Grafana: No datapoints
Hi all,
I have a smal problem with Grafana and InfluxDB, but this makes me not being able to draw graphs.
My database has content, see the following image:content
But there are no datapoints available for Grafana, see the following image:
no%20datapoints
I followed this tutorial here InfluxDB+Grafana persistence and graphing
Do you have an answer here? I assume it has something to do with the timestamp of the database entries, the example of the sine_wave in the tutorial works like a charm
is it really a FROM autogen?
At SELECT, I’m using field(value) and mean() - removing mean() results in empty graphs :slight_smile:
11
Cheers,
Marianne
Hello Marianne,
thanks for the reply! It should be autogen, because influxdbs’ standard value is autogen and i did not change it. but i tried, as you suggested, also default, with same result. anyway, grafana offers me only autogen when i select a value in the “from” list.
maybe some other tips?
Have you setup grafana as image below?
Hi there! Yes, setup is like that.
yes
I found something else, and propably this has something to do with the issue. See the following picture from the query inspector:
null
All the data has only a timestamp but no axis value. Only “null”.
Do you know why?
That maybe the reason, mine look like this:
i think i found the reason for this issue, i played a bit with grafana and found out that inside my database there are only very few data, meaning a lot of values with “null” and only a few with real data.
i played a bit with the time range and found a graph like this:
null1
Is this related to my strategies in the persistence file? mine looks like this:
strategies
what is yours?
Nice!
Maybe you have to have every minute.
influxdb.persist:
Strategies {
everyMinute : “0 * * * * ?”
everyHour : “0 0 * * * ?”
everyDay : “0 0 0 * * ?”
Items {
Temperature* : strategy = everyChange, everyMinute
Strom* : strategy = everyChange, everyMinute
Lys* : strategy = everyChange, everyMinute
