Grafana crashes and restarts every 2 minutes
I’m migrating from OH2 to a fresh OH4 on a raspberry 4. I made the installation with openhabian.
Recently, I installed with openhabian-config Grafana + Influxdb. It worked well however I have noticed that the size of /var/log rapidly grow up to 1 GB (and then logs stops as zram limits the log directory to 1 GB).
I realized that daemon and syslog are very large (about 450MB each) and this is caused by Grafana restarting every 2 minutes. I don’t know how to fix this so I would be grateful is someone could help me.
Below the logs when Grafana is started and eventually stops.
Many thanks,
Bernard
Sep 10 16:13:47 openhabian grafana[6694]: logger=settings t=2023-09-10T16:13:47.622164685+02:00 level=info msg="Starting Grafana" version=10.1.0 commit=838218ba20 branch=HEAD compiled=2023-08-23T12:52:21+02:00
Sep 10 16:13:47 openhabian grafana[6694]: logger=settings t=2023-09-10T16:13:47.623358611+02:00 level=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
Sep 10 16:13:47 openhabian grafana[6694]: logger=settings t=2023-09-10T16:13:47.623489979+02:00 level=info msg="Config loaded from" file=/etc/grafana/grafana.ini
Sep 10 16:13:47 openhabian grafana[6694]: logger=settings t=2023-09-10T16:13:47.623560478+02:00 level=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
Sep 10 16:13:47 openhabian grafana[6694]: logger=settings t=2023-09-10T16:13:47.623628033+02:00 level=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
Sep 10 16:13:47 openhabian grafana[6694]: logger=settings t=2023-09-10T16:13:47.623694254+02:00 level=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
Sep 10 16:13:47 openhabian grafana[6694]: logger=settings t=2023-09-10T16:13:47.623761938+02:00 level=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
Sep 10 16:13:47 openhabian grafana[6694]: logger=settings t=2023-09-10T16:13:47.623830252+02:00 level=info msg=Target target=[all]
Sep 10 16:13:47 openhabian grafana[6694]: logger=settings t=2023-09-10T16:13:47.62392538+02:00 level=info msg="Path Home" path=/usr/share/grafana
Sep 10 16:13:47 openhabian grafana[6694]: logger=settings t=2023-09-10T16:13:47.623991527+02:00 level=info msg="Path Data" path=/var/lib/grafana
Sep 10 16:13:47 openhabian grafana[6694]: logger=settings t=2023-09-10T16:13:47.6240571+02:00 level=info msg="Path Logs" path=/var/log/grafana
Sep 10 16:13:47 openhabian grafana[6694]: logger=settings t=2023-09-10T16:13:47.624175006+02:00 level=info msg="Path Plugins" path=/var/lib/grafana/plugins
Sep 10 16:13:47 openhabian grafana[6694]: logger=settings t=2023-09-10T16:13:47.624339281+02:00 level=info msg="Path Provisioning" path=/etc/grafana/provisioning
Sep 10 16:13:47 openhabian grafana[6694]: logger=settings t=2023-09-10T16:13:47.624413743+02:00 level=info msg="App mode production"
Sep 10 16:13:47 openhabian grafana[6694]: logger=sqlstore t=2023-09-10T16:13:47.625702649+02:00 level=info msg="Connecting to DB" dbtype=sqlite3
Sep 10 16:13:47 openhabian grafana[6694]: logger=migrator t=2023-09-10T16:13:47.776493512+02:00 level=info msg="Starting DB migrations"
Sep 10 16:13:47 openhabian grafana[6694]: logger=migrator t=2023-09-10T16:13:47.82149246+02:00 level=info msg="migrations completed" performed=0 skipped=493 duration=4.42834ms
Sep 10 16:13:47 openhabian grafana[6694]: logger=secrets t=2023-09-10T16:13:47.826119834+02:00 level=info msg="Envelope encryption state" enabled=true currentprovider=secretKey.v1
Sep 10 16:13:48 openhabian grafana[6694]: logger=plugin.loader t=2023-09-10T16:13:48.026922884+02:00 level=warn msg="Plugin missing module.js" pluginID=input warning="Missing module.js, If you loaded this plugin from git, make sure to compile it."
Sep 10 16:13:48 openhabian grafana[6694]: logger=plugin.loader t=2023-09-10T16:13:48.0271184+02:00 level=info msg="Plugin registered" pluginID=input
Sep 10 16:13:48 openhabian grafana[6694]: logger=local.finder t=2023-09-10T16:13:48.027208917+02:00 level=warn msg="Skipping finding plugins as directory does not exist" path=/var/lib/grafana/plugins
Sep 10 16:13:48 openhabian grafana[6694]: logger=query_data t=2023-09-10T16:13:48.038552671+02:00 level=info msg="Query Service initialization"
Sep 10 16:13:48 openhabian grafana[6694]: logger=live.push_http t=2023-09-10T16:13:48.050594229+02:00 level=info msg="Live Push Gateway initialization"
Sep 10 16:14:00 openhabian grafana[6694]: logger=infra.usagestats.collector t=2023-09-10T16:14:00.080070873+02:00 level=info msg="registering usage stat providers" usageStatsProvidersLen=2
Sep 10 16:14:00 openhabian grafana[6694]: logger=server t=2023-09-10T16:14:00.080539773+02:00 level=info msg="Writing PID file" path=/run/grafana/grafana-server.pid pid=6694
Sep 10 16:14:00 openhabian grafana[6694]: logger=modules t=2023-09-10T16:14:00.081433056+02:00 level=info msg=initialising module=secret-migrator
Sep 10 16:14:00 openhabian grafana[6694]: logger=modules t=2023-09-10T16:14:00.081825365+02:00 level=info msg=initialising module=http-server
Sep 10 16:14:00 openhabian grafana[6694]: logger=http.server t=2023-09-10T16:14:00.091020208+02:00 level=info msg="HTTP Server Listen" address=[::]:3000 protocol=http subUrl= socket=
Sep 10 16:14:00 openhabian grafana[6694]: logger=modules t=2023-09-10T16:14:00.116443009+02:00 level=info msg=initialising module=provisioning
Sep 10 16:14:00 openhabian grafana[6694]: logger=provisioning.alerting t=2023-09-10T16:14:00.118982674+02:00 level=info msg="starting to provision alerting"
Sep 10 16:14:00 openhabian grafana[6694]: logger=provisioning.alerting t=2023-09-10T16:14:00.119154098+02:00 level=info msg="finished to provision alerting"
Sep 10 16:14:00 openhabian grafana[6694]: logger=modules t=2023-09-10T16:14:00.119891364+02:00 level=info msg=initialising module=background-services
Sep 10 16:14:00 openhabian grafana[6694]: logger=ngalert.state.manager t=2023-09-10T16:14:00.120614594+02:00 level=info msg="Warming state cache for startup"
Sep 10 16:14:00 openhabian grafana[6694]: logger=grafanaStorageLogger t=2023-09-10T16:14:00.130902402+02:00 level=info msg="storage starting"
Sep 10 16:14:00 openhabian grafana[6694]: logger=modules t=2023-09-10T16:14:00.131236508+02:00 level=info msg="All modules healthy" modules="[secret-migrator provisioning http-server background-services]"
Sep 10 16:14:00 openhabian grafana[6694]: logger=ngalert.state.manager t=2023-09-10T16:14:00.161029058+02:00 level=info msg="State cache has been initialized" states=0 duration=40.408797ms
Sep 10 16:14:00 openhabian grafana[6694]: logger=ngalert.scheduler t=2023-09-10T16:14:00.161328868+02:00 level=info msg="Starting scheduler" tickInterval=10s
Sep 10 16:14:00 openhabian grafana[6694]: logger=ticker t=2023-09-10T16:14:00.161611068+02:00 level=info msg=starting first_tick=2023-09-10T16:14:10+02:00
Sep 10 16:14:00 openhabian grafana[6694]: logger=ngalert.multiorg.alertmanager t=2023-09-10T16:14:00.16181849+02:00 level=info msg="Starting MultiOrg Alertmanager"
Sep 10 16:14:00 openhabian grafana[6694]: logger=grafana.update.checker t=2023-09-10T16:14:00.417318281+02:00 level=info msg="Update check succeeded" duration=291.970054ms
Sep 10 16:14:00 openhabian grafana[6694]: logger=plugins.update.checker t=2023-09-10T16:14:00.485796191+02:00 level=info msg="Update check succeeded" duration=358.718935ms
Sep 10 16:15:19 openhabian grafana[6694]: SIGILL: illegal instruction
Sep 10 16:15:19 openhabian grafana[6694]: PC=0x86232c4 m=10 sigcode=1
Sep 10 16:15:19 openhabian grafana[6694]: signal arrived during cgo execution
Sep 10 16:15:19 openhabian grafana[6694]: instruction bytes: 0xfe 0xde 0xff 0xe7 0x1c 0x0 0x9d 0xe5 0x10 0x10 0x80 0xe2 0x14 0x10 0x8d 0xe5
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 526 [syscall]:
Sep 10 16:15:19 openhabian grafana[6694]: runtime.cgocall(0x84aa89c, 0xc9ba694)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/cgocall.go:157 +0x50 fp=0xc9ba67c sp=0xc9ba664 pc=0x43a3d48
Sep 10 16:15:19 openhabian grafana[6694]: github.com/mattn/go-sqlite3._Cfunc__sqlite3_step_internal(0xeaeaf7d8)
Sep 10 16:15:19 openhabian grafana[6694]: #011_cgo_gotypes.go:365 +0x38 fp=0xc9ba690 sp=0xc9ba67c pc=0x4d69858
Sep 10 16:15:19 openhabian grafana[6694]: github.com/mattn/go-sqlite3.(*SQLiteRows).nextSyncLocked.func1(0xc681170)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/mattn/go-sqlite3@v1.14.16/sqlite3.go:2186 +0x50 fp=0xc9ba6a8 sp=0xc9ba690 pc=0x4d7e0a8
Sep 10 16:15:19 openhabian grafana[6694]: github.com/mattn/go-sqlite3.(*SQLiteRows).nextSyncLocked(0xc681170, {0xc9f0840, 0x2b, 0x2b})
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/mattn/go-sqlite3@v1.14.16/sqlite3.go:2186 +0x20 fp=0xc9ba7c4 sp=0xc9ba6a8 pc=0x4d7ce38
Sep 10 16:15:19 openhabian grafana[6694]: github.com/mattn/go-sqlite3.(*SQLiteRows).Next.func1()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/mattn/go-sqlite3@v1.14.16/sqlite3.go:2167 +0x3c fp=0xc9ba7ec sp=0xc9ba7c4 pc=0x4d7cd90
Sep 10 16:15:19 openhabian grafana[6694]: runtime.goexit()
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xc9ba7ec sp=0xc9ba7ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by github.com/mattn/go-sqlite3.(*SQLiteRows).Next in goroutine 462
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/mattn/go-sqlite3@v1.14.16/sqlite3.go:2166 +0x158
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 1 [select]:
Sep 10 16:15:19 openhabian grafana[6694]: runtime.gopark(0x112170c, 0x0, 0x9, 0x18, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xb6597f0 sp=0xb6597dc pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0xb6598b8, 0xb6598b0, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0xb65988c sp=0xb6597f0 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/dskit/services.(*Manager).AwaitStopped(0xadb8340, {0x191fccc, 0x8c6d130})
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/dskit@v0.0.0-20230706162620-5081d8ed53e6/services/manager.go:145 +0x80 fp=0xb6598c8 sp=0xb65988c pc=0x60d432c
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/grafana/pkg/modules.(*service).Run(0xbb501e0, {0x191fccc, 0x8c6d130})
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/grafana/pkg/modules/modules.go:133 +0x264 fp=0xb659908 sp=0xb6598c8 pc=0x60f333c
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/grafana/pkg/server.(*Server).Run(0xc5b05a0, {0x191fccc, 0x8c6d130})
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/grafana/pkg/server/server.go:129 +0xac fp=0xb659938 sp=0xb659908 pc=0x845b1b8
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/grafana/pkg/cmd/grafana-server/commands.RunServer({{0x18eb688, 0x6}, {0x18f4268, 0xa}, {0x18eb678, 0x4}, {0x18f4278, 0xa}, 0xa2cff00})
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/grafana/pkg/cmd/grafana-server/commands/cli.go:251 +0xe74 fp=0xb659c08 sp=0xb659938 pc=0x84a5000
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/grafana/pkg/cmd/grafana-server/commands.ServerCommand.func1(0xa2cff00)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/grafana/pkg/cmd/grafana-server/commands/cli.go:97 +0x7c fp=0xb659c60 sp=0xb659c08 pc=0x84a416c
Sep 10 16:15:19 openhabian grafana[6694]: github.com/urfave/cli/v2.(*Command).Run(0x9cb9ce0, 0xa2cff00, {0xa2f6380, 0x8, 0x8})
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/urfave/cli/v2@v2.25.0/command.go:273 +0x904 fp=0xb659db0 sp=0xb659c60 pc=0x45721ec
Sep 10 16:15:19 openhabian grafana[6694]: github.com/urfave/cli/v2.(*Command).Run(0x9cb9e40, 0xa2cfe20, {0x98544b0, 0x9, 0xa})
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/urfave/cli/v2@v2.25.0/command.go:266 +0xb4c fp=0xb659f00 sp=0xb659db0 pc=0x4572434
Sep 10 16:15:19 openhabian grafana[6694]: github.com/urfave/cli/v2.(*App).RunContext(0x9b81f00, {0x191fccc, 0x8c6d130}, {0x98544b0, 0x9, 0xa})
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/urfave/cli/v2@v2.25.0/app.go:332 +0x594 fp=0xb659f34 sp=0xb659f00 pc=0x456f09c
Sep 10 16:15:19 openhabian grafana[6694]: github.com/urfave/cli/v2.(*App).Run(...)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/urfave/cli/v2@v2.25.0/app.go:309
Sep 10 16:15:19 openhabian grafana[6694]: main.main()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/grafana/pkg/cmd/grafana/main.go:39 +0x284 fp=0xb659fa0 sp=0xb659f34 pc=0x84a6628
Sep 10 16:15:19 openhabian grafana[6694]: runtime.main()
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:267 +0x338 fp=0xb659fec sp=0xb659fa0 pc=0x43e5318
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xb659fec sp=0xb659fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 2 [force gc (idle), 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: runtime.gopark(0x11216d8, 0x8c46538, 0x11, 0x14, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x986cfd4 sp=0x986cfc0 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.goparkunlock(...)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:404
Sep 10 16:15:19 openhabian grafana[6694]: runtime.forcegchelper()
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:322 +0xe4 fp=0x986cfec sp=0x986cfd4 pc=0x43e56ec
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x986cfec sp=0x986cfec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by runtime.init.5 in goroutine 1
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:310 +0x1c
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 3 [GC sweep wait]:
Sep 10 16:15:19 openhabian grafana[6694]: runtime.gopark(0x11216d8, 0x8c4d8e8, 0xc, 0x14, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x986d7c4 sp=0x986d7b0 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.bgsweep(0x987a000)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/mgcsweep.go:321 +0x11c fp=0x986d7e4 sp=0x986d7c4 pc=0x43cbd9c
Sep 10 16:15:19 openhabian grafana[6694]: runtime.gcenable.func1()
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/mgc.go:200 +0x28 fp=0x986d7ec sp=0x986d7e4 pc=0x43bc2b8
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x986d7ec sp=0x986d7ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by runtime.gcenable in goroutine 1
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/mgc.go:200 +0x74
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 4 [GC scavenge wait]:
Sep 10 16:15:19 openhabian grafana[6694]: runtime.gopark(0x11216d8, 0x8c4fb48, 0xd, 0x14, 0x2)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x986dfb4 sp=0x986dfa0 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.(*scavengerState).park(0x8c4fb48)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/mgcscavenge.go:425 +0x68 fp=0x986dfc8 sp=0x986dfb4 pc=0x43c8f08
Sep 10 16:15:19 openhabian grafana[6694]: runtime.bgscavenge(0x987a000)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/mgcscavenge.go:658 +0x60 fp=0x986dfe4 sp=0x986dfc8 pc=0x43c964c
Sep 10 16:15:19 openhabian grafana[6694]: runtime.gcenable.func2()
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/mgc.go:201 +0x28 fp=0x986dfec sp=0x986dfe4 pc=0x43bc264
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x986dfec sp=0x986dfec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/mgc.go:201 +0xbc
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 5 [finalizer wait, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: runtime.gopark(0x1121570, 0x8c6d208, 0x10, 0x14, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x986c788 sp=0x986c774 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.runfinq()
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/mfinal.go:193 +0x110 fp=0x986c7ec sp=0x986c788 pc=0x43bb110
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x986c7ec sp=0x986c7ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by runtime.createfing in goroutine 1
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/mfinal.go:163 +0x5c
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 6 [GC worker (idle), 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: runtime.gopark(0x1121584, 0x9c21410, 0x1a, 0x14, 0x0)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x986e790 sp=0x986e77c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.gcBgMarkWorker()
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/mgc.go:1293 +0xec fp=0x986e7ec sp=0x986e790 pc=0x43beaf0
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x986e7ec sp=0x986e7ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by runtime.gcBgMarkStartWorkers in goroutine 1
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/mgc.go:1217 +0x20
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 7 [GC worker (idle)]:
Sep 10 16:15:19 openhabian grafana[6694]: runtime.gopark(0x1121584, 0x98ae000, 0x1a, 0x14, 0x0)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x986ef90 sp=0x986ef7c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/mgc.go:1293 +0xec fp=0x986efec sp=0x986ef90 pc=0x43beaf0
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x986efec sp=0x986efec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 18 [GC worker (idle)]:
Sep 10 16:15:19 openhabian grafana[6694]: runtime.gopark(0x1121584, 0x9c80000, 0x1a, 0x14, 0x0)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x9868790 sp=0x986877c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/mgc.go:1293 +0xec fp=0x98687ec sp=0x9868790 pc=0x43beaf0
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x98687ec sp=0x98687ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 34 [GC worker (idle)]:
Sep 10 16:15:19 openhabian grafana[6694]: runtime.gopark(0x1121584, 0x9c21428, 0x1a, 0x14, 0x0)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x9c88790 sp=0x9c8877c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/mgc.go:1293 +0xec fp=0x9c887ec sp=0x9c88790 pc=0x43beaf0
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x9c887ec sp=0x9c887ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 8 [select]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x98696f8 sp=0x98696e4 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0x98697d0, 0x98697bc, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0x9869794 sp=0x98696f8 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/golang/glog.(*fileSink).flushDaemon(0x8c4f630)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/golang/glog@v1.1.0/glog_file.go:345 +0xcc fp=0x98697e4 sp=0x9869794 pc=0x5347f50
Sep 10 16:15:19 openhabian grafana[6694]: github.com/golang/glog.init.1.func1()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/golang/glog@v1.1.0/glog_file.go:163 +0x28 fp=0x98697ec sp=0x98697e4 pc=0x5346ff8
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x98697ec sp=0x98697ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by github.com/golang/glog.init.1 in goroutine 1
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/golang/glog@v1.1.0/glog_file.go:163 +0x1b4
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 9 [select]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x9869ef8 sp=0x9869ee4 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0x9869fcc, 0x9869fb8, 0x0, 0x0, 0x3, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0x9869f94 sp=0x9869ef8 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: go.opencensus.io/stats/view.(*worker).start(0x9ede240)
Sep 10 16:15:19 openhabian grafana[6694]: #011go.opencensus.io@v0.24.0/stats/view/worker.go:292 +0xbc fp=0x9869fe4 sp=0x9869f94 pc=0x5af2768
Sep 10 16:15:19 openhabian grafana[6694]: go.opencensus.io/stats/view.init.0.func1()
Sep 10 16:15:19 openhabian grafana[6694]: #011go.opencensus.io@v0.24.0/stats/view/worker.go:34 +0x28 fp=0x9869fec sp=0x9869fe4 pc=0x5af1b00
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x9869fec sp=0x9869fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by go.opencensus.io/stats/view.init.0 in goroutine 1
Sep 10 16:15:19 openhabian grafana[6694]: #011go.opencensus.io@v0.24.0/stats/view/worker.go:34 +0xa0
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 55 [select]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xaf17e88 sp=0xaf17e74 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0xaf17f5c, 0xaf17f48, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0xaf17f24 sp=0xaf17e88 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/grafana/pkg/api.(*HTTPServer).running(0xa137800, {0x191fe6c, 0xbb50660})
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/grafana/pkg/api/http_server.go:450 +0x9c fp=0xaf17f6c sp=0xaf17f24 pc=0x68b3f40
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/grafana/pkg/api.(*HTTPServer).running-fm({0x191fe6c, 0xbb50660})
Sep 10 16:15:19 openhabian grafana[6694]: #011<autogenerated>:1 +0x38 fp=0xaf17f84 sp=0xaf17f6c pc=0x68e54c8
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/dskit/services.(*BasicService).main(0xa62cae0)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/dskit@v0.0.0-20230706162620-5081d8ed53e6/services/basic_service.go:190 +0x1fc fp=0xaf17fe4 sp=0xaf17f84 pc=0x60d25b0
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/dskit/services.(*BasicService).StartAsync.func1.2()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/dskit@v0.0.0-20230706162620-5081d8ed53e6/services/basic_service.go:119 +0x28 fp=0xaf17fec sp=0xaf17fe4 pc=0x60d2224
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xaf17fec sp=0xaf17fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by github.com/grafana/dskit/services.(*BasicService).StartAsync.func1 in goroutine 424
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/dskit@v0.0.0-20230706162620-5081d8ed53e6/services/basic_service.go:119 +0x110
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 226 [select, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x9c8b704 sp=0x9c8b6f0 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0x9c8b7d0, 0x9c8b7c4, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0x9c8b7a0 sp=0x9c8b704 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/patrickmn/go-cache.(*janitor).Run(0x9c78700, 0x9c586c0)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/patrickmn/go-cache@v2.1.0+incompatible/cache.go:1079 +0x98 fp=0x9c8b7e0 sp=0x9c8b7a0 pc=0x5437b00
Sep 10 16:15:19 openhabian grafana[6694]: github.com/patrickmn/go-cache.runJanitor.func1()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/patrickmn/go-cache@v2.1.0+incompatible/cache.go:1099 +0x30 fp=0x9c8b7ec sp=0x9c8b7e0 pc=0x5437ccc
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x9c8b7ec sp=0x9c8b7ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by github.com/patrickmn/go-cache.runJanitor in goroutine 1
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/patrickmn/go-cache@v2.1.0+incompatible/cache.go:1099 +0xfc
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 207 [select, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x9c8af04 sp=0x9c8aef0 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0x9c8afd0, 0x9c8afc4, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0x9c8afa0 sp=0x9c8af04 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/patrickmn/go-cache.(*janitor).Run(0xa36fbc0, 0xa4e2510)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/patrickmn/go-cache@v2.1.0+incompatible/cache.go:1079 +0x98 fp=0x9c8afe0 sp=0x9c8afa0 pc=0x5437b00
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/patrickmn/go-cache@v2.1.0+incompatible/cache.go:1099 +0x30 fp=0x9c8afec sp=0x9c8afe0 pc=0x5437ccc
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x9c8afec sp=0x9c8afec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 208 [select, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x9c8a704 sp=0x9c8a6f0 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0x9c8a7cc, 0x9c8a7c4, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0x9c8a7a0 sp=0x9c8a704 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: database/sql.(*DB).connectionOpener(0xa17ccf0, {0x191fe6c, 0xa4e2600})
Sep 10 16:15:19 openhabian grafana[6694]: #011database/sql/sql.go:1218 +0x9c fp=0x9c8a7dc sp=0x9c8a7a0 pc=0x4c86eb0
Sep 10 16:15:19 openhabian grafana[6694]: database/sql.OpenDB.func1()
Sep 10 16:15:19 openhabian grafana[6694]: #011database/sql/sql.go:791 +0x38 fp=0x9c8a7ec sp=0x9c8a7dc pc=0x4c85110
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x9c8a7ec sp=0x9c8a7ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by database/sql.OpenDB in goroutine 1
Sep 10 16:15:19 openhabian grafana[6694]: #011database/sql/sql.go:791 +0x170
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 209 [select, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x9868ee4 sp=0x9868ed0 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0x9868fcc, 0x9868fb8, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0x9868f80 sp=0x9868ee4 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: database/sql.(*DB).connectionCleaner(0xa17ccf0, 0xd18c2e28000)
Sep 10 16:15:19 openhabian grafana[6694]: #011database/sql/sql.go:1061 +0xe8 fp=0x9868fdc sp=0x9868f80 pc=0x4c862dc
Sep 10 16:15:19 openhabian grafana[6694]: database/sql.(*DB).startCleanerLocked.func1()
Sep 10 16:15:19 openhabian grafana[6694]: #011database/sql/sql.go:1048 +0x38 fp=0x9868fec sp=0x9868fdc pc=0x4c861c8
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x9868fec sp=0x9868fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by database/sql.(*DB).startCleanerLocked in goroutine 1
Sep 10 16:15:19 openhabian grafana[6694]: #011database/sql/sql.go:1048 +0x20c
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 397 [select, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x9c85ee8 sp=0x9c85ed4 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0x9c85fc0, 0x9c85fac, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0x9c85f84 sp=0x9c85ee8 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/prometheus/alertmanager/store.(*Alerts).Run(0xa1826d0, {0x191fe6c, 0xa64a2d0}, 0x1a3185c5000)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/prometheus/alertmanager@v0.25.0/store/store.go:63 +0xe4 fp=0x9c85fd4 sp=0x9c85f84 pc=0x57ac66c
Sep 10 16:15:19 openhabian grafana[6694]: github.com/prometheus/alertmanager/provider/mem.NewAlerts.func3()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/prometheus/alertmanager@v0.25.0/provider/mem/mem.go:129 +0x48 fp=0x9c85fec sp=0x9c85fd4 pc=0x582ae20
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x9c85fec sp=0x9c85fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by github.com/prometheus/alertmanager/provider/mem.NewAlerts in goroutine 1
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/prometheus/alertmanager@v0.25.0/provider/mem/mem.go:129 +0x34c
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 216 [select, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x9c86704 sp=0x9c866f0 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0x9c867d0, 0x9c867c4, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0x9c867a0 sp=0x9c86704 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/patrickmn/go-cache.(*janitor).Run(0xa5ced90, 0xa5d2ae0)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/patrickmn/go-cache@v2.1.0+incompatible/cache.go:1079 +0x98 fp=0x9c867e0 sp=0x9c867a0 pc=0x5437b00
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/patrickmn/go-cache@v2.1.0+incompatible/cache.go:1099 +0x30 fp=0x9c867ec sp=0x9c867e0 pc=0x5437ccc
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x9c867ec sp=0x9c867ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 245 [select]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x9c896ac sp=0x9c89698 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0x9c89798, 0x9c89780, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0x9c89748 sp=0x9c896ac pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/centrifugal/centrifuge.(*historyHub).expireStreams(0xa3a0a20)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/broker_memory.go:210 +0x84 fp=0x9c897e4 sp=0x9c89748 pc=0x657ced4
Sep 10 16:15:19 openhabian grafana[6694]: github.com/centrifugal/centrifuge.(*historyHub).runCleanups.func1()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/broker_memory.go:164 +0x28 fp=0x9c897ec sp=0x9c897e4 pc=0x657c9a4
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x9c897ec sp=0x9c897ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by github.com/centrifugal/centrifuge.(*historyHub).runCleanups in goroutine 1
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/broker_memory.go:164 +0x58
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 246 [select]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x9c89eb0 sp=0x9c89e9c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0x9c89f98, 0x9c89f84, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0x9c89f4c sp=0x9c89eb0 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/centrifugal/centrifuge.(*historyHub).removeStreams(0xa3a0a20)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/broker_memory.go:171 +0x84 fp=0x9c89fe4 sp=0x9c89f4c pc=0x657ca54
Sep 10 16:15:19 openhabian grafana[6694]: github.com/centrifugal/centrifuge.(*historyHub).runCleanups.func2()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/broker_memory.go:165 +0x28 fp=0x9c89fec sp=0x9c89fe4 pc=0x657c950
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x9c89fec sp=0x9c89fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/broker_memory.go:165 +0xa0
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 247 [select]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xafc1f0c sp=0xafc1ef8 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0xafc1fd4, 0xafc1fcc, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0xafc1fa8 sp=0xafc1f0c pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/FZambia/eagle.(*Eagle).aggregate(0xa181950)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/FZambia/eagle@v0.1.0/eagle.go:210 +0x94 fp=0xafc1fe4 sp=0xafc1fa8 pc=0x6579c40
Sep 10 16:15:19 openhabian grafana[6694]: github.com/FZambia/eagle.New.func1()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/FZambia/eagle@v0.1.0/eagle.go:66 +0x28 fp=0xafc1fec sp=0xafc1fe4 pc=0x65785f8
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xafc1fec sp=0xafc1fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by github.com/FZambia/eagle.New in goroutine 1
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/FZambia/eagle@v0.1.0/eagle.go:66 +0x188
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 384 [chan receive]:
Sep 10 16:15:19 openhabian grafana[6694]: runtime.gopark(0x1121550, 0xadb83b0, 0xe, 0x17, 0x2)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xa8e6f7c sp=0xa8e6f68 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.chanrecv(0xadb8380, 0xa8e6fe8, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/chan.go:583 +0x4c4 fp=0xa8e6fb8 sp=0xa8e6f7c pc=0x43a63f4
Sep 10 16:15:19 openhabian grafana[6694]: runtime.chanrecv2(0xadb8380, 0xa8e6fe8)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/chan.go:447 +0x20 fp=0xa8e6fcc sp=0xa8e6fb8 pc=0x43a5f24
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/dskit/services.(*BasicService).AddListener.func1()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/dskit@v0.0.0-20230706162620-5081d8ed53e6/services/basic_service.go:344 +0x6c fp=0xa8e6fec sp=0xa8e6fcc pc=0x60d36cc
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xa8e6fec sp=0xa8e6fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by github.com/grafana/dskit/services.(*BasicService).AddListener in goroutine 1
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/dskit@v0.0.0-20230706162620-5081d8ed53e6/services/basic_service.go:343 +0x1d8
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 53 [select, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x986b668 sp=0x986b654 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0x986b794, 0x986b748, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0x986b704 sp=0x986b668 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/prometheus/alertmanager/inhibit.(*Inhibitor).run(0xa31c740, {0x191fe6c, 0x9bee120})
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/prometheus/alertmanager@v0.25.0/inhibit/inhibit.go:65 +0x120 fp=0x986b7b8 sp=0x986b704 pc=0x57ad51c
Sep 10 16:15:19 openhabian grafana[6694]: github.com/prometheus/alertmanager/inhibit.(*Inhibitor).Run.func1()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/prometheus/alertmanager@v0.25.0/inhibit/inhibit.go:102 +0x2c fp=0x986b7c8 sp=0x986b7b8 pc=0x57ade98
Sep 10 16:15:19 openhabian grafana[6694]: github.com/oklog/run.(*Group).Run.func1({0xa192270, 0x9e7a680})
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/oklog/run@v1.1.0/group.go:38 +0x24 fp=0x986b7e0 sp=0x986b7c8 pc=0x4b6578c
Sep 10 16:15:19 openhabian grafana[6694]: github.com/oklog/run.(*Group).Run.func2()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/oklog/run@v1.1.0/group.go:39 +0x3c fp=0x986b7ec sp=0x986b7e0 pc=0x4b6573c
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x986b7ec sp=0x986b7ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by github.com/oklog/run.(*Group).Run in goroutine 399
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/oklog/run@v1.1.0/group.go:37 +0x7c
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 418 [chan receive]:
Sep 10 16:15:19 openhabian grafana[6694]: runtime.gopark(0x1121550, 0xadb8430, 0xe, 0x17, 0x2)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x986bf7c sp=0x986bf68 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.chanrecv(0xadb8400, 0x986bfe8, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/chan.go:583 +0x4c4 fp=0x986bfb8 sp=0x986bf7c pc=0x43a63f4
Sep 10 16:15:19 openhabian grafana[6694]: runtime.chanrecv2(0xadb8400, 0x986bfe8)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/chan.go:447 +0x20 fp=0x986bfcc sp=0x986bfb8 pc=0x43a5f24
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/dskit@v0.0.0-20230706162620-5081d8ed53e6/services/basic_service.go:344 +0x6c fp=0x986bfec sp=0x986bfcc pc=0x60d36cc
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x986bfec sp=0x986bfec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 217 [select]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xa8a7ef8 sp=0xa8a7ee4 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0xa8a7fdc, 0xa8a7fb8, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0xa8a7f94 sp=0xa8a7ef8 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/centrifugal/centrifuge.(*Node).initMetrics.func1()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/node.go:351 +0xa0 fp=0xa8a7fec sp=0xa8a7f94 pc=0x65b5f2c
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xa8a7fec sp=0xa8a7fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by github.com/centrifugal/centrifuge.(*Node).initMetrics in goroutine 1
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/node.go:349 +0x200
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 218 [select]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x9885ef8 sp=0x9885ee4 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0x9885fd4, 0x9885fbc, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0x9885f94 sp=0x9885ef8 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/centrifugal/centrifuge.(*Node).sendNodePing(0xa24cc80)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/node.go:366 +0x88 fp=0x9885fe4 sp=0x9885f94 pc=0x65b606c
Sep 10 16:15:19 openhabian grafana[6694]: github.com/centrifugal/centrifuge.(*Node).Run.func1()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/node.go:246 +0x28 fp=0x9885fec sp=0x9885fe4 pc=0x65b5310
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x9885fec sp=0x9885fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by github.com/centrifugal/centrifuge.(*Node).Run in goroutine 1
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/node.go:246 +0x2e4
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 219 [select]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x9c84f08 sp=0x9c84ef4 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0x9c84fd4, 0x9c84fc8, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0x9c84fa4 sp=0x9c84f08 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/centrifugal/centrifuge.(*Node).cleanNodeInfo(0xa24cc80)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/node.go:380 +0xac fp=0x9c84fe4 sp=0x9c84fa4 pc=0x65b6254
Sep 10 16:15:19 openhabian grafana[6694]: github.com/centrifugal/centrifuge.(*Node).Run.func2()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/node.go:247 +0x28 fp=0x9c84fec sp=0x9c84fe4 pc=0x65b52bc
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x9c84fec sp=0x9c84fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/node.go:247 +0x32c
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 220 [select]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x9c85708 sp=0x9c856f4 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0x9c857d4, 0x9c857c8, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0x9c857a4 sp=0x9c85708 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/centrifugal/centrifuge.(*Node).updateMetrics(0xa24cc80)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/node.go:321 +0xa4 fp=0x9c857e4 sp=0x9c857a4 pc=0x65b5c08
Sep 10 16:15:19 openhabian grafana[6694]: github.com/centrifugal/centrifuge.(*Node).Run.func3()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/node.go:248 +0x28 fp=0x9c857ec sp=0x9c857e4 pc=0x65b5268
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x9c857ec sp=0x9c857ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/node.go:248 +0x374
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 221 [sync.Cond.Wait, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: runtime.gopark(0x11216d8, 0xa31fc10, 0x14, 0x1a, 0x3)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x9c86f70 sp=0x9c86f5c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: sync.runtime_notifyListWait(0xa31fc08, 0xa)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/sema.go:527 +0x1e4 fp=0x9c86f9c sp=0x9c86f70 pc=0x441c2f4
Sep 10 16:15:19 openhabian grafana[6694]: sync.(*Cond).Wait(0xa31fc00)
Sep 10 16:15:19 openhabian grafana[6694]: #011sync/cond.go:70 +0xbc fp=0x9c86fc0 sp=0x9c86f9c pc=0x4444b28
Sep 10 16:15:19 openhabian grafana[6694]: github.com/centrifugal/centrifuge/internal/dissolve.(*queueImpl).Wait(0x9c50b00)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/queue.go:139 +0x70 fp=0x9c86fd0 sp=0x9c86fc0 pc=0x6577fe0
Sep 10 16:15:19 openhabian grafana[6694]: github.com/centrifugal/centrifuge/internal/dissolve.(*Dissolver).runWorker(0x9f19d70)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:52 +0x28 fp=0x9c86fe4 sp=0x9c86fd0 pc=0x6577a1c
Sep 10 16:15:19 openhabian grafana[6694]: github.com/centrifugal/centrifuge/internal/dissolve.(*Dissolver).Run.func1()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:31 +0x28 fp=0x9c86fec sp=0x9c86fe4 pc=0x65778e4
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x9c86fec sp=0x9c86fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by github.com/centrifugal/centrifuge/internal/dissolve.(*Dissolver).Run in goroutine 1
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:31 +0x24
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 222 [sync.Cond.Wait, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x9c87770 sp=0x9c8775c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: sync.runtime_notifyListWait(0xa31fc08, 0x9)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/sema.go:527 +0x1e4 fp=0x9c8779c sp=0x9c87770 pc=0x441c2f4
Sep 10 16:15:19 openhabian grafana[6694]: #011sync/cond.go:70 +0xbc fp=0x9c877c0 sp=0x9c8779c pc=0x4444b28
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/queue.go:139 +0x70 fp=0x9c877d0 sp=0x9c877c0 pc=0x6577fe0
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:52 +0x28 fp=0x9c877e4 sp=0x9c877d0 pc=0x6577a1c
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:31 +0x28 fp=0x9c877ec sp=0x9c877e4 pc=0x65778e4
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x9c877ec sp=0x9c877ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 223 [sync.Cond.Wait, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x9c87f70 sp=0x9c87f5c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: sync.runtime_notifyListWait(0xa31fc08, 0xb)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/sema.go:527 +0x1e4 fp=0x9c87f9c sp=0x9c87f70 pc=0x441c2f4
Sep 10 16:15:19 openhabian grafana[6694]: #011sync/cond.go:70 +0xbc fp=0x9c87fc0 sp=0x9c87f9c pc=0x4444b28
#011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:31 +0x28 fp=0xa8a3fec sp=0xa8a3fe4 pc=0x65778e4
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xa8a3fec sp=0xa8a3fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 258 [sync.Cond.Wait, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xa8a4770 sp=0xa8a475c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: sync.runtime_notifyListWait(0xa31fc08, 0x4)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/sema.go:527 +0x1e4 fp=0xa8a479c sp=0xa8a4770 pc=0x441c2f4
Sep 10 16:15:19 openhabian grafana[6694]: #011sync/cond.go:70 +0xbc fp=0xa8a47c0 sp=0xa8a479c pc=0x4444b28
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/queue.go:139 +0x70 fp=0xa8a47d0 sp=0xa8a47c0 pc=0x6577fe0
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:52 +0x28 fp=0xa8a47e4 sp=0xa8a47d0 pc=0x6577a1c
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:31 +0x28 fp=0xa8a47ec sp=0xa8a47e4 pc=0x65778e4
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xa8a47ec sp=0xa8a47ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 259 [sync.Cond.Wait, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xa8a4f70 sp=0xa8a4f5c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: sync.runtime_notifyListWait(0xa31fc08, 0x7)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/sema.go:527 +0x1e4 fp=0xa8a4f9c sp=0xa8a4f70 pc=0x441c2f4
Sep 10 16:15:19 openhabian grafana[6694]: #011sync/cond.go:70 +0xbc fp=0xa8a4fc0 sp=0xa8a4f9c pc=0x4444b28
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/queue.go:139 +0x70 fp=0xa8a4fd0 sp=0xa8a4fc0 pc=0x6577fe0
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:52 +0x28 fp=0xa8a4fe4 sp=0xa8a4fd0 pc=0x6577a1c
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:31 +0x28 fp=0xa8a4fec sp=0xa8a4fe4 pc=0x65778e4
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xa8a4fec sp=0xa8a4fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 260 [sync.Cond.Wait, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xa8a5770 sp=0xa8a575c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: sync.runtime_notifyListWait(0xa31fc08, 0x8)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/sema.go:527 +0x1e4 fp=0xa8a579c sp=0xa8a5770 pc=0x441c2f4
Sep 10 16:15:19 openhabian grafana[6694]: #011sync/cond.go:70 +0xbc fp=0xa8a57c0 sp=0xa8a579c pc=0x4444b28
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/queue.go:139 +0x70 fp=0xa8a57d0 sp=0xa8a57c0 pc=0x6577fe0
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:52 +0x28 fp=0xa8a57e4 sp=0xa8a57d0 pc=0x6577a1c
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:31 +0x28 fp=0xa8a57ec sp=0xa8a57e4 pc=0x65778e4
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xa8a57ec sp=0xa8a57ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 261 [sync.Cond.Wait, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xa8a5f70 sp=0xa8a5f5c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: sync.runtime_notifyListWait(0xa31fc08, 0x2)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/sema.go:527 +0x1e4 fp=0xa8a5f9c sp=0xa8a5f70 pc=0x441c2f4
Sep 10 16:15:19 openhabian grafana[6694]: #011sync/cond.go:70 +0xbc fp=0xa8a5fc0 sp=0xa8a5f9c pc=0x4444b28
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/queue.go:139 +0x70 fp=0xa8a5fd0 sp=0xa8a5fc0 pc=0x6577fe0
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:52 +0x28 fp=0xa8a5fe4 sp=0xa8a5fd0 pc=0x6577a1c
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:31 +0x28 fp=0xa8a5fec sp=0xa8a5fe4 pc=0x65778e4
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xa8a5fec sp=0xa8a5fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 262 [sync.Cond.Wait, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xa8a6770 sp=0xa8a675c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: sync.runtime_notifyListWait(0xa31fc08, 0x3)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/sema.go:527 +0x1e4 fp=0xa8a679c sp=0xa8a6770 pc=0x441c2f4
Sep 10 16:15:19 openhabian grafana[6694]: #011sync/cond.go:70 +0xbc fp=0xa8a67c0 sp=0xa8a679c pc=0x4444b28
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/queue.go:139 +0x70 fp=0xa8a67d0 sp=0xa8a67c0 pc=0x6577fe0
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:52 +0x28 fp=0xa8a67e4 sp=0xa8a67d0 pc=0x6577a1c
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:31 +0x28 fp=0xa8a67ec sp=0xa8a67e4 pc=0x65778e4
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xa8a67ec sp=0xa8a67ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 263 [sync.Cond.Wait, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xa8a6f70 sp=0xa8a6f5c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: sync.runtime_notifyListWait(0xa31fc08, 0x5)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/sema.go:527 +0x1e4 fp=0xa8a6f9c sp=0xa8a6f70 pc=0x441c2f4
Sep 10 16:15:19 openhabian grafana[6694]: #011sync/cond.go:70 +0xbc fp=0xa8a6fc0 sp=0xa8a6f9c pc=0x4444b28
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/queue.go:139 +0x70 fp=0xa8a6fd0 sp=0xa8a6fc0 pc=0x6577fe0
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:52 +0x28 fp=0xa8a6fe4 sp=0xa8a6fd0 pc=0x6577a1c
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:31 +0x28 fp=0xa8a6fec sp=0xa8a6fe4 pc=0x65778e4
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xa8a6fec sp=0xa8a6fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 264 [sync.Cond.Wait, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xa8a7770 sp=0xa8a775c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: sync.runtime_notifyListWait(0xa31fc08, 0x6)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/sema.go:527 +0x1e4 fp=0xa8a779c sp=0xa8a7770 pc=0x441c2f4
Sep 10 16:15:19 openhabian grafana[6694]: #011sync/cond.go:70 +0xbc fp=0xa8a77c0 sp=0xa8a779c pc=0x4444b28
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/queue.go:139 +0x70 fp=0xa8a77d0 sp=0xa8a77c0 pc=0x6577fe0
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:52 +0x28 fp=0xa8a77e4 sp=0xa8a77d0 pc=0x6577a1c
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:31 +0x28 fp=0xa8a77ec sp=0xa8a77e4 pc=0x65778e4
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xa8a77ec sp=0xa8a77ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 265 [sync.Cond.Wait, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xa8d1f70 sp=0xa8d1f5c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: sync.runtime_notifyListWait(0xa31fc08, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/sema.go:527 +0x1e4 fp=0xa8d1f9c sp=0xa8d1f70 pc=0x441c2f4
Sep 10 16:15:19 openhabian grafana[6694]: #011sync/cond.go:70 +0xbc fp=0xa8d1fc0 sp=0xa8d1f9c pc=0x4444b28
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/queue.go:139 +0x70 fp=0xa8d1fd0 sp=0xa8d1fc0 pc=0x6577fe0
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:52 +0x28 fp=0xa8d1fe4 sp=0xa8d1fd0 pc=0x6577a1c
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:31 +0x28 fp=0xa8d1fec sp=0xa8d1fe4 pc=0x65778e4
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xa8d1fec sp=0xa8d1fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 266 [sync.Cond.Wait, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xa8a0770 sp=0xa8a075c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: sync.runtime_notifyListWait(0xa31fc08, 0xe)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/sema.go:527 +0x1e4 fp=0xa8a079c sp=0xa8a0770 pc=0x441c2f4
Sep 10 16:15:19 openhabian grafana[6694]: #011sync/cond.go:70 +0xbc fp=0xa8a07c0 sp=0xa8a079c pc=0x4444b28
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/queue.go:139 +0x70 fp=0xa8a07d0 sp=0xa8a07c0 pc=0x6577fe0
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:52 +0x28 fp=0xa8a07e4 sp=0xa8a07d0 pc=0x6577a1c
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:31 +0x28 fp=0xa8a07ec sp=0xa8a07e4 pc=0x65778e4
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xa8a07ec sp=0xa8a07ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 267 [sync.Cond.Wait, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xa8a0f70 sp=0xa8a0f5c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: sync.runtime_notifyListWait(0xa31fc08, 0x10)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/sema.go:527 +0x1e4 fp=0xa8a0f9c sp=0xa8a0f70 pc=0x441c2f4
Sep 10 16:15:19 openhabian grafana[6694]: #011sync/cond.go:70 +0xbc fp=0xa8a0fc0 sp=0xa8a0f9c pc=0x4444b28
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/queue.go:139 +0x70 fp=0xa8a0fd0 sp=0xa8a0fc0 pc=0x6577fe0
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:52 +0x28 fp=0xa8a0fe4 sp=0xa8a0fd0 pc=0x6577a1c
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:31 +0x28 fp=0xa8a0fec sp=0xa8a0fe4 pc=0x65778e4
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xa8a0fec sp=0xa8a0fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 268 [sync.Cond.Wait, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xa8a1770 sp=0xa8a175c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: sync.runtime_notifyListWait(0xa31fc08, 0x12)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/sema.go:527 +0x1e4 fp=0xa8a179c sp=0xa8a1770 pc=0x441c2f4
Sep 10 16:15:19 openhabian grafana[6694]: #011sync/cond.go:70 +0xbc fp=0xa8a17c0 sp=0xa8a179c pc=0x4444b28
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/queue.go:139 +0x70 fp=0xa8a17d0 sp=0xa8a17c0 pc=0x6577fe0
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:52 +0x28 fp=0xa8a17e4 sp=0xa8a17d0 pc=0x6577a1c
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/centrifugal/centrifuge@v0.29.1/internal/dissolve/dissolve.go:31 +0x28 fp=0xa8a17ec sp=0xa8a17e4 pc=0x65778e4
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xa8a17ec sp=0xa8a17ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 269 [sync.Cond.Wait, 1 minutes]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xa8a1f70 sp=0xa8a1f5c pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0x9882f60 sp=0x9882ec4 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: net/http.(*persistConn).writeLoop(0xc4448c0)
Sep 10 16:15:19 openhabian grafana[6694]: #011net/http/transport.go:2421 +0xd0 fp=0x9882fe4 sp=0x9882f60 pc=0x47b2f2c
Sep 10 16:15:19 openhabian grafana[6694]: net/http.(*Transport).dialConn.func6()
Sep 10 16:15:19 openhabian grafana[6694]: #011net/http/transport.go:1777 +0x28 fp=0x9882fec sp=0x9882fe4 pc=0x47afd0c
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x9882fec sp=0x9882fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by net/http.(*Transport).dialConn in goroutine 484
Sep 10 16:15:19 openhabian grafana[6694]: #011net/http/transport.go:1777 +0x1490
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 515 [IO wait]:
Sep 10 16:15:19 openhabian grafana[6694]: runtime.gopark(0x11216c8, 0xecad79d0, 0x2, 0x1b, 0x5)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xafc0ab8 sp=0xafc0aa4 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.netpollblock(0xecad79c0, 0x72, 0x0)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/netpoll.go:564 +0x100 fp=0xafc0ad0 sp=0xafc0ab8 pc=0x43dcaa8
Sep 10 16:15:19 openhabian grafana[6694]: internal/poll.runtime_pollWait(0xecad79c0, 0x72)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/netpoll.go:343 +0x54 fp=0xafc0ae4 sp=0xafc0ad0 pc=0x441a1e4
Sep 10 16:15:19 openhabian grafana[6694]: internal/poll.(*pollDesc).wait(0xa4326a8, 0x72, 0x0)
Sep 10 16:15:19 openhabian grafana[6694]: #011internal/poll/fd_poll_runtime.go:84 +0x30 fp=0xafc0af8 sp=0xafc0ae4 pc=0x44a4914
Sep 10 16:15:19 openhabian grafana[6694]: internal/poll.(*pollDesc).waitRead(...)
Sep 10 16:15:19 openhabian grafana[6694]: #011internal/poll/fd_poll_runtime.go:89
Sep 10 16:15:19 openhabian grafana[6694]: internal/poll.(*FD).Read(0xa432690, {0xc9e9900, 0x1300, 0x1300})
Sep 10 16:15:19 openhabian grafana[6694]: #011internal/poll/fd_unix.go:164 +0x240 fp=0xafc0b48 sp=0xafc0af8 pc=0x44a5b20
Sep 10 16:15:19 openhabian grafana[6694]: net.(*netFD).Read(0xa432690, {0xc9e9900, 0x1300, 0x1300})
Sep 10 16:15:19 openhabian grafana[6694]: #011net/fd_posix.go:55 +0x38 fp=0xafc0b74 sp=0xafc0b48 pc=0x466b5cc
Sep 10 16:15:19 openhabian grafana[6694]: net.(*conn).Read(0xb13ea28, {0xc9e9900, 0x1300, 0x1300})
Sep 10 16:15:19 openhabian grafana[6694]: #011net/net.go:179 +0x48 fp=0xafc0ba4 sp=0xafc0b74 pc=0x467f6bc
Sep 10 16:15:19 openhabian grafana[6694]: net.(*TCPConn).Read(0xb13ea28, {0xc9e9900, 0x1300, 0x1300})
Sep 10 16:15:19 openhabian grafana[6694]: #011<autogenerated>:1 +0x44 fp=0xafc0bc4 sp=0xafc0ba4 pc=0x4696708
Sep 10 16:15:19 openhabian grafana[6694]: crypto/tls.(*atLeastReader).Read(0xb539270, {0xc9e9900, 0x1300, 0x1300})
Sep 10 16:15:19 openhabian grafana[6694]: #011crypto/tls/conn.go:805 +0x78 fp=0xafc0bf4 sp=0xafc0bc4 pc=0x46ca444
Sep 10 16:15:19 openhabian grafana[6694]: bytes.(*Buffer).ReadFrom(0x98b4384, {0x18f5b40, 0xb539270})
Sep 10 16:15:19 openhabian grafana[6694]: #011bytes/buffer.go:211 +0xa4 fp=0xafc0c34 sp=0xafc0bf4 pc=0x44d6418
Sep 10 16:15:19 openhabian grafana[6694]: crypto/tls.(*Conn).readFromUntil(0x98b4200, {0x18f5b7c, 0xb13ea28}, 0x5)
Sep 10 16:15:19 openhabian grafana[6694]: #011crypto/tls/conn.go:827 +0xd4 fp=0xafc0c5c sp=0xafc0c34 pc=0x46ca6b4
Sep 10 16:15:19 openhabian grafana[6694]: crypto/tls.(*Conn).readRecordOrCCS(0x98b4200, 0x0)
Sep 10 16:15:19 openhabian grafana[6694]: #011crypto/tls/conn.go:625 +0x248 fp=0xafc0dec sp=0xafc0c5c pc=0x46c7ce4
Sep 10 16:15:19 openhabian grafana[6694]: crypto/tls.(*Conn).readRecord(...)
Sep 10 16:15:19 openhabian grafana[6694]: #011crypto/tls/conn.go:587
Sep 10 16:15:19 openhabian grafana[6694]: crypto/tls.(*Conn).Read(0x98b4200, {0xbd90000, 0x1000, 0x1000})
Sep 10 16:15:19 openhabian grafana[6694]: #011crypto/tls/conn.go:1369 +0x160 fp=0xafc0e1c sp=0xafc0dec pc=0x46cddf8
Sep 10 16:15:19 openhabian grafana[6694]: net/http.(*persistConn).Read(0xc444960, {0xbd90000, 0x1000, 0x1000})
Sep 10 16:15:19 openhabian grafana[6694]: #011net/http/transport.go:1954 +0x16c fp=0xafc0e50 sp=0xafc0e1c pc=0x47b089c
Sep 10 16:15:19 openhabian grafana[6694]: bufio.(*Reader).fill(0xc680d50)
Sep 10 16:15:19 openhabian grafana[6694]: #011bufio/bufio.go:113 +0x10c fp=0xafc0e74 sp=0xafc0e50 pc=0x470cbac
Sep 10 16:15:19 openhabian grafana[6694]: bufio.(*Reader).Peek(0xc680d50, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011bufio/bufio.go:151 +0x68 fp=0xafc0e80 sp=0xafc0e74 pc=0x470cd34
Sep 10 16:15:19 openhabian grafana[6694]: net/http.(*persistConn).readLoop(0xc444960)
Sep 10 16:15:19 openhabian grafana[6694]: #011net/http/transport.go:2118 +0x194 fp=0xafc0fe4 sp=0xafc0e80 pc=0x47b1444
Sep 10 16:15:19 openhabian grafana[6694]: net/http.(*Transport).dialConn.func5()
Sep 10 16:15:19 openhabian grafana[6694]: #011net/http/transport.go:1776 +0x28 fp=0xafc0fec sp=0xafc0fe4 pc=0x47afd60
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xafc0fec sp=0xafc0fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by net/http.(*Transport).dialConn in goroutine 489
Sep 10 16:15:19 openhabian grafana[6694]: #011net/http/transport.go:1776 +0x1440
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 516 [select]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xc9c9ec4 sp=0xc9c9eb0 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0xc9c9fd0, 0xc9c9f90, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0xc9c9f60 sp=0xc9c9ec4 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: net/http.(*persistConn).writeLoop(0xc444960)
Sep 10 16:15:19 openhabian grafana[6694]: #011net/http/transport.go:2421 +0xd0 fp=0xc9c9fe4 sp=0xc9c9f60 pc=0x47b2f2c
Sep 10 16:15:19 openhabian grafana[6694]: #011net/http/transport.go:1777 +0x28 fp=0xc9c9fec sp=0xc9c9fe4 pc=0x47afd0c
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xc9c9fec sp=0xc9c9fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 443 [select]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xaf89ec0 sp=0xaf89eac pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0xaf89f94, 0xaf89f80, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0xaf89f5c sp=0xaf89ec0 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/grafana/pkg/services/ngalert/notifier.(*MultiOrgAlertmanager).Run(0xa59bb90, {0x191fe6c, 0xc04d8f0})
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/grafana/pkg/services/ngalert/notifier/multiorg_alertmanager.go:148 +0xdc fp=0xaf89fa4 sp=0xaf89f5c pc=0x6779e54
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/grafana/pkg/services/ngalert.(*AlertNG).Run.func2()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/grafana/pkg/services/ngalert/ngalert.go:326 +0x30 fp=0xaf89fbc sp=0xaf89fa4 pc=0x6807bec
Sep 10 16:15:19 openhabian grafana[6694]: golang.org/x/sync/errgroup.(*Group).Go.func1()
Sep 10 16:15:19 openhabian grafana[6694]: #011golang.org/x/sync@v0.3.0/errgroup/errgroup.go:75 +0x60 fp=0xaf89fec sp=0xaf89fbc pc=0x5122fe4
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xaf89fec sp=0xaf89fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by golang.org/x/sync/errgroup.(*Group).Go in goroutine 450
Sep 10 16:15:19 openhabian grafana[6694]: #011golang.org/x/sync@v0.3.0/errgroup/errgroup.go:72 +0xa0
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 444 [select]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xc86fe88 sp=0xc86fe74 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0xc86ff64, 0xc86ff48, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0xc86ff24 sp=0xc86fe88 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/grafana/pkg/services/ngalert/sender.(*AlertsRouter).Run(0xa62c420, {0x191fe6c, 0xc04d8f0})
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/grafana/pkg/services/ngalert/sender/router.go:361 +0x9c fp=0xc86ffa4 sp=0xc86ff24 pc=0x679d690
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/grafana/pkg/services/ngalert.(*AlertNG).Run.func3()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/grafana/pkg/services/ngalert/ngalert.go:329 +0x30 fp=0xc86ffbc sp=0xc86ffa4 pc=0x6807b9c
Sep 10 16:15:19 openhabian grafana[6694]: #011golang.org/x/sync@v0.3.0/errgroup/errgroup.go:75 +0x60 fp=0xc86ffec sp=0xc86ffbc pc=0x5122fe4
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xc86ffec sp=0xc86ffec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 445 [select]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xaf87dd8 sp=0xaf87dc4 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0xaf87f0c, 0xaf87ef4, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0xaf87e74 sp=0xaf87dd8 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/grafana/pkg/services/ngalert/schedule.(*schedule).schedulePeriodic(0x9f44980, {0x191fe6c, 0xc04d8f0}, 0xc04d980)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/grafana/pkg/services/ngalert/schedule/schedule.go:169 +0x328 fp=0xaf87f6c sp=0xaf87e74 pc=0x67eab4c
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/grafana/pkg/services/ngalert/schedule.(*schedule).Run(0x9f44980, {0x191fe6c, 0xc04d8f0})
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/grafana/pkg/services/ngalert/schedule/schedule.go:137 +0x15c fp=0xaf87fa4 sp=0xaf87f6c pc=0x67ea334
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/grafana/pkg/services/ngalert.(*AlertNG).Run.func4()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/grafana/pkg/services/ngalert/ngalert.go:334 +0x38 fp=0xaf87fbc sp=0xaf87fa4 pc=0x6807b4c
Sep 10 16:15:19 openhabian grafana[6694]: #011golang.org/x/sync@v0.3.0/errgroup/errgroup.go:75 +0x60 fp=0xaf87fec sp=0xaf87fbc pc=0x5122fe4
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xaf87fec sp=0xaf87fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 446 [select]:
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0x9880e54 sp=0x9880e40 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0x9880f3c, 0x9880f24, 0x0, 0x0, 0x2, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0x9880ef0 sp=0x9880e54 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/grafana/pkg/util/ticker.(*T).run(0xc04d980)
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/grafana/pkg/util/ticker/ticker.go:69 +0x454 fp=0x9880fe4 sp=0x9880ef0 pc=0x5dec5c4
Sep 10 16:15:19 openhabian grafana[6694]: github.com/grafana/grafana/pkg/util/ticker.New.func1()
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/grafana/pkg/util/ticker/ticker.go:40 +0x28 fp=0x9880fec sp=0x9880fe4 pc=0x5debef8
Sep 10 16:15:19 openhabian grafana[6694]: runtime.goexit()
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0x9880fec sp=0x9880fec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by github.com/grafana/grafana/pkg/util/ticker.New in goroutine 445
Sep 10 16:15:19 openhabian grafana[6694]: #011github.com/grafana/grafana/pkg/util/ticker/ticker.go:40 +0x2c4
Sep 10 16:15:19 openhabian grafana[6694]: goroutine 525 [select]:
Sep 10 16:15:19 openhabian grafana[6694]: runtime.gopark(0x112170c, 0x0, 0x9, 0x18, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/proc.go:398 +0x104 fp=0xa8e86d8 sp=0xa8e86c4 pc=0x43e58cc
Sep 10 16:15:19 openhabian grafana[6694]: runtime.selectgo(0xa8e87b4, 0xa8e8798, 0x0, 0x0, 0x3, 0x1)
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/select.go:327 +0xaf0 fp=0xa8e8774 sp=0xa8e86d8 pc=0x43f9680
Sep 10 16:15:19 openhabian grafana[6694]: database/sql.(*Rows).awaitDone(0xb15df90, {0x191fe4c, 0xbba2438}, {0x0, 0x0}, {0x191fe6c, 0xc6811a0})
Sep 10 16:15:19 openhabian grafana[6694]: #011database/sql/sql.go:2962 +0xcc fp=0xa8e87cc sp=0xa8e8774 pc=0x4c8f5a4
Sep 10 16:15:19 openhabian grafana[6694]: database/sql.(*Rows).initContextClose.func1()
Sep 10 16:15:19 openhabian grafana[6694]: #011database/sql/sql.go:2949 +0x58 fp=0xa8e87ec sp=0xa8e87cc pc=0x4c8f4ac
Sep 10 16:15:19 openhabian grafana[6694]: #011runtime/asm_arm.s:859 +0x4 fp=0xa8e87ec sp=0xa8e87ec pc=0x441f598
Sep 10 16:15:19 openhabian grafana[6694]: created by database/sql.(*Rows).initContextClose in goroutine 462
Sep 10 16:15:19 openhabian grafana[6694]: #011database/sql/sql.go:2949 +0x1ac
Sep 10 16:15:19 openhabian grafana[6694]: trap    0x0
Sep 10 16:15:19 openhabian grafana[6694]: error   0x0
Sep 10 16:15:19 openhabian grafana[6694]: oldmask 0x0
Sep 10 16:15:19 openhabian grafana[6694]: r0      0x0
Sep 10 16:15:19 openhabian grafana[6694]: r1      0x0
Sep 10 16:15:19 openhabian grafana[6694]: r2      0x1
Sep 10 16:15:19 openhabian grafana[6694]: r3      0x1
Sep 10 16:15:19 openhabian grafana[6694]: r4      0xeaeee1a4
Sep 10 16:15:19 openhabian grafana[6694]: r5      0xc9ba694
Sep 10 16:15:19 openhabian grafana[6694]: r6      0xa3e0248
Sep 10 16:15:19 openhabian grafana[6694]: r7      0x10
Sep 10 16:15:19 openhabian grafana[6694]: r8      0xa4846c0
Sep 10 16:15:19 openhabian grafana[6694]: r9      0x0
Sep 10 16:15:19 openhabian grafana[6694]: r10     0xc9bce00
Sep 10 16:15:19 openhabian grafana[6694]: fp      0xeae8baa8
Sep 10 16:15:19 openhabian grafana[6694]: ip      0x0
Sep 10 16:15:19 openhabian grafana[6694]: sp      0xeae871dc
Sep 10 16:15:19 openhabian grafana[6694]: lr      0x85f76d8
Sep 10 16:15:19 openhabian grafana[6694]: pc      0x86232c4
Sep 10 16:15:19 openhabian grafana[6694]: cpsr    0x60000010
Sep 10 16:15:19 openhabian grafana[6694]: fault   0x0
This ( fresh ) means that you downloaded and installed the latest openhabian image and you are on Bullseye ?
Hello @Wolfgang_S,
Yes exactly, I downloaded the lastest openhabian image.
I checked the system, all is up to date.
Bernard
Maybe this is linked to the latest Grafana issue here:https://github.com/grafana/grafana/issues/73781 ?
Hello @openhabgs
Thank you for your reponse. I’ll have a look to the thread.
I’ve also noticed something strange with grafana repo when updating the system:
apt-get update
Get:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
Hit:2 http://davesteele.github.io/comitup/repo comitup InRelease
Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:4 https://repos.influxdata.com/debian bullseye InRelease
Get:5 https://packages.grafana.com/oss/deb stable InRelease [5,984 B]
Get:6 https://deb.nodesource.com/node_18.x bullseye InRelease [4,586 B]
Err:5 https://packages.grafana.com/oss/deb stable InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
Fetched 19.6 kB in 2s (12.3 kB/s)
Reading package lists... Done
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
W: Some index files failed to download. They have been ignored, or old ones used instead.
Bernard
dont know if it might help, i also had a problem a couple of days ago and was not able to update openhabian because of a failed grafana update. dont remember the error message but also was debending of a key. worst was that no update was possible, even not the others that are not related to grafana.
but i need to add i did not have a problem with a restart of grafana in a defined time, grafana always worked, i only was not able to update!
i found the solution for me here:
additional: when i typed in the console:
apt-key list | grep -i grafana | wc -l
i received the 0 back
so i only had to type
sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
then i could update again, only grafana showed still
Die folgenden Pakete sind zurückgehalten worden...
and was left out. so i had to
sudo apt-get dist-upgrade
and after that all update worked again
Thank you @bastler,
I will try!
Jeblack
I had the same problem and followed your solution - and after that system was working again as expected and grafana was update. Afterwards also the openhabian upgrade worked.
Thanks for sharing this
