Hi @rlkoshak
I am trying to figure out which link I can get working, so this is still in test phase and that is why 2 protocols are still in the file.
I looked in the log and apparently there is error in creating all actuators. That is why is not working:
Dec 21 18:59:15 raspberrypizero INFO - [MqttConnection] Disconnected from MQTT broker with client <paho.mqtt.client.Client object at 0xb653d330>, userdata None, and code 0
Dec 21 18:59:15 raspberrypizero python3[5954]: /opt/sensor_reporter/gpio/rpi_gpio.py:140: RuntimeWarning: This channel is already in use, continuing anyway. Use GPIO.setwarnings(False) to disable warnings.
Dec 21 18:59:15 raspberrypizero python3[5954]: GPIO.setup(self.pin, GPIO.OUT)
Dec 21 18:59:15 raspberrypizero python3[5954]: Exception in thread Thread-1:
Dec 21 18:59:15 raspberrypizero python3[5954]: Traceback (most recent call last):
Dec 21 18:59:15 raspberrypizero python3[5954]: File "/usr/lib/python3.7/threading.py", line 917, in _bootstrap_inner
Dec 21 18:59:15 raspberrypizero python3[5954]: self.run()
Dec 21 18:59:15 raspberrypizero python3[5954]: File "/usr/lib/python3.7/threading.py", line 865, in run
Dec 21 18:59:15 raspberrypizero python3[5954]: self._target(*self._args, **self._kwargs)
Dec 21 18:59:15 raspberrypizero python3[5954]: File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 3452, in _thread_main
Dec 21 18:59:15 raspberrypizero python3[5954]: self.loop_forever(retry_first_connection=True)
Dec 21 18:59:15 raspberrypizero python3[5954]: File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 1779, in loop_forever
Dec 21 18:59:15 raspberrypizero python3[5954]: rc = self.loop(timeout, max_packets)
Dec 21 18:59:15 raspberrypizero python3[5954]: File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 1181, in loop
Dec 21 18:59:15 raspberrypizero python3[5954]: rc = self.loop_read(max_packets)
Dec 21 18:59:15 raspberrypizero python3[5954]: File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 1572, in loop_read
Dec 21 18:59:15 raspberrypizero python3[5954]: rc = self._packet_read()
Dec 21 18:59:15 raspberrypizero python3[5954]: File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 2310, in _packet_read
Dec 21 18:59:15 raspberrypizero python3[5954]: rc = self._packet_handle()
Dec 21 18:59:15 raspberrypizero python3[5954]: File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 2936, in _packet_handle
Dec 21 18:59:15 raspberrypizero python3[5954]: return self._handle_publish()
Dec 21 18:59:15 raspberrypizero python3[5954]: File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 3216, in _handle_publish
Dec 21 18:59:15 raspberrypizero python3[5954]: self._handle_on_message(message)
Dec 21 18:59:15 raspberrypizero python3[5954]: File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 3429, in _handle_on_message
Dec 21 18:59:15 raspberrypizero python3[5954]: callback(self, self._userdata, message)
Dec 21 18:59:15 raspberrypizero python3[5954]: File "/opt/sensor_reporter/mqtt/mqtt_conn.py", line 147, in on_message
Dec 21 18:59:15 raspberrypizero python3[5954]: handler(msg.payload.decode("utf-8"))
Dec 21 18:59:15 raspberrypizero python3[5954]: File "/opt/sensor_reporter/gpio/rpi_gpio.py", line 159, in on_message
Dec 21 18:59:15 raspberrypizero python3[5954]: self.cmd_src, msg, self.toggle, self.pin)
Dec 21 18:59:15 raspberrypizero python3[5954]: AttributeError: 'RpiGpioActuator' object has no attribute 'toggle'
Dec 21 18:59:15 raspberrypizero systemd[1]: sensor_reporter.service: Succeeded.
Dec 21 18:59:15 raspberrypizero systemd[1]: Stopped Reports status and sensor readings over MQTT and openHAB REST.
Dec 21 18:59:19 raspberrypizero systemd[1]: Started Reports status and sensor readings over MQTT and openHAB REST.
Dec 21 18:59:20 raspberrypizero INFO - [sensor_reporter] Setting logging level to DEBUG
Dec 21 18:59:20 raspberrypizero INFO - [sensor_reporter] Creating connection MQTTSprinklers
Dec 21 18:59:20 raspberrypizero INFO - [MqttConnection] Initializing MQTT Connection...
Dec 21 18:59:20 raspberrypizero INFO - [MqttConnection] Attempting to connect to MQTT broker at 192.168.4.227:1883
Dec 21 18:59:20 raspberrypizero INFO - [MqttConnection] Connection to MQTT is successful
Dec 21 18:59:20 raspberrypizero INFO - [MqttConnection] LWT topic is sensor_reporter/status, subscribing to refresh topic sensor_reporter/refresh
Dec 21 18:59:20 raspberrypizero INFO - [MqttConnection] Registering for messages on 'sensor_reporter/refresh'
Dec 21 18:59:20 raspberrypizero DEBUG - [MqttConnection] Published message ONLINE to sensor_reporter/status retain=True
Dec 21 18:59:20 raspberrypizero DEBUG - [sensor_reporter] 1 connections created
Dec 21 18:59:20 raspberrypizero INFO - [sensor_reporter] Creating device for Actuator0
Dec 21 18:59:20 raspberrypizero INFO - [MqttConnection] Connected with client <paho.mqtt.client.Client object at 0xb64e6330>, userdata None, flags {'session present': 0}, and result code 0. Subscribing to refresh command topic sensor_reporter/refresh
Dec 21 18:59:20 raspberrypizero INFO - [MqttConnection] on_connect: Resubscribing to sensor_reporter/refresh
Dec 21 18:59:21 raspberrypizero INFO - [sensor_reporter] Received a request for current sensor states before poll_mgr has been created, ignoring.
Dec 21 18:59:21 raspberrypizero DEBUG - [MqttConnection] on_publish: Successfully published message <paho.mqtt.client.Client object at 0xb64e6330>, None, 2
Dec 21 18:59:21 raspberrypizero DEBUG - [MqttConnection] on_publish: Successfully published message <paho.mqtt.client.Client object at 0xb64e6330>, None, 3
Dec 21 18:59:21 raspberrypizero DEBUG - [MqttConnection] on_subscribe: Successfully subscribed <paho.mqtt.client.Client object at 0xb64e6330>, None, 1, (0,)
Dec 21 18:59:21 raspberrypizero DEBUG - [MqttConnection] on_subscribe: Successfully subscribed <paho.mqtt.client.Client object at 0xb64e6330>, None, 4, (0,)
Dec 21 18:59:21 raspberrypizero INFO - [MqttConnection] Registering for messages on 'sensor_reporter/SprinklersTerraceCmd'
Dec 21 18:59:21 raspberrypizero DEBUG - [MqttConnection] on_subscribe: Successfully subscribed <paho.mqtt.client.Client object at 0xb64e6330>, None, 5, (0,)
Dec 21 18:59:21 raspberrypizero ERROR - [sensor_reporter] Error creating device Actuator0: Traceback (most recent call last):#012 File "/usr/lib/python3.7/configparser.py", line 788, in get#012 value = d[option]#012 File "/usr/lib/python3.7/collections/__init__.py", line 914, in __getitem__#012 return self.__missing__(key) # support subclasses that define __missing__#012 File "/usr/lib/python3.7/collections/__init__.py", line 906, in __missing__#012 raise KeyError(key)#012KeyError: 'toggle'#012#012During handling of the above exception, another exception occurred:#012#012Traceback (most recent call last):#012 File "sensor_reporter.py", line 170, in create_device#012 return device(dev_conns, params)#012 File "/opt/sensor_reporter/gpio/rpi_gpio.py", line 149, in __init__#012 self.toggle = bool(params("Toggle"))#012 File "sensor_reporter.py", line 161, in <lambda>#012 params = lambda key: config.get(section, key)#012 File "/usr/lib/python3.7/configparser.py", line 791, in get#012 raise NoOptionError(option, section)#012configparser.NoOptionError: No option 'toggle' in section: 'Actuator0'
Dec 21 18:59:21 raspberrypizero INFO - [sensor_reporter] Creating device for Actuator1
Dec 21 18:59:21 raspberrypizero INFO - [MqttConnection] Registering for messages on 'sensor_reporter/SprinklersGardenHouseCmd'
Dec 21 18:59:21 raspberrypizero DEBUG - [MqttConnection] on_subscribe: Successfully subscribed <paho.mqtt.client.Client object at 0xb64e6330>, None, 6, (0,)
Dec 21 18:59:21 raspberrypizero ERROR - [sensor_reporter] Error creating device Actuator1: Traceback (most recent call last):#012 File "/usr/lib/python3.7/configparser.py", line 788, in get#012 value = d[option]#012 File "/usr/lib/python3.7/collections/__init__.py", line 914, in __getitem__#012 return self.__missing__(key) # support subclasses that define __missing__#012 File "/usr/lib/python3.7/collections/__init__.py", line 906, in __missing__#012 raise KeyError(key)#012KeyError: 'toggle'#012#012During handling of the above exception, another exception occurred:#012#012Traceback (most recent call last):#012 File "sensor_reporter.py", line 170, in create_device#012 return device(dev_conns, params)#012 File "/opt/sensor_reporter/gpio/rpi_gpio.py", line 149, in __init__#012 self.toggle = bool(params("Toggle"))#012 File "sensor_reporter.py", line 161, in <lambda>#012 params = lambda key: config.get(section, key)#012 File "/usr/lib/python3.7/configparser.py", line 791, in get#012 raise NoOptionError(option, section)#012configparser.NoOptionError: No option 'toggle' in section: 'Actuator1'
Dec 21 18:59:21 raspberrypizero INFO - [sensor_reporter] Creating device for Actuator2
Dec 21 18:59:21 raspberrypizero INFO - [MqttConnection] Registering for messages on 'sensor_reporter/SprinklersEntranceCmd'
Dec 21 18:59:21 raspberrypizero DEBUG - [MqttConnection] on_subscribe: Successfully subscribed <paho.mqtt.client.Client object at 0xb64e6330>, None, 7, (0,)
Dec 21 18:59:21 raspberrypizero ERROR - [sensor_reporter] Error creating device Actuator2: Traceback (most recent call last):#012 File "/usr/lib/python3.7/configparser.py", line 788, in get#012 value = d[option]#012 File "/usr/lib/python3.7/collections/__init__.py", line 914, in __getitem__#012 return self.__missing__(key) # support subclasses that define __missing__#012 File "/usr/lib/python3.7/collections/__init__.py", line 906, in __missing__#012 raise KeyError(key)#012KeyError: 'toggle'#012#012During handling of the above exception, another exception occurred:#012#012Traceback (most recent call last):#012 File "sensor_reporter.py", line 170, in create_device#012 return device(dev_conns, params)#012 File "/opt/sensor_reporter/gpio/rpi_gpio.py", line 149, in __init__#012 self.toggle = bool(params("Toggle"))#012 File "sensor_reporter.py", line 161, in <lambda>#012 params = lambda key: config.get(section, key)#012 File "/usr/lib/python3.7/configparser.py", line 791, in get#012 raise NoOptionError(option, section)#012configparser.NoOptionError: No option 'toggle' in section: 'Actuator2'
Dec 21 18:59:21 raspberrypizero INFO - [sensor_reporter] Creating device for Actuator3
Dec 21 18:59:21 raspberrypizero INFO - [MqttConnection] Registering for messages on 'sensor_reporter/SprinklersFrontCmd'
Dec 21 18:59:21 raspberrypizero DEBUG - [MqttConnection] on_subscribe: Successfully subscribed <paho.mqtt.client.Client object at 0xb64e6330>, None, 8, (0,)
Dec 21 18:59:21 raspberrypizero ERROR - [sensor_reporter] Error creating device Actuator3: Traceback (most recent call last):#012 File "/usr/lib/python3.7/configparser.py", line 788, in get#012 value = d[option]#012 File "/usr/lib/python3.7/collections/__init__.py", line 914, in __getitem__#012 return self.__missing__(key) # support subclasses that define __missing__#012 File "/usr/lib/python3.7/collections/__init__.py", line 906, in __missing__#012 raise KeyError(key)#012KeyError: 'toggle'#012#012During handling of the above exception, another exception occurred:#012#012Traceback (most recent call last):#012 File "sensor_reporter.py", line 170, in create_device#012 return device(dev_conns, params)#012 File "/opt/sensor_reporter/gpio/rpi_gpio.py", line 149, in __init__#012 self.toggle = bool(params("Toggle"))#012 File "sensor_reporter.py", line 161, in <lambda>#012 params = lambda key: config.get(section, key)#012 File "/usr/lib/python3.7/configparser.py", line 791, in get#012 raise NoOptionError(option, section)#012configparser.NoOptionError: No option 'toggle' in section: 'Actuator3'
Dec 21 18:59:21 raspberrypizero INFO - [sensor_reporter] Creating device for Actuator4
Dec 21 18:59:21 raspberrypizero INFO - [MqttConnection] Registering for messages on 'sensor_reporter/DripHoseCmd'
Dec 21 18:59:21 raspberrypizero DEBUG - [MqttConnection] on_subscribe: Successfully subscribed <paho.mqtt.client.Client object at 0xb64e6330>, None, 9, (0,)
Dec 21 18:59:21 raspberrypizero ERROR - [sensor_reporter] Error creating device Actuator4: Traceback (most recent call last):#012 File "/usr/lib/python3.7/configparser.py", line 788, in get#012 value = d[option]#012 File "/usr/lib/python3.7/collections/__init__.py", line 914, in __getitem__#012 return self.__missing__(key) # support subclasses that define __missing__#012 File "/usr/lib/python3.7/collections/__init__.py", line 906, in __missing__#012 raise KeyError(key)#012KeyError: 'toggle'#012#012During handling of the above exception, another exception occurred:#012#012Traceback (most recent call last):#012 File "sensor_reporter.py", line 170, in create_device#012 return device(dev_conns, params)#012 File "/opt/sensor_reporter/gpio/rpi_gpio.py", line 149, in __init__#012 self.toggle = bool(params("Toggle"))#012 File "sensor_reporter.py", line 161, in <lambda>#012 params = lambda key: config.get(section, key)#012 File "/usr/lib/python3.7/configparser.py", line 791, in get#012 raise NoOptionError(option, section)#012configparser.NoOptionError: No option 'toggle' in section: 'Actuator4'
Dec 21 18:59:21 raspberrypizero INFO - [sensor_reporter] Creating device for Actuator5
Dec 21 18:59:21 raspberrypizero INFO - [MqttConnection] Registering for messages on 'sensor_reporter/SprinkerPumpCmd'
Dec 21 18:59:21 raspberrypizero DEBUG - [MqttConnection] on_subscribe: Successfully subscribed <paho.mqtt.client.Client object at 0xb64e6330>, None, 10, (0,)
Dec 21 18:59:21 raspberrypizero ERROR - [sensor_reporter] Error creating device Actuator5: Traceback (most recent call last):#012 File "/usr/lib/python3.7/configparser.py", line 788, in get#012 value = d[option]#012 File "/usr/lib/python3.7/collections/__init__.py", line 914, in __getitem__#012 return self.__missing__(key) # support subclasses that define __missing__#012 File "/usr/lib/python3.7/collections/__init__.py", line 906, in __missing__#012 raise KeyError(key)#012KeyError: 'toggle'#012#012During handling of the above exception, another exception occurred:#012#012Traceback (most recent call last):#012 File "sensor_reporter.py", line 170, in create_device#012 return device(dev_conns, params)#012 File "/opt/sensor_reporter/gpio/rpi_gpio.py", line 149, in __init__#012 self.toggle = bool(params("Toggle"))#012 File "sensor_reporter.py", line 161, in <lambda>#012 params = lambda key: config.get(section, key)#012 File "/usr/lib/python3.7/configparser.py", line 791, in get#012 raise NoOptionError(option, section)#012configparser.NoOptionError: No option 'toggle' in section: 'Actuator5'
Dec 21 18:59:21 raspberrypizero INFO - [sensor_reporter] Creating device for Actuator6
Dec 21 18:59:21 raspberrypizero INFO - [MqttConnection] Registering for messages on 'sensor_reporter/SprinklerPiRelay7Cmd'
Dec 21 18:59:21 raspberrypizero ERROR - [sensor_reporter] Error creating device Actuator6: Traceback (most recent call last):#012 File "/usr/lib/python3.7/configparser.py", line 788, in get#012 value = d[option]#012 File "/usr/lib/python3.7/collections/__init__.py", line 914, in __getitem__#012 return self.__missing__(key) # support subclasses that define __missing__#012 File "/usr/lib/python3.7/collections/__init__.py", line 906, in __missing__#012 raise KeyError(key)#012KeyError: 'toggle'#012#012During handling of the above exception, another exception occurred:#012#012Traceback (most recent call last):#012 File "sensor_reporter.py", line 170, in create_device#012 return device(dev_conns, params)#012 File "/opt/sensor_reporter/gpio/rpi_gpio.py", line 149, in __init__#012 self.toggle = bool(params("Toggle"))#012 File "sensor_reporter.py", line 161, in <lambda>#012 params = lambda key: config.get(section, key)#012 File "/usr/lib/python3.7/configparser.py", line 791, in get#012 raise NoOptionError(option, section)#012configparser.NoOptionError: No option 'toggle' in section: 'Actuator6'
Dec 21 18:59:21 raspberrypizero DEBUG - [MqttConnection] on_subscribe: Successfully subscribed <paho.mqtt.client.Client object at 0xb64e6330>, None, 11, (0,)
Dec 21 18:59:21 raspberrypizero INFO - [sensor_reporter] Creating device for Actuator7
Dec 21 18:59:21 raspberrypizero INFO - [MqttConnection] Registering for messages on 'sensor_reporter/SprinklerPiRelay8Cmd'
Dec 21 18:59:21 raspberrypizero DEBUG - [MqttConnection] on_subscribe: Successfully subscribed <paho.mqtt.client.Client object at 0xb64e6330>, None, 12, (0,)
Dec 21 18:59:21 raspberrypizero ERROR - [sensor_reporter] Error creating device Actuator7: Traceback (most recent call last):#012 File "/usr/lib/python3.7/configparser.py", line 788, in get#012 value = d[option]#012 File "/usr/lib/python3.7/collections/__init__.py", line 914, in __getitem__#012 return self.__missing__(key) # support subclasses that define __missing__#012 File "/usr/lib/python3.7/collections/__init__.py", line 906, in __missing__#012 raise KeyError(key)#012KeyError: 'toggle'#012#012During handling of the above exception, another exception occurred:#012#012Traceback (most recent call last):#012 File "sensor_reporter.py", line 170, in create_device#012 return device(dev_conns, params)#012 File "/opt/sensor_reporter/gpio/rpi_gpio.py", line 149, in __init__#012 self.toggle = bool(params("Toggle"))#012 File "sensor_reporter.py", line 161, in <lambda>#012 params = lambda key: config.get(section, key)#012 File "/usr/lib/python3.7/configparser.py", line 791, in get#012 raise NoOptionError(option, section)#012configparser.NoOptionError: No option 'toggle' in section: 'Actuator7'
Dec 21 18:59:21 raspberrypizero DEBUG - [sensor_reporter] 0 actuators created
Dec 21 18:59:21 raspberrypizero INFO - [sensor_reporter] Creating device for Sensor1
Dec 21 18:59:21 raspberrypizero INFO - [Heartbeat] Configuing Heartbeat: msec to heartbeat/num and str to heartbeat/str with interval 60.0
Dec 21 18:59:21 raspberrypizero DEBUG - [sensor_reporter] 1 sensors created
Dec 21 18:59:21 raspberrypizero DEBUG - [sensor_reporter] Creating polling manager
Dec 21 18:59:21 raspberrypizero DEBUG - [sensor_reporter] Created, returning polling manager
Dec 21 18:59:21 raspberrypizero INFO - [PollManager] Starting polling loop
Dec 21 18:59:21 raspberrypizero DEBUG - [MqttConnection] on_publish: Successfully published message <paho.mqtt.client.Client object at 0xb64e6330>, None, 13
Dec 21 18:59:21 raspberrypizero DEBUG - [MqttConnection] Published message 18 to sensor_reporter/heartbeat/num retain=False
Dec 21 18:59:21 raspberrypizero DEBUG - [MqttConnection] on_publish: Successfully published message <paho.mqtt.client.Client object at 0xb64e6330>, None, 14
Dec 21 18:59:21 raspberrypizero DEBUG - [MqttConnection] Published message 00:00:00 to sensor_reporter/heartbeat/str retain=False
Dec 21 19:00:21 raspberrypizero DEBUG - [MqttConnection] on_publish: Successfully published message <paho.mqtt.client.Client object at 0xb64e6330>, None, 15
Dec 21 19:00:21 raspberrypizero DEBUG - [MqttConnection] Published message 60122 to sensor_reporter/heartbeat/num retain=False
Dec 21 19:00:21 raspberrypizero DEBUG - [MqttConnection] on_publish: Successfully published message <paho.mqtt.client.Client object at 0xb64e6330>, None, 16
Dec 21 19:00:21 raspberrypizero DEBUG - [MqttConnection] Published message 00:01:00 to sensor_reporter/heartbeat/str retain=False
Dec 21 19:01:21 raspberrypizero DEBUG - [MqttConnection] on_publish: Successfully published message <paho.mqtt.client.Client object at 0xb64e6330>, None, 17
Dec 21 19:01:21 raspberrypizero DEBUG - [MqttConnection] Published message 120224 to sensor_reporter/heartbeat/num retain=False
Dec 21 19:01:21 raspberrypizero DEBUG - [MqttConnection] on_publish: Successfully published message <paho.mqtt.client.Client object at 0xb64e6330>, None, 18
Dec 21 19:01:21 raspberrypizero DEBUG - [MqttConnection] Published message 00:02:00 to sensor_reporter/heartbeat/str retain=False
