Hi everyone,
I’m using a OH1, Raspberry Pi with GPIO Binding 1.7 and everything works well. Just tried to install OH2 with GPIO binding 1.9.0 and I’m having the following error:
[ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedService, id=293, bundle=189/mvn:org.openhab.io/org.openhab.io.gpio/1.9.0]: Unexpected problem updating configuration org.openhab.gpio
java.lang.ClassCastException: java.lang.Boolean cannot be cast to java.lang.String
at org.openhab.io.gpio.linux.GPIOLinux.updated(GPIOLinux.java:126)[189:org.openhab.io.gpio:1.9.0]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1461)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1417)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109)[3:org.apache.felix.configadmin:1.8.12]
at java.lang.Thread.run(Thread.java:744)[:1.8.0]
I’m running OH2 as root in Raspbian. Anybody with the same problem or some idea what is happening?
Thank you!
roger
