") || command.contains("%"))
Yes, but also another problem is the space between 20 percent ; 20% havn’t spacing.
I modify the rule as follows and it works properly
rule "Voice control"
	Item VoiceCommand received command
	var String command = VoiceCommand.state.toString.toLowerCase
	logInfo("Voice.Rec","VoiceCommand received "+command)
	var State newState = null
	// find new state, toggle otherwise (if possible)
	if (command.contains("gradi") || command.contains("percento")) {
		// extract new state (find the digits in the string)
		var java.util.regex.Pattern p = java.util.regex.Pattern::compile(".* ([0-9]+) (gradi|percento).*")
		var Matcher m = p.matcher(command)
		if (m.matches()) {
			newState = new StringType(m.group(1).trim())
	else if (command.contains("%")) {
		var java.util.regex.Pattern p = java.util.regex.Pattern::compile(".* ([0-9]+)(%).*")
	    	if (m.matches()) {
Voice control rule follow....
