This only happens when I include the item corresponding to car charging, “Sähköauto”. If I remove that the bars of the past look as they should. I have triple checked that the settings of the car chargin item are the same as for the rest of the items.
I sometines want to manually override the control values that have been automatically calculated. For this, I have an UI datetime widget to force a given hour’s control value on / off, see screenshot.
I have to be very careful and select full hour in this widget so that the control value will be written for the full hour. If I make a mistake and select for example 15:01 with the widget, then I will have two control values, one for 15:00 and another for 15:01.
What causes the error? Will the control point end up on e.g 15:01 if the script that sets the control points runs over a minute? My script sets control points for dishwasher, washing machine and car charging in one script and in that order. Car charging control points are set last.
That should not matter because we’re anyway talking about control points of tomorrow. I’d suggest that you inspect your raw data points in InfluxDB data explorer to see if this hypothesis is correct to begin with.
I don’t think these latter values are your control values, they seem to be the actual start times of your dish washer or laundry machine based on the names of your measurements.
You can use the measurement names (such as nibe_control, waterheater_control) as the filter on the bottom part of the screen.
Your control values seem to follow the same pattern with each other. For some reason your control values are at 30 min past full hour when inspected with influx data explorer, it’s the time_ attribute / column that I was interested in. You can see the 0 and 1 control values there for each hour.
But anyway, the reason for the spikes in the chart is that on 2023-07-20 you had two car charger control values for the same hour (they were 10 seconds apart from each other). I suspect that you have a configuration bug.
You should have two clearly de-coupled items (and influxdb measurements). One for the control values (when the chargong should be on) and another for the actuals (when the charging actually was on). I suspect that your rules that toggle the charging on/off are also writing to the control value measurement.
The only rule I could find running at 30 minutes past full hour was the rule that determines the number of heating hours which, when run, also triggers the fetching of spot prices from Ensto-E. I made this now run at 15:00 only, as opposed to the earlier 14:30 and 19:30
This is probable. I have tested with a number of item names to fix the problem. There may still be duplicate rules and/or items running. Need to do a cleanup of the spaghetti this has turned into during the debugging.
Fetches the fresh weather forecast and does nothing else
Rule CalculateHeatingHours
Runs daily at 14.20
The script action implicitly assumes that we previously fetched weather forecast data in our database but does not re-fetch it. It simply calculates the heating hours and saves the result to an Item called "HeatingHours"l
Rule FetchSpotPrices
Runs 14.15, 14.45, 15.15 and 15.45
The first rule action contains the code that fetches the spot prices from Entso-E API
It also invokes 4 other rules as can be seen in the screenshot below. These are “DetermineWaterHeatingControls”, “DetermineCompressorControls”, “DetermineNibeWaterHeatingControls” and “DetermineCarChargingControls”. In other words, every device that has control points has its own “Determine control points” rule which are invoked here.
These control points are re-determined whenever the HeatingHours (or HeatingSlices or MinimumHeatingPerSlice) has changed, see screenshot below
Summary
The benefit of breaking down the logic like this is that
I don’t need to call the Entso-E API over and over again if I need to re-determine the control points for one device
If I need to re-determine the control points for one device, I don’t need to re-determine the other control points
One “DetermineXXXControlPoints” rule does only one thing, easy to maintain
The “When HeatingHours changed” condition means that the control points are automatically re-determined when the item “HeatingHours” changes. Which happens either automatically by the rule CalculateHeatingHours OR if I manually change it with an UI widget which looks like this:
The point of this UI is that I can easily override the heating parameters if there is a need to do so. Whenever these parameters change, the heating control points are re-determined.
You’re of course free to structure your rules however you want but I have found this de-coupled approach to be easy to maintain.
This indeed was the root cause for the problem.
For the system to work I have created items with same names as the points the forecast scripts create in InfluxDB in the future, e.g. “washer_control”, “charger_control” etc. These same items are mapped in the graphs.
However, these item states do not automatically change when the InfluxDB point changes. Hence, I had to make a script that every full hour gets the current value of the InfluxDB point and updates the corresponding item with the current value. Herein lies the error. When I updated the item the item value was updated back to InfluxDB! As a result there was two values for the same item at a bit separate times. This confused the graph.
