Grafana and and anything other than Influxdb
On my Ubuntu 24.04 system, Influxdb v2 is not working. Again. This is the most troublesome app I have running on this system; I’m tired of dealing with it and would like to use something else.
Will one of the other persistence services work equally well with Grafana? I’m praying for some other solution!
I think Grafana works with PoatgreSQL.
As long as both Grafana and OH support it, and database should work.
I’m using MariaDB and Grafana since my first steps with OH, some 3 years now, without any problems.
If you do not need reading data from OH you can use Victoria Metrics write works
