OpenHab run on RPi4 with InfluxDB + Grafana. I cannot get access to grafana.
Platform information:
- RPi4B with openhabian and openHAB 2.5.0~S1549-1 (Build #1549)
- Installed InfluxDB and Grafana from openhabian-config
After install port 8080 and 9001 works as expected, but when I try to reach grafana throughIP :3000 from browser, i cant connect.
checking grafana-server.service:
[15:34:37] openhabian@openhab:~$ sudo systemctl status grafana-server
● grafana-server.service - Grafana instance
Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2020-08-19 15:28:37 CEST; 7min ago
Docs: http://docs.grafana.org
Process: 14886 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid -
Main PID: 14886 (code=exited, status=1/FAILURE)
Aug 19 15:28:37 openhab systemd[1]: grafana-server.service: Service RestartSec=100ms expired, scheduling restart.
Aug 19 15:28:37 openhab systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
Aug 19 15:28:37 openhab systemd[1]: Stopped Grafana instance.
Aug 19 15:28:37 openhab systemd[1]: grafana-server.service: Start request repeated too quickly.
Aug 19 15:28:37 openhab systemd[1]: grafana-server.service: Failed with result 'exit-code'.
Aug 19 15:28:37 openhab systemd[1]: Failed to start Grafana instance.
I have tried to reinstall without any success.
After running without grafana to visualize data I tried to see why the grafana-server.service fails.
$ sudo journalctl | grep grafana
show:
Sep 02 14:42:15 openhab systemd[1]: grafana-server.service: Main process exited, code=exited, status=1/FAILURE
Sep 02 14:42:15 openhab systemd[1]: grafana-server.service: Failed with result ‘exit-code’.
Sep 02 14:42:16 openhab systemd[1]: grafana-server.service: Service RestartSec=100ms expired, scheduling restart.
Sep 02 14:42:16 openhab systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 4.
Sep 02 14:42:16 openhab grafana-server[28876]: t=2020-09-02T14:42:16+0200 lvl=info msg=“Starting Grafana” logger=server version=5.4.3 commit=6539180 branch=HEAD compiled=2019-01-14T15:26:26+0100
Sep 02 14:42:16 openhab grafana-server[28876]: t=2020-09-02T14:42:16+0200 lvl=info msg=“Config loaded from” logger=settings file=/usr/share/grafana/conf/defaults.ini
Sep 02 14:42:16 openhab grafana-server[28876]: t=2020-09-02T14:42:16+0200 lvl=info msg=“Config loaded from” logger=settings file=/etc/grafana/grafana.ini
Sep 02 14:42:16 openhab grafana-server[28876]: t=2020-09-02T14:42:16+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.data=/var/lib/grafana”
Sep 02 14:42:16 openhab grafana-server[28876]: t=2020-09-02T14:42:16+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.logs=/var/log/grafana”
Sep 02 14:42:16 openhab grafana-server[28876]: t=2020-09-02T14:42:16+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.plugins=/var/lib/grafana/plugins”
Sep 02 14:42:16 openhab grafana-server[28876]: t=2020-09-02T14:42:16+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.provisioning=/etc/grafana/provisioning”
Sep 02 14:42:16 openhab grafana-server[28876]: t=2020-09-02T14:42:16+0200 lvl=info msg=“Path Home” logger=settings path=/usr/share/grafana
Sep 02 14:42:16 openhab grafana-server[28876]: t=2020-09-02T14:42:16+0200 lvl=info msg=“Path Data” logger=settings path=/var/lib/grafana
Sep 02 14:42:16 openhab grafana-server[28876]: t=2020-09-02T14:42:16+0200 lvl=info msg=“Path Logs” logger=settings path=/var/log/grafana
Sep 02 14:42:16 openhab grafana-server[28876]: t=2020-09-02T14:42:16+0200 lvl=info msg=“Path Plugins” logger=settings path=/var/lib/grafana/plugins
Sep 02 14:42:16 openhab grafana-server[28876]: t=2020-09-02T14:42:16+0200 lvl=info msg=“Path Provisioning” logger=settings path=/usr/share/grafana/conf/provisioning
Sep 02 14:42:16 openhab grafana-server[28876]: t=2020-09-02T14:42:16+0200 lvl=info msg=“App mode production” logger=settings
Sep 02 14:42:16 openhab grafana-server[28876]: t=2020-09-02T14:42:16+0200 lvl=info msg=“Writing PID file” logger=server path=/var/run/grafana/grafana-server.pid pid=28876
Sep 02 14:42:16 openhab grafana-server[28876]: t=2020-09-02T14:42:16+0200 lvl=info msg=“Initializing HTTPServer” logger=server
Sep 02 14:42:16 openhab grafana-server[28876]: t=2020-09-02T14:42:16+0200 lvl=info msg=“Initializing SqlStore” logger=server
Sep 02 14:42:16 openhab grafana-server[28876]: t=2020-09-02T14:42:16+0200 lvl=eror msg=“Server shutdown” logger=server reason=“Service init failed: Fail to connect to database: Unknown database type: influxdb”
Sep 02 14:42:16 openhab systemd[1]: grafana-server.service: Main process exited, code=exited, status=1/FAILURE
Sep 02 14:42:16 openhab systemd[1]: grafana-server.service: Failed with result ‘exit-code’.
Sep 02 14:42:16 openhab sudo[28882]: openhabian : TTY=pts/0 ; PWD=/run ; USER=root ; COMMAND=/bin/systemctl status grafana-server
Sep 02 14:42:16 openhab systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
Sep 02 14:42:16 openhab systemd[1]: grafana-server.service: Start request repeated too quickly.
It seems that the cause is reported by the statement
Sep 02 14:42:16 openhab grafana-server[28876]: t=2020-09-02T14:42:16+0200 lvl=eror msg="Server shutdown" logger=server reason="Service init failed: Fail to connect to database: Unknown database type: influxdb"
However, I am not able to see why the influxdb should not be known. Storage to the influxdb database works fine, and is visualized in habpanel.
Help is appreciated.
Thanks!
