GPS history view/map
I am using the new GPSTracker binding to track the location of our phones. I’d like to store locations and date/time in my InfluxDB and somehow automatically create a map view of our location histories. Does anyone have an idea how to do that? I’d like to be able to get something like a Google Maps route view with the history of the past 24 hours or so.
That would interest me too.
Is there a solution to this?
Also interested.
Have MariaDB persistence active already
GPSTracker with OwnTracks-APP is working:
I can see the actual position of my Mobile in my openHAB-Item
Now I try to store all positions in my DB and display it in a map. I only find this 3-years-old ticket
Did anyone solve it?
Sketch of a solution - based on https://wiki.openstreetmap.org/wiki/Openlayers_Track_example:
  1. Store your data as a gpx file in conf/html.
  2. Store the HTML code in conf/html/osm_test.html.
  3. Adjust url, lat, lon, zoom (url: "http://localhost:8080/static/your_track.gpx").
  4. Test it: http://localhost:8080/static/osm_test.html
Example files:
around_lake.gpx.txt (982 Bytes)
osm_test.html.txt (3.0 KB)
Use rules to create the gpx files and to adjust the parameters in osm_test.html.
Use
Webview url="Webview url="http://localhost:8080/static/osm_test.html" height=10
in your sitemap
But unfortunately, this doesn’t seem to work:
net::ERR_CONNECTION_REFUSED
Any hints how to fix this?
UI integration:
Hi @anon71759204 ,
thanks for your support
