I was wondering on where to go on this one. I have MySQL persistence running for graphing etc and it has worked fine until I added a new item to display a graph on. I am using openhab 3.0.0 release build with the basicui to the android app. I am running on a pi talking to a MySQL server to limit writes.
I have done an update and increased logging to the full error:
2021-08-04 20:40:12.098 [WARN ] [e.io.http.servlet.BaseOpenHABServlet] - Illegal argument in chart: Series name cannot be null or zero-length!!!
2021-08-04 20:40:12.101 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /chart
java.lang.IllegalStateException: COMMITTED
at org.eclipse.jetty.server.HttpChannelState.sendError(HttpChannelState.java:896) ~[?:?]
at org.eclipse.jetty.server.Response.sendError(Response.java:471) ~[?:?]
at org.openhab.core.ui.internal.chart.ChartServlet.doGet(ChartServlet.java:327) ~[?:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) ~[bundleFile:3.1.0]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) ~[bundleFile:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:791) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:550) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602) ~[?:?]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1435) ~[bundleFile:9.4.40.v20210413]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1350) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[bundleFile:9.4.40.v20210413]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:82) ~[?:?]
at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:540) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:395) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:161) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:383) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:882) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1036) [bundleFile:9.4.40.v20210413]
2021-08-10 22:45:59.216 [DEBUG] [ab.core.ui.icon.internal.IconServlet] - Requested icon category provided by no icon provider
2021-08-10 22:46:00.122 [DEBUG] [ui.internal.items.ItemUIRegistryImpl] - Checking visiblity for widget 'null'.
2021-08-10 22:46:00.127 [DEBUG] [ui.internal.items.ItemUIRegistryImpl] - Checking visiblity for widget 'null'.
2021-08-10 22:46:00.128 [DEBUG] [ui.internal.items.ItemUIRegistryImpl] - Widget null is not visible.
2021-08-10 22:46:00.131 [DEBUG] [ui.internal.items.ItemUIRegistryImpl] - Checking visiblity for widget 'null'.
2021-08-10 22:46:00.132 [DEBUG] [ui.internal.items.ItemUIRegistryImpl] - Widget null is not visible.
2021-08-10 22:46:00.135 [DEBUG] [ui.internal.items.ItemUIRegistryImpl] - Checking visiblity for widget 'null'.
2021-08-10 22:46:00.136 [DEBUG] [ui.internal.items.ItemUIRegistryImpl] - Widget null is not visible.
2021-08-10 22:46:00.139 [DEBUG] [ui.internal.items.ItemUIRegistryImpl] - Checking visiblity for widget 'null'.
2021-08-10 22:46:00.140 [DEBUG] [ui.internal.items.ItemUIRegistryImpl] - Widget null is not visible.
2021-08-10 22:46:00.256 [DEBUG] [ltchartprovider.DefaultChartProvider] - Rendering chart: service: 'jdbc', theme: 'white', startTime: 'Tue Aug 10 14:46:00 BST 2021', endTime: 'Tue Aug 10 22:46:00 BST 2021', width: '1440', height: '720', items: 'ExternalEnergy', groups: 'null', dpi: '280', legend: 'null'
2021-08-10 22:46:00.431 [WARN ] [e.io.http.servlet.BaseOpenHABServlet] - Illegal argument in chart: Series name cannot be null or zero-length!!!
2021-08-10 22:46:00.432 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /chart
If I am reading this right it is because there is no legend coming through.
Could be wrong but I don’t think that the legend is the problem. In case it is just one parameter to display a legend is not required.
The above code extract shows a line containing debug log statement that shows Received incoming chart request: {}. This is not shown in your log extract.
If that row is shown we are sure that we are in the subroutine that raises the exception “Illegal argument in chart” and as far as I understand it should show all parts of the req object.
Is there maybe more information available before the log extract that you posted ?
@rossko57 Certainly wasn’t a silly suggestion. You are right the basic UI trips over no label being set. I have set them and it all now works. Daft I didn’t set one in the first place but hay.
