Hey folks,
I am trying to setup a group for all of my temperature and humidity sensors and would like to derive a group state from the member items:
Group:Number:AVG humidity <humidity>
Group:Number:AVG temperature <temperature>
The items are defined as follows:
Number:Temperature sensor_temperature_1 "Temperature [%.2f %unit%]" [...]
Number:Temperature sensor_temperature_2 "Temperature [%.2f %unit%]" [...]
Number:Temperature sensor_temperature_3 "Temperature [%.2f %unit%]" [...]
Number:Dimensionless sensor_humidity_1 "Humidity [%.2f %unit%]" [...]
Number:Dimensionless sensor_humidity_2 "Humidity [%.2f %unit%]" [...]
Number:Dimensionless sensor_humidity_3 "Humidity [%.2f %unit%]" [...]
The sensor I am using is the Ruuvi Tag, which I have added as a thing through the current binding. The values for both temperature and humidity are displayed fine in my sitemap. I can convert them as needed too.
Unfortunately, deriving the group state does not seem to work properly, as I am getting an error message:
2020-09-28 20:20:08.954 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Exception while formatting value ‘48.6250’ of item humidity with format ‘%.1f %unit%’: Conversion = ‘u’
2020-09-28 20:20:08.971 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Exception while formatting value ‘19.89’ of item temperature with format ‘%.1f %unit%’: Conversion = ‘u’
2020-09-28 20:20:09.502 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Exception while formatting value ‘48.6275’ of item humidity with format ‘%.1f %unit%’: Conversion = ‘u’
2020-09-28 20:20:09.513 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Exception while formatting value ‘19.89’ of item temperature with format ‘%.1f %unit%’: Conversion = ‘u’
This thread is dicussing the same problem, but with a different binding and its almost 5 years old:
https://community.openhab.org/t/items-in-sitemap-generate-log-message-exception-while-formatting-value-of-item/5401
