I have some Gosund SP111 power outlets which are flashed with Tasmota.
They are used as simple switch items for some time which is working fine.
Now I also want to use the power consumption of the outlets in openHAB but the value of my item is always NULL.
My setup is the following:
openHAB 3.0.2
MQTT system broker
MQTT Binding 3.0.2
Tasmota 9.4 (same problem with 8.2)
mqtt.things
Thing mqtt:topic:tasmota-4193:eg_flur_laterne "eg_flur_laterne" (mqtt:broker:2352baab2a) {
Channels:
Type switch : PowerSwitch [stateTopic="stat/tasmota-4193/POWER", commandTopic="cmnd/tasmota-4193/POWER", on="ON", off="OFF"]
Type number : Power [stateTopic="tele/tasmota-4193/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Power"]
tasmota.items
Switch eg_flur_laterne_schalter "EG Flur Laterne []" <light> (gLicht, gLichtEg, gEG_Flur_Beleuchtung) ["Switch","Light"] {channel="mqtt:topic:tasmota-4193:eg_flur_laterne:PowerSwitch"}
Number:Power eg_flur_laterne_leistung "EG Flur Laterne Leistung [%.1f W]" <line> (gLicht, gLichtEg, gEG_Flur_Beleuchtung) ["Measurement","Power"] {channel="mqtt:topic:tasmota-4193:eg_flur_laterne:Power"}
If I connect to my MQTT broker via MQTT.fx and subscribe to “tele/tasmota-4193/SENSOR” I can see the information from the tele topic.
Can anybody help or give advise how to debug the problem?
I am a bit lost at the moment as i just can’t figure out what the problem is.
Thanks in advance. Regards Alex
